Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
80 registered members (Al, Astro14, Anduril, Alfred_B, 240_Ed, badduxx, 8 invisible), 1,944 guests, and 53 spiders.
Topics296,776
Posts4,958,680
Members66,969
Most Online2,577
Jan 14th, 2019
8 Gal Central Pneumatic issue with running #4500706
08/28/17 07:12 PM
08/28/17 07:12 PM
Buffalo, New York
JimmyJohns Offline OP
Buffalo, New York
2 topics in one day, I must be feeling frisky
In my garage lies an 8 gallon Central Pneumatic air compressor my brother bought, not my cup of tea but it gets the job done, I've done considerable work with it and I guess it's earned my respect.
Here is the issue I am having, after it runs and builds up air, and you let it sit for a few minutes without it needing to rebuild air pressure, and then you DO use a tool requiring it to kick on, it will try to run, sputter, die, and trip its little reset button.
If you constantly use a tool, no issue, if it kicks off for a minute or two, no issue, but any longer then you HAVE to drain ALL of the air out of the tank, reset it, and switch it back on.
Any idea what it may be? I wanted to ask before I started taking it apart because it's really getting on my nerves
Re: 8 Gal Central Pneumatic issue with running [Re: JimmyJohns] #4500739
08/28/17 07:42 PM
08/28/17 07:42 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Could be a bad head bleeder not taking the pressure off the compressor head to allow the compressor to start without a load. This little compressor a piston job or a direct drive?
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: 8 Gal Central Pneumatic issue with running [Re: JimmyJohns] #4500748
08/28/17 07:58 PM
08/28/17 07:58 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Are you using an extension cord with it?
Re: 8 Gal Central Pneumatic issue with running [Re: JimmyJohns] #4500763
08/28/17 08:06 PM
08/28/17 08:06 PM
Buffalo, New York
Buffalo, New York
HF's website says its direct drive, and yes I am using an extension cord with it. As stupid as it may sound, I've tried various outlets and cords, and let a friend borrow it and they had the same issue
Re: 8 Gal Central Pneumatic issue with running [Re: JimmyJohns] #4500813
08/28/17 09:09 PM
08/28/17 09:09 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
It happened to mine although it is not an HF compressor.
There is a release/bleeder valve, I tried to disassemble it but I cannot get it to loosen up so I spray some lubricant.
I put all the hose/tube back and run it and it was back to normal.
Apparently the valve is stuck or something.
You may try to do that and see.
The valve is where the tube that goes to the compressor and a small hose are connected into it.
  • 2017 Toyota Sienna
Re: 8 Gal Central Pneumatic issue with running [Re: JimmyJohns] #4500935
08/29/17 01:27 AM
08/29/17 01:27 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
The little unloader isn't unloading the air pressure...
or the check valve is still letting air reach the piston....
or the start capacitor is bad
The INSTANT it shuts off, if you don't hear a brief "PSSSHT" near the check valve, then it's not bleeding off.
Does this model use a small 1/4" plastic line from the check valve to the switch control box?
Re: 8 Gal Central Pneumatic issue with running [Re: JimmyJohns] #4501145
08/29/17 08:57 AM
08/29/17 08:57 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Yes , I would also say it is starting against high head pressure .
You can have a similar issue with HVAC compressors , if you play with the tstat , rapidly turning it off & on .
In " normal " operation the pressure equalizes through the metering device & evaporator coil . You can put a 5 minute time delay in the condenser control circuit to solve this problem .
Probably not applicable on your air compressor .
Wyr
God bless
