Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
84 registered (4WD, 87sammy, 2012AccentSE, andyd, AITG, Artem, 8 invisible), 1577 Guests and 36 Spiders online.
65262 Members
67 Forums
285515 Topics
#4518271 - 09/16/17 11:44 PM Engine pad heater
bigj_16 Online   content
Loc: Douglas County, Colorado
Anyone ever use the oil pan pad heaters by Wolverine or Kats? I have a plastic oil pan, but might try a smaller one somewhere else on the engine.
#4518282 - 09/17/17 12:33 AM Re: Engine pad heater [Re: bigj_16]
02SE Offline
Loc: The Canyons
I have block heaters on two of my vehicles. They replace a freeze plug in the block. They work well.
#4518317 - 09/17/17 05:25 AM Re: Engine pad heater [Re: bigj_16]
ArcticDriver Offline
Loc: USA
I prefer block heaters which contact coolant to be superior at heat transfer.
We only use the magnetic oilpan heaters on large equipment with large oil capacity in combination with block heaters.
Multiple Diesel and Gasoline vehicles
#4518332 - 09/17/17 06:05 AM Re: Engine pad heater [Re: bigj_16]
demarpaint Offline
Loc: NY
I have Wolverine oil pan heaters on both my Jeeps. They work quite well, they heat the oil from the lowest part of the engine, the oil pan. As the heat rises it heats up the block to a certain degree. They get the oil to operating temps in cold weather much faster than a block heater does. I also have block heaters, where a block heater shines is in getting heat to the cabin and defrosting windows. A combo of the two is the best possible thing you can do during extreme cold.
God Bless Our Troops
#4518362 - 09/17/17 07:21 AM Re: Engine pad heater [Re: bigj_16]
i_hate_autofraud Offline
Loc: Canada
Even is super cold weather, changing to full synthetic engine oil meant I didn't need a heater.
For a car or truck anyway.
For a really old cars/trucks that has cold weather starting/running problems including iffy carb setups,
then a block heater would help a lot.
On a contract years back at "Pryroil" they were working to cheapen out their block heaters
since a retailer said heaters that lasted 5 years was "too long" and they were shooting for
a useful life of just 3 years! Kinda made me mad!
#4518373 - 09/17/17 07:46 AM Re: Engine pad heater [Re: bigj_16]
bioburner Offline
Loc: Minnesota
I've not had much luck with the little pad heaters. Block heaters are the way to go if one can get to the block. My Xterra I couldn't see my way to get to where it was supposed to go. Put a lower hose heater on the Jeep TJ and worked well.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4518388 - 09/17/17 08:15 AM Re: Engine pad heater [Re: bigj_16]
bullwinkle Online   confused
Loc: Cincinnati, OH, USA
I have both on the F-450 in my sig, a Wolverine stick-on on the pan, and the factory block heater. The Wolverine allows me to run any grade oil I want in winter (currently straight 30) without worrying about whether the engine will start & starve for oil in temps below 0F., and the block heater helps the top end & heater warm up faster. I've even stashed my old 6A battery charger underhood & used a cube tap to power all 3 at once. Although, last winter, didn't even need it.
Edited by bullwinkle (09/17/17 08:16 AM)
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4518468 - 09/17/17 10:21 AM Re: Engine pad heater [Re: bigj_16]
HoosierJeeper Offline
Loc: WI
I have the factory one on my Liberty and it works well. Heats up a lot faster with it. It doesn't need it, but if it makes its life easier, why not?
Edited by HoosierJeeper (09/17/17 10:22 AM)
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
