voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Geardaddies, tedonom, 01ws666, ariefnrst, tcoffin014
66658 Registered Users
101 registered members (4WD, 28oz, 2008wrx, 2004tdigls, 14 invisible), 1,871 guests, and 35 spiders.
Topics294,978
Posts4,925,312
Members66,658
Most Online2,553
Oct 27th, 2018
High mileage CVT fluid change #4457953
07/13/17 07:04 AM
07/13/17 07:04 AM
Canada
AustinD Offline OP
AustinD  Offline OP
Canada
I am going to change the CVT fluid on my 2009 Jeep Patriot, however I wanted the opinion of some of you first.
I know with automatic transmissions, if the fluid and transmission are too far gone, the particulates in the fluid can help the clutches in the transmission engage and filling with fresh fluid can cause the transmission to start slipping.
Obviously CVT transmissions work in a different fashion, however I do not know much about them. My Patriot has about 120,000 miles, or 193,000 kilometers, and I am not sure if the fluid has ever been changed. The fluid appears look like fresh motor oil, which from what I understand is what it should look like (I've read that the original fluid has a green tint with turns to the color of motor oil relatively quickly). The fluid does not appear to be dirty. Is there any risk changing the fluid?
Also, I am planning on using Valvoline CVT fluid, which claims to meet CVTF+4 specifications. Is this a good oil, and is there any reason to use OEM fluid over it? Thanks for your advice.
PS, I have a dipstick for this transmission, as well as a scan tool that can read the transmission temperature. Also, I plan on replacing the filter and pan gasket and have access to a pit in a garage.
Re: High mileage CVT fluid change [Re: AustinD] #4457964
07/13/17 07:11 AM
07/13/17 07:11 AM
North Carolina
Rat407 Offline
Rat407  Offline
North Carolina
It shouldn't be a problem. My friend had the same vehicle as you and changed his out at 140k from what was probably the original fluid. Only difference is he used AMSOIL's CVT fluid. It ran great afterwards.
I also changed out the CVT fluid on a Nissan Sentra at 134k, no issues with it either until they sold it at 190k to get a brand new Fusion. The Nissan was starting to use oil at a qt in 500 miles and it poisoned the CAT.
2002 Silverado 5.3 0w-20 AMSOIL
Re: High mileage CVT fluid change [Re: AustinD] #4458079
07/13/17 09:09 AM
07/13/17 09:09 AM
Sav ga
NStuart Offline
NStuart  Offline
Sav ga
O had no problem did several changes at 170k
Detroit14l 1m75k mi bp schaffer9k 30k oil
96 ram 5.9 gas 80k built tranny 5k m1
85 cj7 4.2 performance build. Schaeffer 9000
08 cbr600rr graffiti. T6
08 husky sm610 t6
Re: High mileage CVT fluid change [Re: AustinD] #4458278
07/13/17 12:32 PM
07/13/17 12:32 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Austin, if you're uneasy about it, you could suction out whatever CVT fluid you can get from the dipstick tube and refill with the amount you took out. Drive it around for awhile and if all is well, do the pan drop, clean and refill. I would imagine the fluid will look black. I know it was very dark in my 2016 Nissan Quest CVT at only 32K miles, where new OEM fluid is blue. I'd easily use Valvoline CVT juice in your Jeep. I plan to use it in my Subaru CVT at some point.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: High mileage CVT fluid change [Re: AustinD] #4458323
07/13/17 01:19 PM
07/13/17 01:19 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Just did a drain/fill on a Honda CVT with 120k on its black and burnt fluid. Put in about 4qts of Castrol CVT fluid and seems fine after.
Amazon has a case of Castrol CVT fluid for $35 so that is the cheapest I have found so far.
yup
Re: High mileage CVT fluid change [Re: AustinD] #4458454
07/13/17 03:28 PM
07/13/17 03:28 PM
USA
slacktide_bitog Offline
USA
Nothing wrong with Valvoline, but Amazon has Castrol CVT at a good price too smile
Re: High mileage CVT fluid change [Re: Jimzz] #4458818
07/13/17 09:38 PM
07/13/17 09:38 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
You can use castrol cvt fluid in the Honda ?? I heard the Honda cvt's only suppose to use Honda cvt fluid ONLY
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: High mileage CVT fluid change [Re: Ram02] #4459031
07/14/17 06:33 AM
07/14/17 06:33 AM
Canada
AustinD Offline OP
AustinD  Offline OP
Canada
Well, the manufacturer is going to tell you that. Honda would have you using only Honda branded toilet paper if they could get away with it.
Valvoline CVT fluid also claims to meet Honda (HMMF) specifications.
Re: High mileage CVT fluid change [Re: AustinD] #4459083
07/14/17 07:50 AM
07/14/17 07:50 AM
Upper Midwest
kschachn Online content
kschachn  Online Content
Upper Midwest
It is "recommended for" that use, right?
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: High mileage CVT fluid change [Re: Ram02] #4459253
07/14/17 11:55 AM
07/14/17 11:55 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Yep meets spec and was the best price I could find.
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/BEE1DAAC8509BE8C80257DA5006202D0/$File/BPXE-9RV9FP.pdf
Suitable for use where:
Toyota CVT Fluid TC
Toyota CVT Fluid FE
Nissan CVT Fluid NS-1
Nissan CVT Fluid NS-2
Nissan CVT Fluid NS-3
MMC DIAQUEEN ATF SP-III
MMC DIAQUEEN CVT Fluid J1
MMC DIAQUEEN CVT Fluid J4
Mazda CVTF 3320
Subaru i-CVT Fluid
Subaru i-CVT FG
Subaru Lineartronic High Torque Chain CVTF
Daihatsu AMMIX CVT Fluid DC
Daihatsu AMMIX CVT Fluid DFE
Suzuki CVT Fluid 3320
Suzuki CVT Fluid Green 1
Suzuki CVT Fluid Green 2
Suzuki CVTF TC
Suzuki NS-2
Honda HCF-2
Hyundai/Kia SP-III
Chrysler NS-2
Chrysler CVTF+4
Mini Cooper EZL799
Ford CVT23
MB 236.20
yup
Re: High mileage CVT fluid change [Re: AustinD] #4460274
07/15/17 02:28 PM
07/15/17 02:28 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
I just flipped the washer that was on the Honda I did. I think it was just a normal aluminum washer, not a crush one. If you have the same just clean and flip it.
yup
Re: High mileage CVT fluid change [Re: AustinD] #4462696
07/18/17 09:21 AM
07/18/17 09:21 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I've never had one of these washers leak after reusing them.
