Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
74 registered (87sammy, 04SE, 2004tdigls, 2015_PSD, 8 invisible), 1409 Guests and 47 Spiders online.
65303 Members
67 Forums
285897 Topics
#4498704 - 08/26/17 01:31 PM Idle randomly dipping
mclasser Offline
Loc: The Northeast
This is in my Pilot.
90% of the time, the car idles at a solid 750 RPM at a traffic light with all accessories off. But the other 10%, the idle dips to like 600-650. When this happens, the engine makes a rumbling noise and you can feel the center console shake a little. BUT...turn on the headlights or A/C, the idle rises and everything smooths out again. It's strange that this happens intermittently. Car drives great otherwise.
Any ideas what could be going on?
2018 Hyundai Elantra VE -- 3K
2013 Honda Pilot EX-L 4WD -- 55K
2002 Honda Accord EX-L -- 210K
#4498794 - 08/26/17 03:57 PM Re: Idle randomly dipping [Re: mclasser]
bioburner Offline
Loc: Minnesota
Maybe the 5 year old battery is starting to fail and the alternator is having to engage more to keep the system at 13 or so volts.
Many cars the AC system still exercises to keep seals good even with the switches off.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
#4498800 - 08/26/17 04:06 PM Re: Idle randomly dipping [Re: bioburner]
mclasser Offline
Loc: The Northeast
Battery was replaced earlier this year; connections are all clean & tight.
In addition:
- All fluids are clean & full.
- I mainly use BJ's gas but fill up at Top Tier stations every 3rd tank or so to keep things clean.
- Inspected the air filter. It's 25k miles old but light still shines through; manual says to change every 30k.
I'm thinking about cleaning the MAF sensor & TB. I don't expect them to be dirty at only 45k miles but maybe it'll make a difference.
#4498840 - 08/26/17 05:19 PM Re: Idle randomly dipping [Re: mclasser]
gathermewool Offline
My Civic will idle rough (haven't heckled RPM) after being fully warmed up and at higher ambient temps. This seems to coincide with the ELD sensing low electrical load and lowering supply voltage to 12.6 or so.
Turning even just the running lights on (all but headlights on) will raise the voltage to normal. The vibration doesn't go away completely (likely something else is the root cause of that) but the the vibrations do lessen.
#4498855 - 08/26/17 05:39 PM Re: Idle randomly dipping [Re: mclasser]
JamesBond Offline
Loc: midwest
Maybe it's the cooling fans or ac kicking on. Try cleaning the throttle body.
#4498965 - 08/26/17 08:49 PM Re: Idle randomly dipping [Re: mclasser]
FordBroncoVWJeta Offline
Loc: KS
Might be time for a new intake sensor.
17 Volkswagen Jetta 1.4T
15 Honda CRV 2.4
12 Volkswagen Jetta 2.0
01 Pontiac Sunfire 2.2
#4498990 - 08/26/17 09:33 PM Re: Idle randomly dipping [Re: mclasser]
ATex7239 Offline
Loc: Texas,USA
Go get the battery, alternator, voltage reg, etc. checked anyways. Sometimes you get a bad battery. Autozone with do it for free.
I've had bad or fouling plugs give me a rough idle, as well. Might be good idea to check those out and test the coil packs.
'12 Buick Enclave 139,xxx
Valvoline ML SynBlend 5w30
ACDelco PF63E
'17 Ford Fusion (Company Lease) 42,xxx
Oil Don't know
Filter Don't care
#4501727 - 08/29/17 08:42 PM Re: Idle randomly dipping [Re: mclasser]
4ever4d Offline
Loc: North Carolina
Check the IAC valve. They will get dirty and cause idle issues. Throttle body cleaning will sometimes cause this problem also.
04 Chevy Colorado 3.5 I5 5w-30 OEF
07 Honda Element 2.4 I4 5w-20 OEM
10 Nissan Rogue AWD 2.5 I4 5w-30 OEF
Amsoil Products & Fram or Wix Filters
