Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
104 registered members (1978elcamino, 380SLbenz, 1WildPig, 2012AccentSE, ABerns, 2K2AcuraTL, 9 invisible), 2,149 guests, and 139 spiders.
Topics286,197
Posts4,904,022
Members67,576
Most Online2,967
Mar 10th, 2019
2004 BMW 325i heat and A/C blowing out of vents. #4509298
09/06/17 05:27 PM
09/06/17 05:27 PM
Specific Ocean
Kibitoshin Offline OP
Specific Ocean
Got to look at my aunts 04 BMW 325i with the complaint of poor A/C so the first thing I did was check the A/C pressures at a shop and A/C pressure is within spec. This car has the fully electronic climate control system so I tried fooling around with the controls to see if the vent door actuators are working and vent positioning is working. I tried adjusting the temp to 59F (max cold) or 95F (max heat) and the air coming out of the vents still feel lukewarm. Did some googling around and it might be the heater control valve failing or in the stuck open position (powered closed when car is running) so I might proceed with that fix considering BMW's poor cooling system design.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Kibitoshin] #4509301
09/06/17 05:28 PM
09/06/17 05:28 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
clamp off the heater hose. see if that helps.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Kibitoshin] #4509334
09/06/17 06:08 PM
09/06/17 06:08 PM
Great Lakes
Quattro Pete Offline
Great Lakes
On this vintage BMW, it could be the FSU (final stage unit), also known as blower resistor, or hedgehog...
https://www.youtube.com/watch?v=7_D-Ki_Kk2k
https://www.youtube.com/watch?v=tvVsftVT-BM
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Kibitoshin] #4509600
09/06/17 11:10 PM
09/06/17 11:10 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Sounds like a bad heater valve to me. I'd start there.
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Chris142] #4509614
09/06/17 11:47 PM
09/06/17 11:47 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Is that because the heater control valve is inline on the heater hose ?
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Merkava_4] #4509636
09/07/17 12:29 AM
09/07/17 12:29 AM
Specific Ocean
Specific Ocean
Yep. This is one of these cars that shut off coolant flow to the heater core if heat isn't needed. However I'm trying to find out if this car also uses a blend door to control the amount of heat/cold coming through the vents or it pulses the heater control valve to control heat.
After bringing the car in and pinching coolant flow to the heater core, drv. side blows kinda cold and not really cold on the passenger side vents. Returning coolant flow to heater core drv. side vent becomes warm and pass. side becomes hot so that indicates bad heater control valve. Since this car does not have a dual climate system and doesn't appear to use a heater blend door (pls. verify) it's all pointing to low refrigerant charge. The evaporator is making a loud hissing noise and other people who had the same issue pointed low refrig. charge. I'm having second thoughts with the first A/C pressure check and might bring it to my mechanic friend instead.
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Kibitoshin] #4509640
09/07/17 12:45 AM
09/07/17 12:45 AM
NorCal
Seventh Offline
Seventh  Offline
NorCal
The E46 uses a single water valve and heater core to provide
passenger compartment heat. The water valve is electrically pulsed
to control the flow of coolant through the heater core.
Temperature regulation is based on the following inputs:
-Temperature control switch setting
-Interior temperature sensor signal
-Ambient temperature signal
-Heater core temperature sensor signal
-Evaporator temperature signal
-Solar sensor input (if applicable)
Hissing expansion valve in the firewall does often indicate low charge.
Although the charge may be low, I stand by my previous statement that it needs a new heater valve. I've replaced probably a hundred of those over the years on E46/E38/E39 due to the same symptoms you're experiencing.
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Seventh] #4509642
09/07/17 12:59 AM
09/07/17 12:59 AM
Specific Ocean
Specific Ocean
I guess that confirms my observations. I've ordered a new heater control valve and will double check the refrig. charge with my friend.
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Kibitoshin] #4519912
09/19/17 12:28 AM
09/19/17 12:28 AM
Specific Ocean
Specific Ocean
Update:
Shop says they recovered .56lbs of refrigerant out of system which is supposed to hold 1.6lbs. They pulled vacuum and did not find vacuum loss so they added uv dye and fully charged the system and come back if it blows warm again. A/C blows ice cold and customer and I are very happy (even for an automatic BMWs are fun to drive!)
In my original post I said the first shop checked A/C pressure. I'm guessing it's not an accurate way to determine A/C performance or the amount of refrigerant in the system.
Re: 2004 BMW 325i heat and A/C blowing out of vents. [Re: Kibitoshin] #4520121
09/19/17 09:18 AM
09/19/17 09:18 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Originally Posted By: Kibitoshin
Update:
It is an accurate way to diagnose if you know what you are doing.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
