Nissen Radiator Warning.
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
141 registered members (01rangerxl, 4WD, 2015_PSD, 92saturnsl2, 02z, 928, 17 invisible), 2,017 guests, and 53 spiders.
Topics286,087
Posts4,902,326
Members67,560
Most Online2,967
Mar 10th, 2019
1983 Toyota Cressida -- higher pitched whine #4474880
07/30/17 06:22 PM
07/30/17 06:22 PM
Ontario, Canada
momo Offline OP
momo  Offline OP
Ontario, Canada
Hi all,
When I drove my car and speed was around 60, I noticed a pretty solid higher pitched whine coming from the rear of the car. The higher the speed, the higher the noise.
I did changed the fluid bur there is nothing change in term of the sound. Any suggestion?
'83 Toyota Cressida VWB 5w30 & Denso
'88 Cadillac Brougham d'Elegance VWB 5w30 & Wix gold
'15 Honda Odyssey Castrol Edge 0w20 & Proselect
Re: 1983 Toyota Cressida -- higher pitched whine [Re: momo] #4474886
07/30/17 06:30 PM
07/30/17 06:30 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
It is likely a wheel bearing, if I recall correctly the mx62 didn't have pressed in bearings the way the mx83 did so replacement should be a walk in the park
too many cars and oil combinations to list in 150 characters or less
Re: 1983 Toyota Cressida -- higher pitched whine [Re: momo] #4474890
07/30/17 06:34 PM
07/30/17 06:34 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Wheel bearing- yep
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: 1983 Toyota Cressida -- higher pitched whine [Re: L_Sludger] #4474894
07/30/17 06:38 PM
07/30/17 06:38 PM
Ontario, Canada
momo Offline OP
momo  Offline OP
Ontario, Canada
That's great!!
How you can be so sure??
Re: 1983 Toyota Cressida -- higher pitched whine [Re: momo] #4475326
07/31/17 08:49 AM
07/31/17 08:49 AM
Southeast
meep Offline
meep  Offline
Southeast
whine to me suggests the rear diff. Cressida of that era is RWD if I recall. I don't remember if its a solid axle or a independent rear suspension setup.
Needs to be checked for fluid, and potentially checked for pinion bearing R&R.
-m
2018 F150
2015 crv (wifey!)
Re: 1983 Toyota Cressida -- higher pitched whine [Re: momo] #4475354
07/31/17 09:13 AM
07/31/17 09:13 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Likely differential.
Care to upload the audio ?
Re: 1983 Toyota Cressida -- higher pitched whine [Re: momo] #4475510
07/31/17 12:07 PM
07/31/17 12:07 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
Check the ring gear and pinion backlash.
Re: 1983 Toyota Cressida -- higher pitched whine [Re: momo] #4475704
07/31/17 03:24 PM
07/31/17 03:24 PM
Ohio
L_Sludger Offline
L_Sludger  Offline
Ohio
That's great!!
All Cressidas until 1988 had the old fashioned rear wheel bearings that weren't sealed and needed periodic maintenance.
Source: I owned and ran the Internet's biggest Toyota Cressida website and forum for about seven years. Now defunct sadly. Was a nice community.
RockAuto shows a huge selection of wheel bearings for your car, for CHEAP!
If you do those wheel bearings and there's still noise, well, at least the wheel bearings are freshened up and you aren't out too much money.
Re: 1983 Toyota Cressida -- higher pitched whine [Re: L_Sludger] #4476483
08/01/17 12:29 PM
08/01/17 12:29 PM
California
nthach Offline
nthach  Offline
California
That's great!!
I'm pretty sure the MX63s didn't use tapered bearings in the back with IRS. My parents had one and we didn't touch the rear wheel bearings, I did with the fronts.
