Brilliant payback for package thieves
by SirTanon. 12/18/18 01:22 PM
Calling all Ford Owners
by dogememe. 12/18/18 01:01 PM
2003 Ford CVPI, 86kmi, 6kmi on Edge HM Ti 5W30
by Colt45ws. 12/18/18 12:35 PM
2017 Kia Sportage recall notice
by SlavaB. 12/18/18 12:26 PM
My VW Service Experience
by Delta. 12/18/18 11:36 AM
Nissan high idle, P0507
by LeakySeals. 12/18/18 11:23 AM
Should i go for even thinner fluid ?
by NICAT. 12/18/18 11:06 AM
Viscosity question
by dbierman. 12/18/18 10:50 AM
48 hours and a used car
by Imp4. 12/18/18 09:32 AM
Test driving PHEV w no battery charge
by RichardS. 12/18/18 09:02 AM
2005 Ford PSD with hard shifts when cold?
by racin4ds. 12/18/18 08:08 AM
18% off Ravenol + EVERYTHING @ Blauparts.com
by CleverUserName. 12/18/18 07:48 AM
Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
MuhThugga, wxo, dbierman, keyblade, leeal
66716 Registered Users
85 registered members (5azzmonkey, 2K2AcuraTL, 1WildPig, andyd, AdditiveOCD, 11 invisible), 2,207 guests, and 40 spiders.
Topics295,224
Posts4,930,443
Members66,716
Most Online2,553
Oct 27th, 2018
2008 Honda Civic Automatic Tranmission #4497555
08/25/17 07:11 AM
08/25/17 07:11 AM
VA
maverickfhs Offline OP
VA
SO I test drove a 2008 Honda Civic LX yesterday, it was vibrating around 14-16mph(like slight shaking). I noticed it around 2 times at the similar speeds.
ATF fluid looked a bit dark, couldn't really tell since it was bit late.
Question is, what would it be? Can a simple drain/refill of ATF 2-3 times cure the problem or it'll be something major?
Never noticed anything at highway speeds or any other ones.
Owner said ATF has been replaced, but he doesn't know about kind of fluid, since it was done at a shop.
Any thoughts or opinions from experts smile Thanks
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497566
08/25/17 07:19 AM
08/25/17 07:19 AM
NC
Vladiator Offline
Vladiator  Offline
NC
I got a 2010 Civic sedan. Had vibration at 55-60 mph zone. Replaced the CV axle and that eliminated the vibration. I think you have a mechanical issue there. If fluid was at fault - it would probably slip at certain engine speeds, not vehicle speeds.
Re: 2008 Honda Civic Automatic Tranmission [Re: Vladiator] #4497570
08/25/17 07:22 AM
08/25/17 07:22 AM
VA
VA
Thanks, how many miles and did you notice any other symptoms for a bad CV axle? Like any slow speeds shake or anything?
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497580
08/25/17 07:34 AM
08/25/17 07:34 AM
San Diego, California
Jim_Truett Offline
Jim_Truett  Offline
How many miles on the car? Sounds like a bad inner CV joint to me.
2008 F250 6.4 PowerStroke 49k
2005 Honda Pilot 248k
1963 Nova SS 84k
2015 Civic Si 32k
2013 Mahindra 3016HST 99hrs
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497582
08/25/17 07:36 AM
08/25/17 07:36 AM
VA
VA
It has nearly 155k miles.
Re: 2008 Honda Civic Automatic Tranmission [Re: Jim_Truett] #4497586
08/25/17 07:40 AM
08/25/17 07:40 AM
VA
VA
So it means whole CV axle needs to be replaced and nothing major? Like nothing could be possibly wrong with transmission or something?
