Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
111 registered members (1978elcamino, Alfred_B, ABerns, Agnosto, 2015_PSD, 17 invisible), 2,431 guests, and 63 spiders.
Topics286,019
Posts4,900,954
Members67,548
Most Online2,967
Mar 10th, 2019
AC Delco Classic vs Professional Design #4474662
07/30/17 01:14 PM
07/30/17 01:14 PM
Texas
WyrTwister Offline OP
Texas
What is the difference ?
Thanks , :-)
Wyr
God bless
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474734
07/30/17 03:10 PM
07/30/17 03:10 PM
New England
Peter_480 Offline
Peter_480  Offline
New England
I don't use AC filters myself but I'll add a question - who is the OEM for them?
'10 Ford E250 4.6L
'11 Ford Fusion 2.5L
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474761
07/30/17 03:45 PM
07/30/17 03:45 PM
Massachusetts
CarlGR Offline
CarlGR  Offline
Massachusetts
From what i can find out it's Champion Filters (not connected with Champion Spark Plugs)
Carl
2013 Rav4 XLE
2017 Rogue Sport SV
M1 / Castrol Edge 0W-20
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474787
07/30/17 04:07 PM
07/30/17 04:07 PM
Virginia, USA
Tony10s Offline
Tony10s  Offline
Virginia, USA
Classic -- does not have the e-core center tube design; has a metal center tube
Professional -- has e-core design
Re: AC Delco Classic vs Professional Design [Re: Peter_480] #4474800
07/30/17 04:27 PM
07/30/17 04:27 PM
Texas
Texas
AC Delco is a GM brand . Who actually makes the AC Delco oil filters ? I do not know .
Wyr
God bless
Re: AC Delco Classic vs Professional Design [Re: Tony10s] #4474801
07/30/17 04:29 PM
07/30/17 04:29 PM
Texas
Texas
What is e-core & which of the two is to be preferred ?
Thanks , :-)
Wyr
God bless
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474809
07/30/17 04:35 PM
07/30/17 04:35 PM
MT
jongies3 Offline
jongies3  Offline
MT
Thanks , :-)
The metal center tube has a sturdier construction is the general idea around here and is less prone to cause catastrophic engine failure in the (unlikely) event the filter media blows apart and gets sucked back into the engine, blocking critical oil passages. GM trusts the e-cores as standard OE replacements in all their service departments so they must be okay. E-cores feature a plastic cage with large gaps in the tube for maximum oil flow and circulation. They're made by Champion Labs, and as long as they don't switch suppliers to Purolator, we shouldn't have to worry about the media failing on an e-core.
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
1969 Mustang Mach 1 5.8 V8: PYB 10W-30, Napa Gold 1515 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474810
07/30/17 04:38 PM
07/30/17 04:38 PM
Virginia, USA
Tony10s Offline
Tony10s  Offline
Virginia, USA
Thanks , :-)
E-core -- has "plastic" cage-like center tube design where the filter media is clearly visible (for spin-on filters)
Most people prefer the non-ecore design; that is, most prefer the spin-on filters with metal center tubes.
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474839
07/30/17 05:08 PM
07/30/17 05:08 PM
Toronto
PeterPolyol Offline
PeterPolyol  Offline
Toronto
Hey, about your question about larger filters for the SBC and 3800
Longer upgrades for those M18 filters:
Medium
PF51 AC Delco
PH51 Champ
PH3980 FRAM
and equivalents
Large
51036 Wix
PF52 Delco
PH3535 FRAM
and equivalents
The larger filters are less common than the medium and stock sized ones.
There's no replacement...'scosity for natural viscosity
Re: AC Delco Classic vs Professional Design [Re: PeterPolyol] #4474853
07/30/17 05:28 PM
07/30/17 05:28 PM
Texas
Texas
Thanks , :-)
Wyr
God bless
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4474940
07/30/17 07:24 PM
07/30/17 07:24 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Here is a virgin cut & post of an eCore.
AC Delco eCore cut & post
I have run the PF1250 to 6K without issues.
I have run the similarly constructed Champ PH820 without major issues to 3 to 5K. These were close outs and the nitrile combo valve started losing ADBV function in less than 3K miles.
The big thing is they don't collapse or tear like others we have seen.
The Classic uses a nitrile ADBV and separate bypass valve. I do not know if the Classic configuration solves the drain back issue or not. Most BITOGERs are more comfortable with the Classic design.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4475379
07/31/17 09:37 AM
07/31/17 09:37 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Personally I have always preferred the classic design. I used to be able to stock up on classics at rockauto.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Re: AC Delco Classic vs Professional Design [Re: WyrTwister] #4475909
07/31/17 07:34 PM
07/31/17 07:34 PM
CT
CrAlt Offline
CrAlt  Offline
CT
Ive run both classic and ecore. I have been cutting my filters open after use for a wile now and never seen a defect in either. But I only go 3K or 1 year (which ever comes 1st) so I can't comment on their extended OCI use.
I buy them in bulk from RA when they happen to be in the same warehouse as something else I am getting.
'16 Wrangler JK PYB 5w20 / MO 349
'77 Corvette JG HR2 10w30 / AC PF454
'83 Trans-Am JG HR2 10w30 / AC PF454
'91 Dodge D150 QSGB 10w40 / AC PF13
