Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
78 registered members (2002 Maxima SE, 2004tdigls, 92saturnsl2, 4WD, 4ever4d, 9 invisible), 2,072 guests, and 38 spiders.
Topics295,104
Posts4,927,860
Members66,688
Most Online2,553
Oct 27th, 2018
M1 5w30 HM or 0w40 European #4503668
08/31/17 05:19 PM
08/31/17 05:19 PM
Ga
Timmer Offline OP
Timmer  Offline OP
Ga
Hello all, I have a 2002 Chevy Silverado 1500 5.3 with 196,000 miles....No engine problems or leaks other than piston slap when cold....My question is M1 0w40 European a good choice for this high mileage truck or should I go with M1 5w30 HM...I live in Georgia so the summers get pretty hot but winters are mild with a few nights of freezing temps....I used to use German Castrol 0w30 but it's no longer available....I plan on driving this truck until the wheels fall off so I want to use the best oil to keep her going for as long as possible....I would appreciate you folks advice...As always thank you.....
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503682
08/31/17 05:31 PM
08/31/17 05:31 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
Since the engine has no leaks, I would be inclined to use the M1 0w40. Why do you want to change what is working now? Ed
CX5 Touring 2.5L :-)
Re: M1 5w30 HM or 0w40 European [Re: Eddie] #4503693
08/31/17 05:41 PM
08/31/17 05:41 PM
Ga
Timmer Offline OP
Timmer  Offline OP
Ga
I just wondered if the 0w40 European would be too thick and does it have a better add pack than 5w30 HM....I don't drive the truck hard and normally change oil and Wix Filters every 4500 to 5000 miles....I have read that the 0w40 is more like a thick 30w and since the truck doesn't have any leaks would the 0w40 European be a good choice for this high mileage motor....
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503699
08/31/17 05:43 PM
08/31/17 05:43 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
The 0w40 is going to be about the same thickness at temp as the euro 0w-30.
The M1 5w30 is HTHS 3.1 as it is an ILSAC lube. The 0W40 is HTHS 3.6
Another good option is M1 HM 10W30 HTHS 3.5
Anyway, the 5W30 might gain you some MPG. The 0W40 shears to a 30 quickly, which puts you back at 0w-30.
Either is fine for GA winter
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503701
08/31/17 05:45 PM
08/31/17 05:45 PM
Michigan
BobsArmory Offline
BobsArmory  Offline
Michigan
Castrol 0w-30 is available right now on Amazon
Keeping the forces of evil at bay
2016 Chevy Malibu LT 1.5 Liter Turbo
2017 Chevy Equinox LT 2.4 Liter
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503709
08/31/17 05:56 PM
08/31/17 05:56 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
Higher miles, warm climate (GA), a vehicle that calls for a 30 weight - I'd use the 10w-30 HM. Roughly the same HTHS as the 0w-40, but more "oil" and less VII's. You don't need to make the compromise for low temperatures inherent in running a 0w-XX oil. I used this oil in my dad's Express van with the same 5.3 LM7 with typically excellent results (for the oil; I use it in a number of vehicles).
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503778
08/31/17 06:45 PM
08/31/17 06:45 PM
Pennsylvania
Astro_Guy Offline
Astro_Guy  Offline
Pennsylvania
Mobil 1 5w30 is at the high end of the viscosity range for SAE 30, and Mobil 1 0w40 is at the low end of the viscosity range for SAE 40. The viscosity at 100C are 12.1 vs. 12.9 cSt. This is hardly worth worrying about.
From a more practical perspective, I switched the Volvo in my signature from the 5w30 HM to 0w40 more than two years ago. Not only is it still running at 215 K, but the fuel economy has actually improved. Go figure...
'01 Volvo V70XC, 232k, 0W-40 M1
'16 Accord, 21k, 0W-20 M1 EP
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503785
08/31/17 06:49 PM
08/31/17 06:49 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
why would the 0w-40 be too thick? As a matter of conversation what makes you wonder?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4503989
09/01/17 01:35 AM
09/01/17 01:35 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
If you like GC 0w-30, why not the Castrol 0w-40 A3/B4?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4504053
09/01/17 05:20 AM
09/01/17 05:20 AM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
I'm a long time user of Mobil 1 and others GIII/IV oils - but the 5.3L is the most durable and oil tolerant engine I have. If 40's don't bother you - I'm running Delvac Super at only 70k - it's 4.1 HTHS ...
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: M1 5w30 HM or 0w40 European [Re: Timmer] #4504099
09/01/17 06:33 AM
09/01/17 06:33 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
A friend had a 99 Silverado with 350K when sold. He used M1 5-30 at 15-18K OCIs. He only sold it because of the third trans that failed. The engine still ran very well.
2007 Ford Fusion 235,000 miles
M1 0-20 EP
2017 Ford Fusion 60K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: M1 5w30 HM or 0w40 European [Re: tig1] #4504387
09/01/17 11:26 AM
09/01/17 11:26 AM
Ga
Timmer Offline OP
Timmer  Offline OP
Ga
Thanks everyone, I think I'll stick with what has been working and stay with M1 5w30 HM since that's what the manual calls for and I'm sure the GM engineers are a lot smarter than I am.....thanks again guys......
