Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
26 registered members (bfleeman, Black_Thunder, AnthemBassMan, Brad_C, 555, AndyB, 3 invisible), 492 guests, and 68 spiders.
Topics286,262
Posts4,905,490
Members67,589
Most Online2,967
Mar 10th, 2019
Flooded with Gas Dilute Oil? #4466988
07/22/17 09:45 AM
07/22/17 09:45 AM
Colorado
JerryBob Offline OP
JerryBob  Offline OP
Colorado
Accidentally flooded my 2002 Honda minivan. I absent-mindedly pumped the gas pedal when starting. Old habit from my old Toyota with the carburetor.
Any idea if this causes much gas to get into the oil? I'm thinking a one-time flooding is not a big deal, but I tend to worry about things.
Re: Flooded with Gas Dilute Oil? [Re: JerryBob] #4466993
07/22/17 09:53 AM
07/22/17 09:53 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
FI doesn't have an accelerator pump like a carbureted engine does....no worries.
Thick vs Thin test: 15k / 43k miles complete
Re: Flooded with Gas Dilute Oil? [Re: JerryBob] #4467000
07/22/17 09:59 AM
07/22/17 09:59 AM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
We had a neighbour who had a brand new '63 Impala SS 2dr hardtop. Nice car. Might have been a 327 V8, but I'm not sure about that. He would flood it occasionally and believed you should (and did) always change the oil. That seemed a bit obsessive.
If an engine flooded regularly, it wouldn't be good for the oil, but once - I wouldn't worry about it.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: Flooded with Gas Dilute Oil? [Re: JerryBob] #4467001
07/22/17 10:03 AM
07/22/17 10:03 AM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
It doesn't happen like that and I doubt you would pump a carbed engine enough to flood the oil with gasoline.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Flooded with Gas Dilute Oil? [Re: JerryBob] #4467008
07/22/17 10:09 AM
07/22/17 10:09 AM
ME
eljefino Offline
eljefino  Offline
ME
Did you actually flood it as in you had to hold the pedal to the floor to clear it?
Regardless it'll evaporate off through the PCV system.
Re: Flooded with Gas Dilute Oil? [Re: eljefino] #4467018
07/22/17 10:19 AM
07/22/17 10:19 AM
Colorado
JerryBob Offline OP
JerryBob  Offline OP
Colorado
No, I just pumped the pedal once or twice before starting it, before I realized my mistake. Then I waited a few seconds, and cranked until it started. I smelled gas as I drove away. So I guess I was smelling it coming through the PCV system.
I'm guess I won't worry about it. I never do hard accelerations, and the oil probably otherwise stays very clean.
Re: Flooded with Gas Dilute Oil? [Re: JerryBob] #4467183
07/22/17 01:48 PM
07/22/17 01:48 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
You didn't flood anything on that engine, you could pump the pedal 100 times and nothing will happen except maybe your leg getting tired. The electronic engine control looks for a signal the engine is rotating as in cranking and running not even key on will fire the injectors allowing fuel into the engine without rotation being detected by the sensors.
Re: Flooded with Gas Dilute Oil? [Re: JerryBob] #4467231
07/22/17 03:12 PM
07/22/17 03:12 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
If you smelled gas, you have a leak somewhere ...
