Fireworks Stores
by Warstud
5 minutes 30 seconds ago
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
14 minutes 56 seconds ago
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
23 minutes 49 seconds ago
How Fast to Run a ZeroTurn Mower
by Gebo
31 minutes 38 seconds ago
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
52 minutes 13 seconds ago
My FIL in hospice
by fdcg27
Today at 08:41 PM
Spraying Polyurethane
by Texican
Today at 08:37 PM
Dehumidifier icing
by Kestas
Today at 08:37 PM
Diesel lube in Petrol Engine
by Ducked
Today at 07:46 PM
New key programming cost
by 92saturnsl2
Today at 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
Today at 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
Today at 07:08 PM
Wheel says 50 mph max
by pda1122
Today at 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
Today at 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
Today at 06:36 PM
Old Engine SOUND
by MasterSolenoid
Today at 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
Today at 04:54 PM
go green or Dexcool?
by umungus1122
Today at 04:50 PM
Latest info on ExxonMobil synthetic base stocks
by Gokhan
Today at 04:49 PM
Pennzoil Platinum 5w30 - $3.21/qt Amazon
by SnowmanCO
Today at 04:37 PM
bcj, Ilia, nmac9, Theraven, battleman13
65279 Registered Users
111 registered (01rangerxl, 4WD, 87sammy, 97f150, 2003f7, 16 invisible), 1434 Guests and 57 Spiders online.
65279 Members
67 Forums
285679 Topics
Page 1 of 3 1 2 3 >
#4524661 - 09/24/17 09:49 AM Frozen "coolant" advice
alexanderfitu Offline
Loc: London
Hi all
I have a Kubota D722 that was supplied with water in the cooling system rather than coolant!
The engine sat on its delivery pallet for a year and we had cold weather (-6 deg c) for a month or so.
I believe the engine was only half full of water but it still did some damage. It popped one core plug out and cracked the thermostat housing. As its a cast iron engine, I ran it up to temp today to see if I could see any issues. Apart from the leaking thermostat housing, it ran fine. I drained the oil and it has no coolant in it. I had to pull the head off to replace the thermostat housing and found some marks that concern me.
This engine has 0 hours on it and is new apart from some idling. There are these marks on the front and back of the bore:
This mark is slightly above the core plug that popped out:
The engine runs fine and has good compression. Thoughts on what I should do?
#4524664 - 09/24/17 09:54 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
OVERKILL Offline
Loc: Ontario, Canada
Looks like the bores got a bit rusty while it sat, and that's now coming off quicker on the loaded side. I wouldn't worry about it, just run it unless you want to re-hone the cylinders and put new rings in it.
2016 Durango Limited
2016 Grand Cherokee SRT
#4524668 - 09/24/17 10:00 AM Re: Frozen "coolant" advice [Re: OVERKILL]
2015_PSD Offline
Loc: SE Texas
Agree; though if it were mine, I would probably do two short OCIs on the oil to dump the extra wear metals that will likely be generated from the rust.
2018 MB AMG GLC43 3.0L Coupe - M1 0W-40/OEM
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 5W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4524675 - 09/24/17 10:06 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
tcp71 Offline
Loc: Alberta
Is that a crack in the liner in the second picture?
#4524677 - 09/24/17 10:08 AM Re: Frozen "coolant" advice [Re: tcp71]
Chris142 Offline
Loc: Deplorable in apple valley, ca
looks like it to me.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4524680 - 09/24/17 10:13 AM Re: Frozen "coolant" advice [Re: tcp71]
OVERKILL Offline
Hard to tell, even zoomed in. It may just be a rust line from where the piston was parked, or it could, as you've noted, be a crack. If it is a crack, the engine is scrap, so hopefully it is just rust. The OP could try rubbing it clean with some oil on a rag.
#4524687 - 09/24/17 10:20 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
Loc: London
Thanks for the quick replies!
Yes the second picture is the one I am worried about. That mark is opposite the core plug that popped out. Rubbing it with clean oil does not change its appearance. I cannot feel the mark at all.
This engine is designed to have liners replace, so I suppose I could get somebody to put some new liners into it?
#4524688 - 09/24/17 10:24 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
Kuato Offline
Loc: Colorado
Sounds like a warranty claim with your supplier!
Thick vs Thin test: 15k / 43k miles complete
#4524689 - 09/24/17 10:25 AM Re: Frozen "coolant" advice [Re: Kuato]
Loc: London
Ugh, engine was supplied 2 years ago and they have long since gone bust!
#4524701 - 09/24/17 10:35 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
OVERKILL Offline
What if you hit it with a piece of scotchbrite?
#4524712 - 09/24/17 10:44 AM Re: Frozen "coolant" advice [Re: OVERKILL]
Loc: London
No change, unfortunately.
#4524719 - 09/24/17 10:53 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
OVERKILL Offline
That's concerning, because generally if it is rust, you'll be able to change its appearance. A crack on the other hand.... you won't.
#4524722 - 09/24/17 10:53 AM Re: Frozen "coolant" advice [Re: OVERKILL]
Loc: London
ahh, I see!
I think this is a crack. Its location opposite the core plug is not coincidental I believe.
#4524723 - 09/24/17 10:54 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
WyrTwister Offline
Loc: Texas
Would it be definitive if you had it magnafluxed ?
Best wishes , :-)
Wyr
God bless
#4524727 - 09/24/17 10:57 AM Re: Frozen "coolant" advice [Re: alexanderfitu]
OVERKILL Offline
ahh, I see!
Then you'll likely need to get that liner, but preferably all of them, replaced. As if that one has experienced damage from the freeze event, the odds of the others being out-of-round is higher. I would not expect a huge price difference to do them all but I could be wrong, LOL
Page 1 of 3 1 2 3 >
