I picked up some Pentosin ATF 1 LV at this years AZ 'Clearance'
This is what Pentosin literature states:
"Pentosin ATF 1 LV Fully Synthetic Automatic Transmission Fluid is recommended for Mercedes-Benz 236.10, 236.12, and 236.14 specifications. Pentosin ATF 1 LV is ideal for lifetime applications in automatic gearboxes. It can also be used where a ‘low-viscosity’ ATF is required."
It sounds like it would be a good fit in a Mercon LV application....thoughts?
