Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
110 registered members (53' Stude, 16HC, 99Eclipse, 97prizm, 92saturnsl2, 9 invisible), 1,793 guests, and 36 spiders.
Topics290,958
Posts4,853,282
Members66,062
Most Online3,590
Jan 24th, 2017
Page 1 of 5 1 2 5
Oil for WRX autocross #4480618
08/06/17 09:49 AM
08/06/17 09:49 AM
Pittsburgh, PA, United States
cmiovino Offline OP
cmiovino  Offline OP
I've been a Rotella T6 5w-40 user for the last 5 years. Paired it with a WIX/Napa gold filter with the proper bypass pressure. Car's been a daily driver for 4 of those years, with heavy autocross usage in the last 2-3. Now it's sits in the garage 6 days out of the week. 25-30 events per year. Turboback, exhaust, tune. Stock was 230 crank, now around 280. ~220whp. 2004 EJ20 to be exact.
I'm now out of the old Rotella. The switch to CK-4 concerns me as additives and such have changed and I see some people on here dislike it. The more and more I think about it, it is marketed as diesel oil.
This post was especially concerning:
http://www.chevelles.com/forums/13-performance/958417-rotella-ck4-warning.html
I'd like to change and narrowed it down to a few choices. Price isn't a huge issue, but I'm really looking for protection with 135k on the car. I would like to stick with a 40 weight. I only burn a hair of oil over 3-4k. I will be sticking with 3k mile changes as I only put about 6k on the car total, mostly racing and traveling to these races. I'm on 4k for this change, but there's some slight valvetrain tap when the oil is warming up. Goes away when hot and always with fresh oil.
1. Castrol Edge 0w-40
Seems likeable here. Hadn't really though of going down to a 0 weight. Any issues there? Priced at ~$25 per 5 quarts, this is actually cheaper than Rotella gallons and buying an extra quart. I see a lot of reviews for German cars, but nearly no one using this for Subarus.
2. Motul 8100 X-Cess 5w-40
Pricey, but only $38 on Amazon. I'd have to always order online and prices have been jumping up to even $50. Mostly positive reviews. for the price though, I could change with Castrol or Rotella twice. Appears to be a solid oil however.
3. Stick with Rotella 5w-40
Some have said Rotella is still godly and just use it, all oil is the same. Still concerned with the new standards for autox use or the long run.
I've batted around Liqui Moly and a few others, but that's my current list. Which would you go with for my application?
Re: Oil for WRX autocross [Re: cmiovino] #4480621
08/06/17 09:55 AM
08/06/17 09:55 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
What are your oil temps at these events? What kind of cooling system/upgrades do you have?
Re: Oil for WRX autocross [Re: Rand] #4480627
08/06/17 10:05 AM
08/06/17 10:05 AM
cmiovino Offline OP
cmiovino  Offline OP
The only cooling 'upgrades' I have have a new Koyo radiator and Samco silicone hoses. Fresh Subaru coolant. Stock intercooler.
Cooling has never been an issue. I do not have any additional gauges to report oil temp. I've never 'tracked' the car (ie road courses) and the autox events are only 45-60 second courses at most, but with much of that in the higher RPM range.
Re: Oil for WRX autocross [Re: cmiovino] #4480634
08/06/17 10:16 AM
08/06/17 10:16 AM
SF BAY AREA, CA
dogememe Online content
dogememe  Online Content
SF BAY AREA, CA
If you want to stick with 5w-40, you have options... Delo 400LE 5w-40, cheap and available. Castrol Edge 5w-40, frequently on sale at O'Reilly 5qts with Wix filter for like $34.
2007 Crown Vic P71 4.6 ~127K Miles, RP HPS 5W-30, RP 20-820, Daily Driver.
2010 Escape FWD 2.5 ~90K Miles, Castrol Edge EP 5W-30, Wix 51348, Rented on Turo.
Re: Oil for WRX autocross [Re: cmiovino] #4480637
08/06/17 10:20 AM
08/06/17 10:20 AM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
The Rotella CK-4 still has to protect HD diesel engines adequately.
Everytime there is an oil update tons of myths pop up.
For years we heard how the new Mobil 1 was terrible blah blah.
I would continue with the Rotella T6 for your usage out of the options you listed.
Maybe you could source a few old stock bottles and not worry about it for a couple more years if it bothers you.
Re: Oil for WRX autocross [Re: cmiovino] #4480643
08/06/17 10:25 AM
08/06/17 10:25 AM
Virginia
mattwithcats Offline
Virginia
Pennzoil Euro, 0W-40
Ran well for me,
Ignore the picture,
https://www.walmart.com/ip/Pennzoil-Platinum-Euro-0W-40-Motor-Oil-5-qt/163165881
Either that or Castrol Edge...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Oil for WRX autocross [Re: cmiovino] #4480652
08/06/17 10:36 AM
08/06/17 10:36 AM
Manchester, England
Olas Offline
Olas  Offline
Manchester, England
Anything that meets A3/B4 and A40 will be more than capable of protecting your EJ
Cable ties should hold it
Re: Oil for WRX autocross [Re: cmiovino] #4480705
08/06/17 11:40 AM
08/06/17 11:40 AM
MN
oil_film_movies Offline
MN
Originally Posted By: cmiovino
.... that's my current list. Which would you go with for my application?
