Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
118 registered members (10WSmuckers, 2010Civic, -SyN-, 53' Stude, 16HC, 11 invisible), 1,808 guests, and 31 spiders.
Topics290,958
Posts4,853,292
Members66,062
Most Online3,590
Jan 24th, 2017
Better than no generator, generator. #4515854
09/14/17 07:42 AM
09/14/17 07:42 AM
Ozark Mountains
callbay Offline OP
callbay  Offline OP
Ozark Mountains
I bought one of these little dudes at Harbor Freight about six weeks ago. It was about $88 with a coupon. Regular price is $109. Coupons on line.
https://www.harborfreight.com/900-max-st...carb-63025.html
It's a little 2 cycle 700 watt 2 HP machine. I use it at my boat dock to power the air pump for a boat lift. I was not sure if it would handle the load or especially the start up amps but it does well. Bears down yes but no problems at all.
Only 38 pounds so easy to carry.
I broke it in with no load for 20 minutes and when I start it now, I warm it up with no load for five minutes and then cool down with no load for 3. I burn 32/1 since it operates at very high load (don't flame me for not using the 50/1 recommended) and I use full synthetic FD rated 2 cycle oil.
Very quiet and seems well made.
Much better than no generator when you need one. It's like what they say about a .25 caliber pistol. "It's better than throwing rocks".
Re: Better than no generator, generator. [Re: callbay] #4515879
09/14/17 08:07 AM
09/14/17 08:07 AM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
You will find that they only run 3600 rpm and will drip oil out of the muffler @ 32:1. I have over 300 hrs on mine and plan on 64:1 next time.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Better than no generator, generator. [Re: callbay] #4515881
09/14/17 08:11 AM
09/14/17 08:11 AM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Probably will make nice anchor too. They had these stacked like a block wall at the south TX flea markets and there were several being used to power various items to show that they were working. It will probably run well past anybody's expected life cycle.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: Better than no generator, generator. [Re: callbay] #4515894
09/14/17 08:32 AM
09/14/17 08:32 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
It might power a few lights while camping but not much more.
2015 Ford F250 w/Powerstroke
Re: Better than no generator, generator. [Re: callbay] #4515919
09/14/17 09:14 AM
09/14/17 09:14 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I never understood why people use more oil than recommended. I've worked on a number of these machines over the years where people did this.
Using a richer oil mixture than what is recommended can actually shorten the engine life. It often creates more carbon build-up which can break off and score the piston. Piston scoring on a 2 stroke engine means no compression, and it won't run or will only run very poorly. I have replaced numerous pistons/blocks because of this.
If you run a good name brand oil (I use Husqvarna semi-synthetic) and mix it at the proper ratio, you will not have any problems. Your engine will actually be cleaner inside as a result.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (33k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Better than no generator, generator. [Re: callbay] #4516013
09/14/17 10:43 AM
09/14/17 10:43 AM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
Not true on running rich oil mixtures. Hard carbon in these engines comes from running Boat oil in them. TCW3 oil.
Use a TC rated oil and you will have no problems.
I have run and tore down numerous two strokes and found that to be he case. I have also run 32:1 and 20:1 in small engines and had them last 20+ years without a teardown. Slobber out of the tailpipe is a good sign. Dry soot is bad.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Better than no generator, generator. [Re: callbay] #4516014
09/14/17 10:43 AM
09/14/17 10:43 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Heard many good things about them. Red, White, Blue, and Green they all seem to be about the same and will run up to 1000 watts without issue. Plenty of power for most tasks.
Re: Better than no generator, generator. [Re: callbay] #4516039
09/14/17 11:08 AM
09/14/17 11:08 AM
snowblind in TX
punisher Offline
punisher  Offline
snowblind in TX
For what they are it is hard to complain too much about them. I captured some wave forms on my scope from one of the older blue ones and posted it here last year. Nice when I need power on the farm to drive my dinky little air compressor, and listen to the old boombox during tractor maintenance.
Re: Better than no generator, generator. [Re: Donald] #4516041
09/14/17 11:10 AM
09/14/17 11:10 AM
Mine ran my moms oxygen generator and my refrigerator at the same time. It did labor when the compressor first came on but caught up quickly.
Re: Better than no generator, generator. [Re: callbay] #4516055
09/14/17 11:23 AM
09/14/17 11:23 AM
MA
AandPDan Online content
AandPDan  Online Content
MA
I've had one for 6 years. It ran for almost 5 days when we lost power during a snowstorm.
Still starts up and runs fine.
Re: Better than no generator, generator. [Re: callbay] #4516077
09/14/17 11:55 AM
09/14/17 11:55 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
700 Watts divided by 120 Volts = 5.8 Amps.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Better than no generator, generator. [Re: Chris142] #4516095
09/14/17 12:09 PM
09/14/17 12:09 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Not long ago I talked to a lawn care worker and they had one on their truck. He told me they use it on occasion when they need re-mote power for electric tools. He told me it does have a lot of hours on it and haven't had any problems.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Better than no generator, generator. [Re: Panzerman] #4516096
09/14/17 12:09 PM
09/14/17 12:09 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
+1
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Better than no generator, generator. [Re: CT8] #4516098
09/14/17 12:12 PM
09/14/17 12:12 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
+1
Is it possible that the guys who run extra oil in their 2 cycle engines are the same guys that run thicker than factory engine oil in their vehicles? Just askin.
M1 0-20 EP
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Better than no generator, generator. [Re: Panzerman] #4516116
09/14/17 12:42 PM
09/14/17 12:42 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I've never seen boat oil run in engines up here. It likely isn't as big of an issue if you run decent oil, but many of these engines had the cheapest oil possible.
I also had a guy running regular motor oil mixed with fuel...
