Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
Rotella T5 10w30 Ford 6.7L anyone?
by sw99. 12/14/18 07:49 AM
Advice on spark plugs for 90,000 mile Accord
by Chris B.. 12/13/18 11:24 PM
Elec star kit for predator engine...
by SmokeyBear. 12/13/18 11:07 PM
Mecredes Bosch vs Ngk sparks plug
by Rohan. 12/13/18 09:48 PM
Wife problem?
by penguin. 12/13/18 08:04 PM
2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
captobvious, pgrkcs, 4Doors4Life, 780Ari, kayumb
66677 Registered Users
102 registered members (bdcardinal, 4WD, AndyB, AZjeff, Alfred_B, 14 invisible), 1,975 guests, and 43 spiders.
Topics295,061
Posts4,927,058
Members66,677
Most Online2,553
Oct 27th, 2018
1952 Chevy DeLuxe - Radiator cap rated 16 pounds? #4526431
09/26/17 06:26 AM
09/26/17 06:26 AM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
Noticed last night that my old 1952 Chevy Deluxe has a modern radiator cap on it, rated at 16 pounds. Although it fits properly, I'm fairly certain that a 16 pound cap isn't correct for a 65 year old car.
I would assume that it should be more like a 4 pound, or possibly a 7 pound cap.
Is there some reason (other than scarce availability of a 4 pound cap), that someone would fit a 16 pound cap here? I can't think of any.
This is a 235 cubic inch straight 6, with an original style radiator and water pump. Rock Auto has a 4 pound cap, that would appear to fit.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526444
09/26/17 06:43 AM
09/26/17 06:43 AM
hawthorne, Ca.
46Harry Offline
46Harry  Offline
hawthorne, Ca.
A 16 lb cap is way to high for an old Chevy 6. A 4 or 7 lb cap is what I would use. I use 7 lb caps on my Studebakers and they do just fine.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526452
09/26/17 07:01 AM
09/26/17 07:01 AM
GA
drtyler Offline
drtyler  Offline
GA
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526574
09/26/17 09:14 AM
09/26/17 09:14 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Wow! I'm surprised you didn't push out the packing in the pump. That is a 216 CI engine a very primitive OHV 6 Babbitted bushings in the lower end. Non-permanent anti-freeze. My '40 had scoops on the rod caps. The 235 introduced in '53 was a way better engine.
Thick oil is better grin2
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: andyd] #4526591
09/26/17 09:32 AM
09/26/17 09:32 AM
GA
drtyler Offline
drtyler  Offline
GA
Maybe, maybe not.
If it's a 3 speed, the original engine is a 216. It's possible that the engine may have been changed out to a 235 in the past 65 years.
If its a Powerglide, the original engine is a low pressure 235. Basically a bored 216 with hydraulic lifters.
His car may have one of the post-1953 235s, but he hasn't mentioned which engine is in his car now.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526711
09/26/17 11:52 AM
09/26/17 11:52 AM
Illinois
mrsilv04 Offline OP
mrsilv04  Offline OP
Illinois
Did mention it is a 235.
Didn't mention that the castings on the block suggest that it is from 1955.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526719
09/26/17 12:03 PM
09/26/17 12:03 PM
Texas
GMBoy Offline
GMBoy  Offline
Texas
My 1958 Apache has a 7lb cap. I run a 50/50 mix of traditional Green coolant.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526720
09/26/17 12:04 PM
09/26/17 12:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Wasn't the 235 basically unchanged up until around 1961 or 1962?
It may be that it can actually handle 8 psi or more.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526740
09/26/17 12:22 PM
09/26/17 12:22 PM
GA
drtyler Offline
drtyler  Offline
GA
Starting in '54, the 7 lb cap was specified by Chevy.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: mrsilv04] #4526753
09/26/17 12:37 PM
09/26/17 12:37 PM
Marshfield , MA
Marshfield , MA
As old Chevys go, I think the 235 was my favorite engine. In 1967, a buddy bought a beautiful 54 Belair convertible for 75$ because the top was junk.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: andyd] #4526761
09/26/17 12:46 PM
09/26/17 12:46 PM
California
Billbert Offline
Billbert  Offline
California
he biggest problem will be the design of the radiator where the tanks are soldered. design changes later on allowed for a stronger seal and higher pressures to increase the boiling temperature
If you think you can, or if you think you can't, You are probably right.
Auto Instructor / ASE Master Tech
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: drtyler] #4526863
09/26/17 03:16 PM
09/26/17 03:16 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Originally Posted By: drtyler
Maybe, maybe not.
Those enclosed drive lines were also the pits.Haven't heard a Blue Flame six rattling for years. One barrel carb and 6.5 compression, hottest thing in town.
Re: 1952 Chevy DeLuxe - Radiator cap rated 16 pounds? [Re: Yah-Tah-Hey] #4527094
09/26/17 07:37 PM
09/26/17 07:37 PM
Western S.C.
CR94 Online content
CR94  Online Content
Western S.C.
... If it's a 3 speed, the original engine is a 216. It's possible that the engine may have been changed out to a 235 in the past 65 years.
My parents had 3 of those, a'54 car (which I eventually inherited), '55 pickup, and '61 car. Never a problem with the "enclosed drive line" of the '54. The '54 235 was rated 115 gross hp, as I recall; the Powerglide version had hydraulic lifters and was rated a bit higher. The '61 was up to 135 claimed hp, but felt much more sluggish than the '54, due to greater weight and gearing that wasn't as short.
2011 Toyota Prius now at 94K
