Break in filter cut open/ Filtermag
by UncleDave
06/23/18 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
06/23/18 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
06/23/18 10:33 AM
Windows 10 Update, version 1803
by Sayjac
06/23/18 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
06/23/18 09:48 AM
Super Tech Conventional 15w40 HDEO. CK-4/SN
by Snagglefoot
06/23/18 09:38 AM
1 gallon jug of Sta-bil for $7 at Rural King
by classic70
06/23/18 09:34 AM
Anger on BITOG
by Gebo
06/23/18 08:55 AM
2010 Acura MDX w/ 3.7 lire oil consumption issue
by Varbill
06/23/18 08:45 AM
Surprising oil filter service interval.
by jakewells
06/23/18 08:12 AM
World Population
by CourierDriver
06/23/18 08:11 AM
SBC Finned Aluminum Dress Up Kit $32
by hatt
06/23/18 07:35 AM
Meguiars
by dslofti
06/23/18 07:20 AM
Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
85 registered (Bailes1992, ArrestMeRedZ, aquariuscsm, advocate, andyd, 330indy, 13 invisible), 1609 Guests and 37 Spiders online.
65299 Members
67 Forums
285842 Topics
Page 1 of 4 1 2 3 4 >
#4477791 - 08/02/17 09:00 PM Trumpet Oil for Pistol
Al Offline
Loc: Elizabethtown, Pa
The best brass valve oil is Ultrapure..period. Hey we could debate this too.
Anyway. I bought a couple needle oilers for both my horns and drum roll..why not guns? So far..so good.If the ultrapure were not so expensive I would use it in my vehicle.
What the hey..finally a thread that discusses oil.
#4477822 - 08/02/17 09:48 PM Re: Trumpet Oil for Pistol [Re: Al]
Superflop Offline
Loc: Seattle
Until we have a uoa of 40 to 50k depressions we really cant know. Plus we dont know what trumpet what valves and reed. Without that we cant reccomend an oil or oci. smile best to stick with oem.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
#4477827 - 08/02/17 09:59 PM Re: Trumpet Oil for Pistol [Re: Superflop]
CR94 Offline
Loc: Western S.C. since 1996
Originally Posted By: Superflop
... Plus we dont know what trumpet what valves and reed. ...
Reed? On a trumpet!?
2011 Toyota Prius now at 88K
#4477858 - 08/02/17 10:38 PM Re: Trumpet Oil for Pistol [Re: Al]
bsmithwins Offline
Loc: OR, USA
I'll take a stab at it:
1) Musical instrument oil is probably lacking in EP additives.
2) Oil designed for brass instruments is probably not going to have great corrosion protection abilities.
3) Gun oils need to be creepy to seep into assemblies and permanently joined parts.
4) Great gun oil can be bought for $40 a gallon...
BSW
#4477869 - 08/02/17 10:57 PM Re: Trumpet Oil for Pistol [Re: bsmithwins]
Linctex Offline
Loc: Waco, TX
The water content will be off the charts!
Mobil 1 doesn't cost that much, unless you are getting the new "Annual Protection" baloney
#4477874 - 08/02/17 11:06 PM Re: Trumpet Oil for Pistol [Re: Al]
AZjeff Offline
Loc: PV Az
Is it tested to not stain your shirt when you...... you know......
Any lube is better than no lube, some are just better than others.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP *gasp*
16 Silverado 1500 4.3 Ecotec3, DI, AFM 5W-30 PP
Why know when you can guess?!
#4477945 - 08/03/17 06:02 AM Re: Trumpet Oil for Pistol [Re: Linctex]
billt460 Online   content
Loc: Glendale, Arizona
That's what I was going to say. And unless you're a competition shooter, a quart of Mobil 1 will all but last a lifetime, if all you use it on is weapons.
#4477948 - 08/03/17 06:07 AM Re: Trumpet Oil for Pistol [Re: Al]
Another thing to consider is brass musical instruments have a human mouth applied to them in order to be played. That being the case, do these type of lubes fall under FDA guidelines as a, "Food Grade lubricant"? If so I'd walk away from it. Most food grade lubricants are plant ester based, and can spoil over time. We're seeing this all over the Internet with Frog Lube gumming up guns that have seen any appreciable storage time.
#4478080 - 08/03/17 10:04 AM Re: Trumpet Oil for Pistol [Re: Al]
Al Offline
I love the comments..keep em coming. I will see how many thousands of rounds the 42 lasts with this oil. Seems glocks can go many thousands of rounds without cleaning or oiling. So given I regularly clean and oil (every 4 or 500 rounds) I will still outlive me.
like the idea of a voa on the oil though.
#4478145 - 08/03/17 11:33 AM Re: Trumpet Oil for Pistol [Re: Al]
Linctex Offline
Loc: Waco, TX
Seems glocks can go many thousands of rounds without cleaning or oiling. ... It will still outlive me.
Have you seen the 100,000+ Glock Torture test?!?
#4478146 - 08/03/17 11:34 AM Re: Trumpet Oil for Pistol [Re: Al]
Linctex Offline
Loc: Waco, TX
#4478220 - 08/03/17 01:32 PM Re: Trumpet Oil for Pistol [Re: bsmithwins]
Triple_Se7en Offline
Loc: 1/2 hr. north of Detroit
BSW
I liked 1 thru 3.
Your #4 would be a waste because three ounces of oil lasts me two years. Only things I oil with handguns are the barrel lug and whatever moves in the trigger parts. The rest gets lightweight grease.
When you manually open your slide and run it back & forth a few times, if it ain't quiet sliding and it sounds a little like grinding, it's need grease, not oil.
A friend handed me his Glock26, after stating he just shot 200 at the range and now 500 rounds fired without cleaning / oiling. Planning on leaving the gun dirty for another range visit the very next week. I unloaded it and worked the slide. My wife could hear it 20 feet away, in the open door bathroom.
Not good care given to that Glock. Use oils and grease on a handgun that fit the task. Not something that fits a trumpet or something toxic and smelly that works the inside of your car engine.
Edited by Triple_Se7en (08/03/17 01:38 PM)
#4478277 - 08/03/17 02:23 PM Re: Trumpet Oil for Pistol [Re: Triple_Se7en]
And there are literally thousands of lubricants in that category. Most all of them don't require the word "Gun" to appear on the label anywhere to do the job.... Unless paying more is a prerequisite.
#4478308 - 08/03/17 03:03 PM Re: Trumpet Oil for Pistol [Re: Linctex]
There have been several range rental Glock's that have popped up every now and then, that have gone over the 1 MILLION round mark. And range rental guns do not receive the best care or lubrication.
#4478341 - 08/03/17 03:54 PM Re: Trumpet Oil for Pistol [Re: Al]
901Memphis Offline
Loc: Northern Kentucky
I don't think it would be designed for a high temperature application
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
