Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
7 minutes 15 seconds ago
diesel oil in older engines- RE: cats etc
by 928
7 minutes 34 seconds ago
2011 F-150 Ecoboost timing chain replacement
by 14Accent
12 minutes 30 seconds ago
My stash of Kendall GT1 almost gone..
by Vern_in_IL
13 minutes 12 seconds ago
mobil 1 rebate check
by Fitter30
51 minutes 11 seconds ago
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
Extend wifi range
by clarkflower
Today at 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
Today at 01:57 PM
Lease Buyout by Dealer
by Throt
Today at 01:52 PM
13 Ford Escape
by RedOak
Today at 01:10 PM
New washer pump leaking fluid
by llmercll
Today at 12:17 PM
Fuel dilution and CCS/MRV viscosity
by doyall
Today at 12:10 PM
Door Hinges
by Scrum67
Today at 11:59 AM
PBS, TV channels in different countries
by onetwoothreee
Today at 11:29 AM
Break in filter cut open/ Filtermag
by UncleDave
Today at 10:36 AM
Changed coil pack, now throwing cat code
by llmercll
Today at 10:36 AM
07 V6 Mustang oil leak.
by aquariuscsm
Today at 10:33 AM
Windows 10 Update, version 1803
by Sayjac
Today at 09:55 AM
Super Tech Euro Spec Synthetic
by Snagglefoot
Today at 09:48 AM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
88 registered (2015_PSD, 928, 71Chevyguy, 1JZ_E46, 14Accent, 10 invisible), 1545 Guests and 46 Spiders online.
65303 Members
67 Forums
285863 Topics
#4470446 - 07/25/17 09:21 PM 06 lucerne 3,8
lucerne06 Offline
Loc: northeast
got a p300 code misfire on multiple clynders, car was running rough wanting to stall....replaced all three coil packs and a new ignition module....started car and it was still running rough and sluggish waited a few minutes then took it for a drive, starting running better, then nice and smooth.. But one weird thing happened after about a three miles drive, stopped at a light and when I went to go, it just stalled right out...had to pull over it just died...put it in park and it started right back up and I drove it home , idled it for another 10 min, drove another mile and it seemed fine...what does anyone think why it just died like that. ??
Edited by lucerne06 (07/25/17 09:22 PM)
#4470505 - 07/25/17 10:58 PM Re: 06 lucerne 3,8 [Re: lucerne06]
901Memphis Offline
Loc: Northern Kentucky
Sounds like you forgot to clear the codes before you installed the new parts?
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4470513 - 07/25/17 11:05 PM Re: 06 lucerne 3,8 [Re: lucerne06]
lucerne06 Offline
Loc: northeast
i actually installed the parts, then before starting cleared the codes, then started it...after it just stopped, no other codes presented..
#4470527 - 07/25/17 11:37 PM Re: 06 lucerne 3,8 [Re: lucerne06]
WhyMe Offline
Loc: Washington for now
#4470559 - 07/26/17 01:39 AM Re: 06 lucerne 3,8 [Re: lucerne06]
Merkava_4 Offline
Loc: Clovis, CA
There's shraeder valve right on the fuel rail for hooking up your fuel pressure gauge; see what your fuel pressure is; should be from 40 to 60 psi. If your fuel pressure is good and your spark is good, turn your attention to the crank sensor.
#4470584 - 07/26/17 04:37 AM Re: 06 lucerne 3,8 [Re: lucerne06]
Lubener Offline
Loc: N.Ohio
Probably because you didn't fix the problem.Happens frequently when one guesses at a problem instead of diagnosing it.
Edited by Lubener (07/26/17 04:38 AM)
The "thinking" man's friend.
#4470791 - 07/26/17 10:14 AM Re: 06 lucerne 3,8 [Re: lucerne06]
bigt61 Offline
Loc: Virginia
Could be a fuel pump on it's way out. Do as Merkava suggested above. Don't let it run low on fuel as that will kill a weak pump. Don't fill it up either as it's a lot to drain if you have to end up replacing the pump.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4471347 - 07/26/17 08:04 PM Re: 06 lucerne 3,8 [Re: lucerne06]
caravanmike Offline
Loc: ohio
Check the rear seat pdc, for the rear seat hitting the fuel pump relay. Well known tsb.
Oils I use: Any 5w-30,5w-20 conventional
#4471395 - 07/26/17 09:19 PM Re: 06 lucerne 3,8 [Re: caravanmike]
Hootbro Offline
Loc: DELAWARE
What he said.
https://www.youtube.com/watch?v=G4EkAd9B1uA
2018 Jeep Wrangler JL 3.6L (Idemitsu 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
#4471413 - 07/26/17 09:36 PM Re: 06 lucerne 3,8 [Re: lucerne06]
lucerne06 Offline
Loc: northeast
did find one thing today, my coolant resivor tank was about two inches low from its normal spot, I also found indications of coolant leaking from the gasket next to the alternator, same color as my coolant...thinking head gasket...no white smoke, no milky white in oil , no film in coolant resivror..???
Edited by lucerne06 (07/26/17 09:36 PM)
#4471499 - 07/26/17 11:26 PM Re: 06 lucerne 3,8 [Re: lucerne06]
WhyMe Offline
intake manifold gaskets. very common on GM V6
#4473337 - 07/28/17 08:08 PM Re: 06 lucerne 3,8 [Re: lucerne06]
WyrTwister Offline
Loc: Texas
If you are loosing coolant , also inspect the 2 plastic coolant elbows , between the engine & the serpentine belt tensioner . From there , the coolant goes to the 2 heater hoses .
Do a youtube search .
As far as the fuel pump relay under the rear seat , Eric O. - South Main Auto , has a good youtube video .
Wyr
God bless
