64829 Members
68 Forums
282235 Topics
#4505240 - 09/02/17 09:48 AM
Mobil EP 5W-30, strange riding experience.
Loc: China
My Honda PCX scooter, with Mobil fs 0w-40, smooth as silk.
I changed to EP 5-30, rough, very discernable rough.
Is it normal? the scooter recommends 10W-30.
#4505508 - 09/02/17 02:01 PM
Re: Mobil EP 5W-30, strange riding experience.
[Re: dole]
Loc: MTL, CANADA
Give it time. My car usually is a bit louder right after an oil change but 1000-2000 kms in it quiets down.
2007 Corolla Red Pearl 155k miles PP 0w20 & ST 4967
#4505556 - 09/02/17 03:28 PM
[Re: dole]
Loc: Idaho
The Mobil 0W-40 is a far superior oil to the EP.
Artificial intelligence is no match for natural stupidity, we shall prevail
#4505914 - 09/02/17 11:50 PM
[Re: dole]
Loc: Texas
#4506010 - 09/03/17 08:01 AM
[Re: CT8]
Loc: Illinois
The Mobil 0W-40 is a far superior oil to the EP. In what way? Different for different engines, but superior? I don't think so.
2007 Ford Fusion 224,000 miles M1 0-20 EP 2017 Ford Fusion 47K M1 0-20 EP 10,000 mile OCIs on both engines M1 ATF and MC LV M1 10-30 in all OPE MC filters
#4506081 - 09/03/17 09:30 AM
[Re: tig1]
Loc: Ontario, Canada
The Mobil 0W-40 is a far superior oil to the EP. In what way? Different for different engines, but superior? I don't think so. I would have to agree with CT8 that, all things equal, the 0w-40 is a superior lube. This is due to the higher level of AW additives allowed by both the grade and the fact that it is a Euro oil, as well as the more difficult to obtain Euro approvals. Now, does that mean it is offers a tangible benefit in the OP's application? Probably not. But it is possible the different chemistry and blend characteristics have resulted in different acoustics.
2016 Durango Limited 2016 Grand Cherokee SRT
#4506107 - 09/03/17 09:49 AM
[Re: OVERKILL]
Loc: Kalifornia Kollective
The Mobil 0W-40 is a far superior oil to the EP. In what way? Different for different engines, but superior? I don't think so. I would have to agree with CT8 that, all things equal, the 0w-40 is a superior lube. This is due to the higher level of AW additives allowed by both the grade and the fact that it is a Euro oil, as well as the more difficult to obtain Euro approvals. Now, does that mean it is offers a tangible benefit in the OP's application? Probably not. But it is possible the different chemistry and blend characteristics have resulted in different acoustics. Bingo
#4506152 - 09/03/17 10:43 AM
[Re: FZ1]
Loc: Texas
P.S. It's a Scooter. It needs thicker low end 10w-20w. That's the problem.
#4506156 - 09/03/17 10:49 AM
[Re: FZ1]
P.S. It's a Scooter. It needs thicker low end 10w-20w. That's the problem. What?
#4506352 - 09/03/17 02:55 PM
[Re: OVERKILL]
Loc: Texas
Needs a thicker oil on the low end to run more smoothly.
#4509511 - 09/06/17 09:15 PM
[Re: OVERKILL]
Loc: Illinois
The Mobil 0W-40 is a far superior oil to the EP. In what way? Different for different engines, but superior? I don't think so. I would have to agree with CT8 that, all things equal, the 0w-40 is a superior lube. This is due to the higher level of AW additives allowed by both the grade and the fact that it is a Euro oil, as well as the more difficult to obtain Euro approvals. Now, does that mean it is offers a tangible benefit in the OP's application? Probably not. But it is possible the different chemistry and blend characteristics have resulted in different acoustics. What I mean is if an engine calls for 0-20EP, then 0-40 may give inferior results to the 0-20EP. Same with an engine calling for 0-40. If you use 0-20EP you may have an inferior result with 0-20EP. It's not apples to apples.
#4509615 - 09/06/17 11:50 PM
[Re: OVERKILL]
Loc: Texas/International
"Acoustics" on my eBoost to date: (lowest Db on top)
M1 Formula M 5w40 M1 EP 5w30 PUP 5w30 M1 5w30
So the 40 has been the lowest noise ...
2017 Tahoe 5.3L 4WD 2014 Fusion Hybrid 2013 Cruze RS 1.4T 2010 Canyon 5.3L 4WD
