Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
low water pressure on new kitchen faucet
by Joe1
06/22/18 09:40 AM
Flashing third tail light
by Brigadier
06/22/18 08:59 AM
Intermittent AC Cooling
by Gebo
06/22/18 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
06/22/18 08:45 AM
Crude and foul behavior
by mjoekingz28
06/22/18 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
06/22/18 08:30 AM
Wrecking Yards
by Snagglefoot
06/22/18 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
06/22/18 08:14 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
86 registered (Astro14, Atesz792, Al, andyd, 92saturnsl2, 11 invisible), 1551 Guests and 31 Spiders online.
65294 Members
67 Forums
285781 Topics
#4521168 - 09/20/17 11:32 AM Mobil1 TDT in 2008 ML320 CDI OM642 ?
DrewKeen Offline
Loc: Middle GA
What are the thoughts on doing this in GA? I figure the car will like a thicker viscosity in the heat here.
Is the main reason for the different spec from the I6 CDI the emissions equipment?
If so, would this oil be acceptable for an offroad only vehicle with this no longer attached?
#4524497 - 09/24/17 02:24 AM Re: Mobil1 TDT in 2008 ML320 CDI OM642 ? [Re: DrewKeen]
BobFout Offline
Loc: Indiana
If the information presented by Mobil is correct "your vehicle manufacturer recommends a 0W-30, 0W-40, 5W-30, 5W-40 or 5W-50 viscosity and oil that meets MB-Approval 228.51, MB-Approval 229.31, MB-Approval 229.51 or MB-Approval 229.52.", then an API HDEO like TDT is similar to specified oils (MB 228.51 - in terms of sulfated ash, important for DPF longevity) except ZDDP is slightly higher (than 229.31/229.51).
Unless it's under some kind of extended warranty, use away. Also consider Rotella or Delo 5w40. A good spec oil would be Valvoline Synpower 5w40.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#4524785 - 09/24/17 12:01 PM Re: Mobil1 TDT in 2008 ML320 CDI OM642 ? [Re: DrewKeen]
m37charlie Offline
Loc: Alaska
If emissions are deleted you can revert to 228.3, 228.5, 229.3/5 as per
http://bevo.mercedes-benz.com/d/d/en/Spec_223_2.pdf
Mobil 1 TDT is not MB-Approved but is equivalent to a 228.31 which is NOT recommended for a DPF equipped MB car diesel; just a DPF equipped MB heavy duty truck engine. It has too much ash for the small DPF on newer MB diesel cars.
Charlie
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
#4525373 - 09/25/17 01:48 AM Re: Mobil1 TDT in 2008 ML320 CDI OM642 ? [Re: DrewKeen]
edyvw Offline
Loc: Colorado Springs
Get Valvoline 5W40 MST that is available in NAPA for $5 when on sale. Meets MB 229.51.
13' BMW X5 35d (Mobil1 5W30 ESP+OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
