CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
61 registered members (antik, 87sammy, Anthony, 2015_PSD, A1O, 7 invisible), 735 guests, and 27 spiders.
Topics287,674
Posts4,932,035
Members67,838
Most Online2,967
Mar 10th, 2019
DODGE power steering fluid CONFUSION #4481930
08/07/17 03:37 PM
08/07/17 03:37 PM
Upper Midwest by the Lakes USA
SumpChump Offline OP
My manual says ATF+4 (I was thinking of using maxlife but all my walmart has is SuperTech ATF+4) for my recently aquired 2005 Ram 1500 with about 100k miles.
Dodge dealer says that has been superceeded by a special Mopar PS fluid with specific aditives for Dodge PS units. Re-engineered basically in retrospect their Ps fluid.
What do you all think? Is the SuperTech ATF+4 good enough and has good additives or is the Mopar a must to prevent leaks starting from the cleaning effects of fresh fluid in there?
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4481965
08/07/17 04:13 PM
08/07/17 04:13 PM
USA
slacktide_bitog Offline
USA
The store brand ATF+4 will be just fine. Remember, it does carry official approval from Chrysler as a licensed ATF+4 smile
In fact, everything on Chrysler's official ATF+4 approved list is the same, since they require a specific group III base oil and a special Lubrizol add pack. So any licensed ATF+4 will work as intended, from cheap Walmart brand all the way to dealer ATF+4 (which is actually made by Valvoline AFAIK)
However, the absolute best ATF+4 to use, if you can afford it, is Red Line C+. Even though it's not licensed, it is a great product and better than what Chrysler will approve. Red Line C+ uses the same add pack as licensed ATF+4 but with a group V ester base stock, making it ineligible for official ATF+4 approval.
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4481977
08/07/17 04:23 PM
08/07/17 04:23 PM
MI
doitmyself Offline
doitmyself  Offline
MI
I wonder if the dealer was confused and was talking about the fluid developed for the Grand Cherokee circa 2005+.
See post #4 here: http://www.jeepforum.com/forum/f67/power-steering-fluid-question-1754010/
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4481990
08/07/17 04:42 PM
08/07/17 04:42 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Here's a relevant TSB, but it is over 10 years old: http://dodgeram.info/tsb/2005/19-008-05.htm
I have yet to find anything that recommends the MS-10838 Grand Cherokee fluid in Ram pickups. I would go to the dealer and ask them to show you their current fluid database.
Re: DODGE power steering fluid CONFUSION [Re: doitmyself] #4481999
08/07/17 04:51 PM
08/07/17 04:51 PM
So the parts "dude" had it wrong indeed. Or shall I say ...was mistaken. +4 is the one for the Ram.
I'll be turkey baster-ing so that shoul eliminate any air problems right?
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4482034
08/07/17 05:24 PM
08/07/17 05:24 PM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
I can't see you having any air issues. How hard is it to remove the return line? If it's too much of a pain, do a few drain and fills while cycling the wheel a few times in between.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4482054
08/07/17 05:50 PM
08/07/17 05:50 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
My 2012 Ram OM specs either Mopar Power Steering Fluid PSF+4 OR Mopar ATF+4 for the power steering. I'm currently running Havoline ATF+4 in both the power steering & transmission with no problems. I have some Super Tech ATF+4 in my stash as well, it's licensed so no worries. I used the turkey baster method on my power steering.
Although I can afford Redline C+, I use ATF+4 as I'm able to find licensed fluid for about $4 / qt. or less and I'm too skeptical to run any automatic transmission 100,000 miles or more between fluid changes. Since I change my truck's transmission fluid every 32,000 miles or so I personally don't see a great advantage for me to use C+. Licensed ATF+4 has performed well for me in ambient temperatures ranging from -19F to 105F.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4482118
08/07/17 07:05 PM
08/07/17 07:05 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
ATF+4.
Thick vs Thin test: 15k / 43k miles complete
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4482293
08/07/17 10:20 PM
08/07/17 10:20 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Forgive me for dissenting, but you don't even need ATF+4 ... or ATF at all apparently. Dodge isn't going to recommend Dexron or anything else as a LV PS fluid, they're going to recommend their own ATF spec just because it's their own. (Tip: ATFs have much more in common than they don't)
Most of the additives in ATF, let alone the ones in ATF+4 are useless at best in a simple hydraulic system. Don't take this as advice, it's not, but just something to consider after you pour the ATF+4 in.
There's no replacement...'scosity for natural viscosity
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4482301
08/07/17 10:33 PM
08/07/17 10:33 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
ATF+4 isn't a LV ATF BTW
I like a common fluid for transmission & power steering so I don't have a partial bottle of PSF sitting around my garage for long periods.
Re: DODGE power steering fluid CONFUSION [Re: Nyogtha] #4482700
08/08/17 12:45 PM
08/08/17 12:45 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Yes sir, that's why I said LV PS fluid wink
All ATFs are essentially high-VI, 'Low Vis' working fluids in a power steering system. IIRC this is why some systems call for ATF in the PS system for improved sub-zero performance. Now, synthetic PS fluids are quite common so ATF is no longer the only game in town for high VI performance.
Re: DODGE power steering fluid CONFUSION [Re: PeterPolyol] #4482850
08/08/17 03:30 PM
08/08/17 03:30 PM
Indiana
Indiana
Assuming the transmission takes ATF+4, I would like the convenience of only needing 1 type of fluid. I see your point though.
My best example is the New Progress/ New Venture transfer cases found on Chrysler and GM 4x4's that take either DexIII or ATF+4. Makes one wonder if either or could be used issue free assuming all the seals are functioning. On a side note, I wonder if the Mopar and GM fluids for the "AWD" transfer cases are interchangeable? Hmmm.
Re: DODGE power steering fluid CONFUSION [Re: SumpChump] #4482870
08/08/17 04:06 PM
08/08/17 04:06 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Is that really Dexron III?
Re: DODGE power steering fluid CONFUSION [Re: PeterPolyol] #4482920
08/08/17 05:28 PM
08/08/17 05:28 PM
Indiana
Indiana
I'm not sure what you're asking.
Re: DODGE power steering fluid CONFUSION [Re: PeterPolyol] #4482950
08/08/17 06:01 PM
08/08/17 06:01 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
Hmmm . . . I've never seen Mopar PSF+4 advertised or listed as a LV PSF, although this is the OEM alternative (and assumed Mopar PSF factory fill) in systems that can alternately use ATF+4 as PSF. Your classifications of LV PSF appear to be unique as it doesn't appear as either a design nor marketing description. Same applies to Ford systems that spec Mercon V for PSF.