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497620
08/25/17 08:40 AM
08/25/17 08:40 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
I wouldn't buy that car. Sounds like the owner is trying to get rid of a problem. There is no shortage of civics around.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497629
08/25/17 08:54 AM
08/25/17 08:54 AM
Tennessee
ChevyMan93 Offline
ChevyMan93  Offline
Tennessee
Take it to a mechanic for a diagnostic. Theyll charge roughly $100. Either you find out the problems with the car ahead of time, and it is acceptable, or you spend the $100 and save yourself from possibly thousands in repairs. Id rather spend $100 and KNOW rather than speculate and possibly be out of much more money. Or do as 2010Civic said, and avoid the car altogether. Does sound like a CV axle issue to me though, although hard to speculate through a computer.
2016 Chevrolet Silverado Z71 5.3
2017 Honda CR-V 2.4
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497635
08/25/17 09:04 AM
08/25/17 09:04 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
I'd agree with the CV axle post.
Trans fluid usually won't cause a vibration like that. It may impact shifts and produce a faint whine in different gears, but not a vibration.
If the fluid is dark I'd also question if it was really changed. I changed the fluid on a friend's 2007 Civic which had original fluid at 130k miles. It was a dark red when it came out, but on the dip stick it wasn't too dark.
2006-2008 were also the years that had the cracking engine block problem. Not very common, and Honda offered a recall until 10 years or so, but a problem if it happens to you and you are outside the recall time period. Honestly I'd look for a 2009-2011 for one of those Civics.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497643
08/25/17 09:16 AM
08/25/17 09:16 AM
VA
VA
Thanks guys for your valuable input. We have put down a deposit for the car already last night.
Yeah, I have a 2006 and I am well aware of cracking engine block. I thought it was fixed for 2008 and onward since it was most prominent on 2006/2007 models.
Just curious, how much does it cost to replace the CV axle?
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497657
08/25/17 09:35 AM
08/25/17 09:35 AM
Minnesota
2010Civic Offline
2010Civic  Offline
Minnesota
The cracking block was fixed in the beginning of 2009. So some of the 2009's are affected.
I would guess a shop would charge you a few hundred for labor and $100-200 for the axle itself. For each side.
I've replaced a few cv axles on this generation civic and it isn't too bad but not the most fun thing ever.
2010 Honda Civic LX
59,992 miles
Re: 2008 Honda Civic Automatic Tranmission [Re: 2010Civic] #4497661
08/25/17 09:42 AM
08/25/17 09:42 AM
VA
VA
That's not bad at all. Because of the deposit, we can be mentally prepared for a worst case scenario of it needing a CV axle.
We have done all front suspension components(ball joints, LCA, sway bar end links, outer tie rods), for a 2003 LX, might not be harder than that I guess?
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497668
08/25/17 09:51 AM
08/25/17 09:51 AM
Texas
FZ1 Offline
FZ1  Offline
Texas
Just walk away Rene. Something wrong with the car. Get your deposit back and never,never,never leave deposits on car purchases.
Re: 2008 Honda Civic Automatic Tranmission [Re: FZ1] #4497684
08/25/17 10:15 AM
08/25/17 10:15 AM
USA
ArcticDriver Offline
USA
Not sure why he needs to make a new plan Stan.
A slight vibration in a 9 year old Honda. No big deal.
Deposits on used cars are very common if you don't want the car to be sold while financing is arranged and the whole point of a deposit is to hold the vehicle. This buyer would not have a right to reclaim his deposit unless it was specifically stated in writing he had the right to refund for changing his mind.
Multiple Diesel and Gasoline vehicles
Re: 2008 Honda Civic Automatic Tranmission [Re: maverickfhs] #4497722
08/25/17 11:13 AM
08/25/17 11:13 AM
California
Kool1 Offline
Kool1  Offline
California
Hopefully your vibration is not due to an axle issue as axle issues can be a nightmare. Determining which axle is at fault is difficult. I've found normally with front wheel drive vehicles that the front axles will have problems 3-4 times more often than rear axles. If you narrow down the problem to front or rear axles, it will be a [censored] on the left or rear axle. In the event you change an axle, I would only use Genuine Honda rebuilt or Genuine Honda new axles as almost every aftermarket axle I've ever used has caused vibration or other issues which only complicate the matter further.
