Zipcode error
by aquariuscsm
06/24/18 01:36 PM
NHRA drag racing Racing question??
by daddi
06/24/18 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
Buffer Pads
by TheLawnRanger
06/24/18 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
06/24/18 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
06/24/18 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
06/24/18 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
06/24/18 12:34 PM
Grit guard wash board
by JC1
06/24/18 12:22 PM
Truck Lug Nut Spikes
by ET16
06/24/18 12:12 PM
Tier III fuel is on the way
by ZZman
06/24/18 11:53 AM
ACDelco Dexos 0W20 UOA
by DanMiller
06/24/18 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
06/24/18 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
06/24/18 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
06/24/18 10:18 AM
What to do when your Glock jams
by bigj_16
06/24/18 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
92 registered (aquariuscsm, alphadog, AnthemBassMan, 330indy, BAJA_05, andyd, 7 invisible), 1611 Guests and 35 Spiders online.
65312 Members
67 Forums
285914 Topics
#4478072 - 08/03/17 09:48 AM Oil for 2003 VW Rialta/Eurovan V6 24V high miles
HalfmoonGH Offline
Loc: WY
All this oil talk is confusing to me. I want to find the best synthetic to use in my 2003 VW Rialta/Eurovan with 148K miles on it. I'm leaning towards 5w30 or 5w40 as those are the two VW recommended, but several folks say they use 10w40. Which brand of synthetic should I be considering for my VW engine? Thanks! I tried to search the form several times, but the dates searched thing was a mystery to me and I never got any results. If someone could explain how to use the search dates, I'd appreciate it.
#4478085 - 08/03/17 10:10 AM Re: Oil for 2003 VW Rialta/Eurovan V6 24V high miles [Re: HalfmoonGH]
drtyler Offline
Loc: GA
Castrol Edge 0W40, Mobil 1 0W40, or Pennzoil Platinum Euro 0W40. All are available at WalMart in 5 quart jugs for $22-$26, and all are rated for ACEA A3/B4 and VW 502/505 specs.
#4478115 - 08/03/17 11:03 AM Re: Oil for 2003 VW Rialta/Eurovan V6 24V high miles [Re: HalfmoonGH]
oil_film_movies Offline
Loc: MN
What drtyler above said. Any 0w40 you see on the shelf at Walmart (or Amazon) will work great. A Fram CH9461 oil filter is a good choice. Avoid Purolator oil filters (very bad reputation). Order a bottle of Liqui Moly Motor Oil Saver (amazon or napa) and use it at half-dose to keep the old seals flexible and avoid leaks.
Go to google to search this forum. At google.com, type in, for example the words: Castrol Edge 0w40 HTHS site:bobistheoilguy.com
Next step: on the google.com page, select "Tools" and then select "past month" for example.
Edited by oil_film_movies (08/03/17 11:11 AM)
#4478131 - 08/03/17 11:21 AM Re: Oil for 2003 VW Rialta/Eurovan V6 24V high miles [Re: HalfmoonGH]
Loc: MN
If you ever want to know what oil is recommended for your vehicle, and the Owner's Manual is out-of-date, you can always go to mobiloil.com, then select "Find the right oil", then put in the make, year, model, engine in and your recommendations show up.
Pennzoil and Castrol websites also make a recommendation like that.
#4478252 - 08/03/17 01:56 PM Re: Oil for 2003 VW Rialta/Eurovan V6 24V high miles [Re: HalfmoonGH]
homeyclaus Offline
Loc: Northern VA
If you just acquired the vehicle and it has an automatic transmission, look into getting a decent transmission cooler installed. Heat stress kills.
As far as oil goes, any XW40 euro-spec oil will be fine, and if you want to go with a euro-spec 5W30/0W30 in the winter that's fine too, but is not a requirement.
I just did an AXK VR6 whose #1 piston rod bearing pulverized. Cheap/bad oil + towing + poor maintenance. Fun times.
2013 Toyota Tundra CM 5.7L TRD (M1 0w20/PUP0w40euro, WIX/CQ filter)
2010 Mercedes E550 4Matic (PP 0W40 Euro, Mann)
#4478310 - 08/03/17 03:03 PM Re: Oil for 2003 VW Rialta/Eurovan V6 24V high miles [Re: HalfmoonGH]
edyvw Offline
Loc: Colorado Springs
Go to Wal Mart get Castrol 0W40 or Mobil1 0W40 FS.
My preference is Castrol 0W40.
Forget regular (ILSAC GF-5) 5W30 oils.
However, bottom line is that you can use ANY oil that meets VW 502.00 specification.
13' BMW X5 35d (Mobil1 5W30 ESP+OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
