Actually a two stroke makes more HP with extra oil as has been proven many times, just Google it.
Another misconception I don't agree with is more oil changes your jetting. The jetting is fluid/ air mixture which happens to be gas but you don't add a third party with oil since the gas and oil are mixed going into the combustion chamber. The simple carb does not separate. It simply controls air to fluid spray and it's all a propellant at that point. Regardless when you get your jetting set to the oil ratio YOU like it's not going to lean out the motor because of a richer oil/ gas mix.
