PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
107 registered members (69GTX, arowbat, 69Torino, 2018matto, 2012AccentSE, 16 invisible), 1,935 guests, and 57 spiders.
Topics286,181
Posts4,903,706
Members67,574
Most Online2,967
Mar 10th, 2019
Spark Plug Color- Burning Oil #4464051
07/19/17 02:10 PM
07/19/17 02:10 PM
sw ohio
willbur Offline OP
willbur  Offline OP
sw ohio
Greetings-
what color would the spark plug center electrode be for a cylinder that is maybe burning a little oil? Plugs for five cylinders appear light brownish or white, while the number two cylinder has some coarse med gray deposits on the center electrode. Otherwise, the engine runs superbly wo any indication of oil burning. Color charts say this is a normal color, but since it is quite different from the other five, my suspicions are aroused. Or is this just normal BITOG paranoia?
Re: Spark Plug Color- Burning Oil [Re: willbur] #4464062
07/19/17 02:22 PM
07/19/17 02:22 PM
KS
dpilot83 Offline
dpilot83  Offline
KS
Originally Posted By: willbur
Greetings-
To properly compare cylinders to one another based upon spark plug appearance you need to make sure that whoever installed the spark plugs last timed them correctly. If they are all rotated exactly the same with respect to the valves and piston then you can make an accurate comparison between cylinders. Otherwise it's a wild goose chase.
If your spark plugs do not align properly when tight then you may need to take them to a machine shop and have them build it back up and then cut new threads that are aligned properly.
Only truly paranoid machine shop owners will take you seriously when you request this procedure;)
Re: Spark Plug Color- Burning Oil [Re: willbur] #4464110
07/19/17 03:28 PM
07/19/17 03:28 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I doubt their has ever been an indexed spark plug in an everyday vehicle.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Spark Plug Color- Burning Oil [Re: CT8] #4464147
07/19/17 04:05 PM
07/19/17 04:05 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The Honda Insight had indexed plugs from the factory. Was a pain to replace plugs because you had to order them by index number for each cylinder.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Spark Plug Color- Burning Oil [Re: mightymousetech] #4464150
07/19/17 04:08 PM
07/19/17 04:08 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
That is amazing. Squeezing every mpg and ounce of power possible it seems.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Spark Plug Color- Burning Oil [Re: mightymousetech] #4464154
07/19/17 04:11 PM
07/19/17 04:11 PM
KS
dpilot83 Offline
dpilot83  Offline
KS
Lol, I was just making a joke since he was joking about BITOG paranoia. Had no idea such a thing existed.
Re: Spark Plug Color- Burning Oil [Re: dpilot83] #4464297
07/19/17 07:22 PM
07/19/17 07:22 PM
sw ohio
willbur Offline OP
willbur  Offline OP
sw ohio
Thanks All for this valuable insight into spark plug indexing. However, will this explain the observed color? Indexing is a very inexpensive means to improve power but is it actually relevant to spark plug color?
So, do med grey center electrode deposits indicate oil burning?
Re: Spark Plug Color- Burning Oil [Re: willbur] #4464388
07/19/17 09:31 PM
07/19/17 09:31 PM
Canada
i_hate_autofraud Offline
Canada
Indexing plugs does not require machining since the start of the thread on the plug relative to the ground
electrode position would be random.
Back a few years ago I did consider indexing washers/spacers for plugs in a V8 engine. I originally
was looked at indexing to fix a bad smog test, it made no difference.
With small cylinders in V6s, etc, and fast lean cylinder fuel burn, a plug facing the "wrong way" likely
makes a .01% difference unless your building a race car!
Re: Spark Plug Color- Burning Oil [Re: willbur] #4464435
07/19/17 10:27 PM
07/19/17 10:27 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Prolly represents the proximity to the PCV system inlet location, or to the most pronounced drafts that waft by the PCV port ... Or you have a minor valve stem seal weep, or you have a very slow intake gasket weep on that port, or something. The color is telling you something, but we don't know what ...
Usually a cylinder burning oil will have a blackish plug ...
Re: Spark Plug Color- Burning Oil [Re: willbur] #4465042
07/20/17 02:45 PM
07/20/17 02:45 PM
Ontario, Canada
Ontario, Canada
But to answer OP's question, yes, it may be burning a bit of oil on that cylinder. Don't worry about it, I don't think it is time to start building a new engine yet.
Mighty Mouse Tech
Re: Spark Plug Color- Burning Oil [Re: willbur] #4465472
07/20/17 08:43 PM
07/20/17 08:43 PM
Morris County NJ
steve20 Offline
steve20  Offline
Morris County NJ
I think Broc nailed it with his answer--closed cylinder to PCV 'wind'--Even though EGR also distributes to all cylinders,that particular plug maybe the closest to EGR flow?
Steve
Re: Spark Plug Color- Burning Oil [Re: willbur] #4466661
07/21/17 08:45 PM
07/21/17 08:45 PM
Tennessee
OilSwag Offline
OilSwag  Offline
Tennessee
Indexing is not needed in 99.9% of vehicles today. With old Pushrod engines in relation to a intake and exhaust valve it helped. Head designs have improved alot and pretty much made this mod obsolete. With like 4 valve cars you have a 50% chance of indexing the plugs randomly anyway in an install. Regardless with technology available to use it's been found indexing doesn't help anymore. Fuel trims from obd and datalogging have shown this.
OP, I changed my plugs a few weeks ago and saw a plug that looked different than what I've seen in my 19 years of car mechanics. If you were the one that installed the plugs you could use the used plugs as a reference. With how PO's treat cars, you have no idea what was a used plug, what was in the car for 5 years vs 6 months. I saw a good chart referencing used plugs. It posted over 25 different pictures of plugs as a good reference. If you pull up a chart with 5-10 used plugs from detonation, fouling, etc it's to generic. Reason being is you don't know if a car was running lean for 4K miles than fixed, than perfect for 1k miles but starting fouling because of excessive pcv pressure from oil through intake or whatever. I know now since my plugs were installed that the car is running perfect on all cylinders from datalogging, maintenance, etc so when I pull my plugs for inspection I can than evaluate how the engine was running. The plugs tell some of the story but only part of it. You could pull a plug that looks like the car was running rich as [censored]. In a OBD2 car that meant the car was running lean a [censored] as the ecu was compensating by dumping fuel. If you want to really see how your engine is download torque and get a $10 OBD2 Bluetooth, easy peasy and you can check all important generic sensor readings for free. 5-10 min will tell you more than you could ever know
03 Infiniti G35 209K, Castrol Edge 5W30 topped with Edge HM, Fram Ultra Filter, Berryman/MMO fuel maintenance in 93 E0, all synthetic fluids
