CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
52 registered members (Anthony, Billbert, A1O, bbhero, Bailes1992, 6 invisible), 662 guests, and 27 spiders.
Topics287,673
Posts4,932,031
Members67,838
Most Online2,967
Mar 10th, 2019
2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles #4503855
08/31/17 08:57 PM
08/31/17 08:57 PM
Austin, Texas
Brons2 Offline OP
Brons2  Offline OP
Austin, Texas
Oil: Dealer Bulk 5w20, in place when I bought car
Time of usage: 7 months, mileage:3233
Filtration: OEM
Usage: 50 mile round trip commute, some freeway speed, some stop and go.
Thoughts: Pretty happy with the wear metals but glad I changed it, don't want vis to go any lower on this engine than 8.0 as it has known weak connecting rod bearings.
Replaced with: M1 5w30, OEM filter.
2012 Hyundai Sonata GLS 6MT 2.4GDI, ProDS 10w30, XG9688 filter, 2018 Mitsubishi Outlander SEL 2.4 CVT, Factory fill still.
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Brons2] #4503867
08/31/17 09:10 PM
08/31/17 09:10 PM
WI.
dblshock Offline
dblshock  Offline
WI.
the bulk oil was doing good, M1 should go more than x3 though.
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Brons2] #4503879
08/31/17 09:19 PM
08/31/17 09:19 PM
VA
Thax Offline
Thax  Offline
VA
Good choice on the M1 5w-30 , dont go too long on the oil though. The Theta II engine will beat the snot out of oil, heavy fuel dilution. Go conservative with the oci on this engine.
2000 Ford Explorer Limited 5.0L AWD
2018 KIA Soul EX 2.0L
ASE P2 Parts Specialist
AIA Import Part Specialist
KIA certified Senior Technician, Hybrid certified.
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Thax] #4503882
08/31/17 09:20 PM
08/31/17 09:20 PM
Austin, Texas
Brons2 Offline OP
Brons2  Offline OP
Austin, Texas
That's the plan. I think 4000-4500 tops on the M1. We'll see where we're at then.
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Brons2] #4503901
08/31/17 09:51 PM
08/31/17 09:51 PM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
You'll be fine going 5K with any brand name synthetic. Anything less, a top shelf Conventional or Blend would do.
18 KIA Sportage 2.4 AWD
M1HM 10W-30, OE
13 Hyundai Santa Fe Sport 2.0T
PP EuroL 5W-30, OE
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Brons2] #4503939
08/31/17 11:44 PM
08/31/17 11:44 PM
Austin, Texas
Brons2 Offline OP
Brons2  Offline OP
Austin, Texas
I have 29 5 quart jugs of Chevron Havoline Pro DS in 5w20, 5w30 and 10w30 from the O'Reilly's clearance. The 5w20 will be going in my fiance's Dart, the 30 weights in the Sonata. I've had good results with Chevron oils in the past, I hope it's the same with this one because I have a metric ton of it.
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Brons2] #4504004
09/01/17 04:04 AM
09/01/17 04:04 AM
Virginia
bbhero Online sick
bbhero  Online Sick
Virginia
I could be wrong but I'd bet money this is Cam2 oil. Another member here had gotten dealer service and it was Cam2 there as well. It is actually quite good oil at the end of the day.
Nissan Altima 3.5 Coupe
Carquest Full synthetic HM 5w30 84356 Carquest blue
"Treat your family like your friends and treat your friends like your family."
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: Brons2] #4504133
09/01/17 08:11 AM
09/01/17 08:11 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
That dealer bulk did it's job, all wear numbers low and ample TBN left (3.7).
That's decent moly at 147 ppm. It may be dealer bulk but it looks like a good oil.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: 2012 Sonata 2.4, Dealer Bulk 5w20 3233 miles [Re: SR5] #4504155
09/01/17 08:30 AM
09/01/17 08:30 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
I agree, and as you mention, TBN condemnation levels appear to be many miles down the road. The, at temp, viscosity number at 8, after this 3300 mile run, for an XW20 oil that probably began somewhere in the 8s isn't a concern, in my opinion.
M1HM 10W-30, OE
PP EuroL 5W-30, OE
