Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
127 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,239 guests, and 62 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
How much crude oil is in a quart of engine oil? #4466083
07/21/17 11:49 AM
07/21/17 11:49 AM
North Central Illinois
EyesofThunder Offline OP
I have dug around and can't seem to find out how much. Once forum member (not sure what forum) said 21 gallons of crude to make 1 QUART of librication oil, but that sounds excessive to me.
Anyone know? Or know where I can find out? Just a ballpark number.
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466087
07/21/17 11:54 AM
07/21/17 11:54 AM
NJ, USA
MotoTribologist Offline
NJ, USA
About 1% of crude oil is converted to lubricating oil. So a 55 gallon drum yields about 0.5 gallons of lube oil. In other words 22.5 gallons produces about 1 quart.
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466093
07/21/17 12:02 PM
07/21/17 12:02 PM
CA
youdontwannaknow Offline
CA
Wow thats obscene. Is that for dino or synthetic ?
Is the yeild better for synthetic ?
2013 Accord Touring V6
2018 Chevy Volt
Re: How much crude oil is in a quart of engine oil? [Re: youdontwannaknow] #4466095
07/21/17 12:06 PM
07/21/17 12:06 PM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
What are you talking about? It's not as if it "takes" a whole barrel to "make" the oil and the rest is either consumed in that process or discarded. Crude oil is a very complex mixture of a wide range of molecular weight hydrocarbons, they are separated and often modified for particular uses such as lubricating oils and fuels (among many). Assuming the number quoted is correct the rest of the barrel is used for other purposes.
If one was so inclined you could either crack or convert higher or lower molecular weight compounds into motor oil and with enough effort utilize the entire barrel. It doesn't even have to be crude oil as is demonstrated with GTL.
All of this takes energy of course but it's not the whole rest of the barrel.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 409K
2000 Toyota ECHO, 280K
Re: How much crude oil is in a quart of engine oil? [Re: kschachn] #4466100
07/21/17 12:12 PM
07/21/17 12:12 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
What are you talking about? It's not as if it "takes" a whole barrel to "make" the oil and the rest is either consumed or discarded. Crude oil is a very complex mixture of a wide range of molecular weight hydrocarbons, they are separated and often modified for particular uses such as lubricating oils and fuels (among many). Assuming the number quoted is correct the rest of the barrel is used for other purposes.
Exactly, the crude is sorted by fractional distillation.. Some fractions are very light. Others are heavy like tar.
It's not like they say ok, this run we are making base stock and they get 0.5 gallons of base stock from a 42 gallon barrel. They process the crude and get a number of fractions from the distillation tower.
network down, IP packets delivered via UPS -BOFH
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466102
07/21/17 12:13 PM
07/21/17 12:13 PM
Upper Midwest
Upper Midwest
As has been pointed out, it doesn't "take" 21 gallons of crude to "make" one quart of oil. That may be the ultimate yield but the 21 gallons is not consumed in the process.
You have your question backwards BTW. It isn't how much crude is in a quart of engine oil, it is how much engine oil is in a barrel of crude. Even that isn't exactly right but that is how you should look at it.
1994 BMW 530i, 241K
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466105
07/21/17 12:15 PM
07/21/17 12:15 PM
Illinois
javacontour Offline
javacontour  Offline
Illinois
I think the question is how much of what is in a bottle is basestock (from crude) and how much is additives.
Not sure one will ever get a straight answer.
Re: How much crude oil is in a quart of engine oil? [Re: javacontour] #4466114
07/21/17 12:23 PM
07/21/17 12:23 PM
CA
CA
I was going by the first reply in the thread by MotoTribologist that said "... So a 55 gallon drum yields about 0.5 gallons of lube oil. In other words 22.5 gallons produces about 1 quart..."
How else could one interpret that ?
But thanks its good to know it does not take 22 gallons of crude to produce 1 Qt of lube oil.
2018 Chevy Volt
Re: How much crude oil is in a quart of engine oil? [Re: youdontwannaknow] #4466119
07/21/17 12:28 PM
07/21/17 12:28 PM
A barrel is NOT 55 gallons, a DRUM is 55. A barrel of crude is 42 gallons.
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466123
07/21/17 12:34 PM
07/21/17 12:34 PM
Danh Offline
Danh  Offline
Long story short, virtually every ounce of a 42 gallon barrel is used for something. It may be gasoline or diesel fuel or lubricating oil or grease or asphalt or tar or plastics, et al. True contaminants are about the only thing not used.
And if the OP's 21 gallons of crude to make 1 quart of oil was literally true, that quart of oil would cost around $25 in crude alone.
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466145
07/21/17 12:54 PM
07/21/17 12:54 PM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
I believe the oil use to make motor oil was at one time a "waste" that had no real use before people created a purpose for it.
You can't really say X amount of crude is needed to produce motor oil as it is a by product of the crude refining process.
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466165
07/21/17 01:10 PM
07/21/17 01:10 PM
Upper Midwest
Upper Midwest
That indiscretion is made up for by the fact that crude oil is not all the same, and some will have more or less of the molecular mass fraction that is required for motor oil.
1994 BMW 530i, 241K
Re: How much crude oil is in a quart of engine oil? [Re: EyesofThunder] #4466184
07/21/17 01:24 PM
07/21/17 01:24 PM
MN
oil_film_movies Offline
MN
Answer to how much crude it takes to make 1 quart of motor oil: Not much at all if its a GTL Group III synthetic made from natural gas (i.e, Pennzoil PurePlus).
Answer to how much base oil is in a quart of oil (like the title suggests): 80%-90%, in that range.
Re: How much crude oil is in a quart of engine oil? [Re: oil_film_movies] #4466188
07/21/17 01:28 PM
07/21/17 01:28 PM
Upper Midwest
Upper Midwest
If you go by what the title suggests the answer is zero.
1994 BMW 530i, 241K
Re: How much crude oil is in a quart of engine oil? [Re: kschachn] #4466198
07/21/17 01:40 PM
07/21/17 01:40 PM
Right sorry didn't word it well. Zero crude in a quart of motor oil.
Rephrased. How my crude oil is needed to be distilled or processed to end up with 1 quart of petroleum motor oil (including additives). Probably no way to get an answer.
