A/C was working just not very cold. Thinking it might be low or freon, I vacuumed the system for 2 hours, then charged from a half full tank. Sticker says it takes 26 oz but could only get 16 oz in before it wouldn't take any more. Next day I try to add another 10 oz but near the end, the high side pressure goes over 400, high speed fan kicks in and compressor starts cycling and pressure drops to about 300 and this keeps repeating. Low pressure seems high as well at 60-70 psi. Outside temp around 95. Vent temps warm. Does this seem like an airflow problem across the condenser? Expansion valve problem?
