Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
128 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,223 guests, and 63 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
2 Cycle oil / gas #4495398
08/22/17 04:58 PM
08/22/17 04:58 PM
Texas
WyrTwister Offline OP
Texas
What have you all seen happen if oil / gas is accidentally used in your standard flat head economy B&S lawn mower ?
Thanks , :-)
Wyr
God bless
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495408
08/22/17 05:02 PM
08/22/17 05:02 PM
Minnesota
bioburner Offline
bioburner  Offline
Minnesota
Use it all the time. Like to keep the gas fresh in the little 2 strokers so if the mix gets more than a month old it goes into the riding mower. No issues and same goes for the mixed outboard motor fuel.
97 Ford E350 D,99 F350 dually D
13 Scion Xb
12 Ford Transit Connect
06 Nissan Xterra
03 K1200 BMW
07 Kawasaki KLR650
13 Madass
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495423
08/22/17 05:24 PM
08/22/17 05:24 PM
USA
NHGUY Offline
NHGUY  Offline
USA
Those run on anything...even rubbing alcohol!
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495486
08/22/17 06:31 PM
08/22/17 06:31 PM
Central Coast California
RedOakRanch Offline
RedOakRanch  Offline
No worries many do it on purpose. I used to run 50/1 in a 4 stroke honda 70, no change in performance. I only did it because all my gas cans were mixed for chainsaws.
1994 Ford Crown Vic 207k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 180k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 60k-shop brand?
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495510
08/22/17 06:58 PM
08/22/17 06:58 PM
northwest pa
justintendo Offline
justintendo  Offline
northwest pa
no problems, if done too much you will get carbon buildup on everything. all over valves, plug, exhaust..a few times wont hurt.
2013 escape 2.0 awd mobil 1 10w30ep
2008 fusion 2.3 mtx redline 0w20
1996 f150 4.9 2wd mtx mobil 1 10w30hm
1999 kaw zrx 1100 redline 10w40
many husqvarnas
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495568
08/22/17 08:23 PM
08/22/17 08:23 PM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
I've done it for years, whenever I have extra 2-cycle gas lying around. I just put some Techron in it later to keep the carbon buildup away.
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495603
08/22/17 09:04 PM
08/22/17 09:04 PM
Flaherty, KY
92saturnsl2 Offline
92saturnsl2  Offline
Flaherty, KY
I do the same thing. If the 2-stroke mix is getting near end-of-season and I have nothing for it to go in, it gets used in the next piece of 4-stroke OPE I have to run before winter. I try not to run it full-strength, like half straight gas, half 2-stroke mix if I'm able. If there's still some left over, it goes in my 1985 Ford pickup which doesn't really care what goes in it, within reason.
1985 F-250HD 7.5L 4x4 135k- Castrol GTX 15w-40 HDEO
04 Odyssey EX 184k Valv. Durablend 5w-30
96 Maxima GLE 255k Castrol Edge EP 5w-20
07 Chrysler Pacifica Limited 4.0L 134k Chevron Supreme 5w-20
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495635
08/22/17 09:47 PM
08/22/17 09:47 PM
Port Orange, Florida
Panzerman Offline
Panzerman  Offline
The last construction company I worked we mixed all the gas for small equipment because we were afraid the workers would put straight gas in the saws.
Never had a issue with any of the Generators or pumps that were four strokes. Probably even good for them.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495735
08/23/17 12:03 AM
08/23/17 12:03 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Oil/gas mix doesn't seem to clog up the carb jets over winter.
Also will give the valves some extra lubrication.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: 2 Cycle oil / gas [Re: 92saturnsl2] #4495762
08/23/17 02:05 AM
08/23/17 02:05 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
+1
Nothing will happen....since almost all modern 2stroke oils are low ash or ashless technology....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: 2 Cycle oil / gas [Re: WyrTwister] #4495783
08/23/17 03:57 AM
08/23/17 03:57 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Worst case you foul the plug over time.
The "thinking" man's friend.