Castrol Edge 0w40, but any 0w40 on the shelf at Walmart is good. They all meet a ton of tough specs. Generally 0w40 is too thick for most applications, but autocrossing might elevate oil temps a bit.
Re: Oil for WRX autocross [Re: cmiovino] #4480760
08/06/17 12:42 PM
08/06/17 12:42 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Keep using what you are using, I would say. In the WRX forums people usually go with Rotella
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: Oil for WRX autocross [Re: cmiovino] #4482430
08/08/17 07:32 AM
08/08/17 07:32 AM
NJ
bluesubie Offline
bluesubie  Offline
NJ
I would choose any 0W40 from Wal Mart because these oils meet the toughest specs in the industry, not because of internet fearmongering about the new RT6.
OTOH, for Auto-X I would also consider a high HTHS, thinner viscosity @ 100C, highly friction modified 5W30 like Red Line or Motul 300V. 5-6k mile intervals with either would be no problem IMO. With your short intervals, I would probably stick with a Wal Mart 0W40.
'04 Subaru Forester 2.5XT
Castrol Edge High Mileage
Re: Oil for WRX autocross [Re: dogememe] #4482833
08/08/17 03:04 PM
08/08/17 03:04 PM
Middle Florida
BufordTJustice Offline
Middle Florida
Delo 400 XLE 5w-40 also hasn't gone CK-4 yet...it's still CJ-4 with plenty of Zinc. Castrol Edge 0w-40 has the thickest KV100 and highest HTHS 3.5-3.6 of the current crop of walmart-available 0w-40's. My 911 ran much better on the Castrol 0w-40 than either M1 or PP Euro 0w-40.
1999 Porsche 911 Cab 3.4 6-speed -> Mobil Delvac-1 5w-40 ESP (CJ4) -> Fram Ultra XG3675
2011 Subaru Outback 3.6R -> M1 0w-40 FS -> Fram Ultra XG3593A
Re: Oil for WRX autocross [Re: cmiovino] #4484587
08/10/17 11:15 AM
08/10/17 11:15 AM
cmiovino Offline OP
cmiovino  Offline OP
I know the car runs well on 5w-40, but how different is 0w-40? General temp ranges of cold starts are from 40-60 degrees F the mornings of races, usually garage kept.
It's sounding more and more like I should go to this Castrol Edge 0w-40 for $25 and just keep it changed out every 2.5-3k... which is about 6-9 months for me. I talked with a guy on a built Subaru engine who races with us and he's running the 0w-30 version. States the 0w-40 is "too thick" for his engine's tolerences.
It appears the 0w-30 is a thicker 30 weight and the 0w-40 is a thinner 40 weight. Both within spec, but I don't see anything to justify more than double the price for the 0w-30 ($50/5 quarts), vs $25 for the 40.
Re: Oil for WRX autocross [Re: cmiovino] #4487149
08/13/17 09:08 AM
08/13/17 09:08 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I owned an 07' WRX I bought new and sold it with 136K on it. If you read older Subaru Owners manual, it will state the use of a heavier viscosity is required under
certain operating conditions.
I put a stage II Perrin downpipe and custom Perrin map on an AccessPort at 60K and did a 13.6 1/4 mile.
I never stuck with any one oil religiously, but used Valvoline 5W40 in it more than anything else. Any oil regardless of viscosity that meets the Porsche A40
spec will provide all the protection you need. Castrol 0W40 and Pennzoil 0W40 fits the bill cheap in 5 QT jugs at Wal-Mart and Pennzoil also makes a 5W40 Porsche approved A40 oil you can find at some Advanced Auto locations but it's not cheap. Castrol 0W30 and 0W40 is actually made in Belgium and digging into the MSDS indicates they contain a better base oil mix than the typical group III base oil used in most other synthetics.
Me: 13' VW GTI 3 door 6 speed manual
Re: Oil for WRX autocross [Re: cmiovino] #4487150
08/13/17 09:10 AM
08/13/17 09:10 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Re: Oil for WRX autocross [Re: cmiovino] #4487455
08/13/17 03:13 PM
08/13/17 03:13 PM
Chicago
danielLD Offline
danielLD  Offline
Chicago
Where is your UOA? You are guessing without proper data.
There are much better choices than the ones you listed. I would drop down to a 30 weight and pick a solid oil that matches your needs based on your data.. A 40 is only going to cause friction and more needless wear.
Page 1 of 5 1 2 5
