Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
OEM Brand Coolant by Rocochem
by NumbersGuy. 12/13/18 01:15 PM
Motomaster Dexron Vi Fully Synthetic
by Gannet167. 12/13/18 12:55 PM
Hacked
by Smoky14. 12/13/18 12:41 PM
Scanning for U codes.
by LeakySeals. 12/13/18 12:23 PM
Food photography trickery
by nthach. 12/13/18 11:29 AM
oil for 2.5 2013 vw passat?
by jstert. 12/13/18 09:47 AM
Scotty Kilmer Parody
by oilpsi2high. 12/13/18 09:41 AM
ID this old tool
by John_Conrad. 12/13/18 09:30 AM
Weak New CR2032/remote start + fob batteries
by redhat. 12/13/18 09:23 AM
WondrousBread, slickoo9, turntable_life, Poles19, HinaMach
66669 Registered Users
108 registered members (aquariuscsm, 28oz, Ag76, andyd, Astro14, 2K2AcuraTL, 10 invisible), 1,952 guests, and 38 spiders.
Topics295,032
Posts4,926,413
Members66,669
Most Online2,553
Oct 27th, 2018
Rotella ELC instead of GO5 #4481261
08/06/17 08:13 PM
08/06/17 08:13 PM
Texas
PumpPusher Offline OP
Texas
I need to change my water pump in my 06 Crown Vic and thinking it would be a good time to do a flush and fill. Any benefit or issues related to using Rotella ELC diesel coolant?
Re: Rotella ELC instead of GO5 [Re: PumpPusher] #4481290
08/06/17 08:36 PM
08/06/17 08:36 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Rotella ELC (red) uses a carboxylate inhibitor chemistry and is nitrated but silicate free. It's good stuff and should serve you well. I'm using the pee yellow Rotella Ultra ELC with molybdate inhibitor chemistry in an all-alloy gasser, no issues. Says it's compatible with other chemistries.
Rotella ELC brochure .pdf
http://s07.static-shell.com/content/dam/...ts-brochure.pdf
Scambling for solutions is a hopelessly futile endeavour and potentially dangerous, without first coming to a solid, personal understanding of the problem. Beware riding the ideological hobby horse.
Re: Rotella ELC instead of GO5 [Re: PumpPusher] #4481404
08/06/17 11:54 PM
08/06/17 11:54 PM
Texas
Texas
Thanks, I didn't realize there was a yellow ELC.
Re: Rotella ELC instead of GO5 [Re: PumpPusher] #4481434
08/07/17 02:09 AM
08/07/17 02:09 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
You can also get Rotella ELC NF from Advance which is Nitrite Free.
Benefits?
No silicates.
Higher oxidation state (less metal losses)
Issues? No.
I use ELC in almost everything.
Re: Rotella ELC instead of GO5 [Re: PumpPusher] #4481450
08/07/17 03:10 AM
08/07/17 03:10 AM
Texas
Texas
I should be able to switch after several flushes with distilled water, correct? I don't really want to go with an aggressive cleaner since I'm not sure what the history is on the cooling system.
Re: Rotella ELC instead of GO5 [Re: PumpPusher] #4481465
08/07/17 03:57 AM
08/07/17 03:57 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
No aggressive cleaner needed.
Re: Rotella ELC instead of GO5 [Re: PumpPusher] #4481466
08/07/17 04:03 AM
08/07/17 04:03 AM
Texas
Texas
Thanks.
