KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
27 registered members (Bailes1992, 2015Corolla, alcyon, 1WildPig, ArrestMeRedZ, 1 invisible), 816 guests, and 36 spiders.
Topics290,965
Posts4,853,483
Members66,063
Most Online3,590
Jan 24th, 2017
Type A transmission fluid replacement #4455629
07/10/17 08:04 PM
07/10/17 08:04 PM
Ottumwa, Iowa
jhellwig Offline OP
jhellwig  Offline OP
Ottumwa, Iowa
I have a non transmission application that specs type A. I have never seen or heard of type a. Does anyone know what it has been replaced by?
This is for a hydraulic control valve from the late 80s early 90s.
It can also take MIL-H-5606A spec fluid.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Type A transmission fluid replacement [Re: jhellwig] #4455634
07/10/17 08:07 PM
07/10/17 08:07 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I always see it at liquer stores next to the nd oil and 8oz bottles of brake fluid.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Type A transmission fluid replacement [Re: Chris142] #4455637
07/10/17 08:10 PM
07/10/17 08:10 PM
Ottumwa, Iowa
jhellwig Offline OP
jhellwig  Offline OP
Ottumwa, Iowa
I need something that is an actual fluid.
2014 Toyota Sienna
1983 Chevy K5 350
Re: Type A transmission fluid replacement [Re: jhellwig] #4455642
07/10/17 08:14 PM
07/10/17 08:14 PM
GA
drtyler Offline
drtyler  Offline
GA
In GM applications (early Powerglides for example), Dexron spec fluid is the replacement and works fine.
I would find a Dexron III fluid, even though that isn't the current Dexron spec.
Re: Type A transmission fluid replacement [Re: jhellwig] #4455659
07/10/17 08:28 PM
07/10/17 08:28 PM
USA
slacktide_bitog Offline
USA
Type-A is what they used before the original Dexron, very very obsolete.
You can probably get Type-A at one of those discount stores in the hood (PQIA has profiled some of them). Amazon also has Accel Type-A
But you're much better off with any Dexron III type ATF. Even Walmart brand ST will work fine in your application smile
Re: Type A transmission fluid replacement [Re: jhellwig] #4455694
07/10/17 08:52 PM
07/10/17 08:52 PM
Ottumwa, Iowa
jhellwig Offline OP
jhellwig  Offline OP
Ottumwa, Iowa
I guess I could even put dex 6 in it then. The pump runs constantly on this.
2014 Toyota Sienna
1983 Chevy K5 350
Re: Type A transmission fluid replacement [Re: jhellwig] #4455709
07/10/17 09:09 PM
07/10/17 09:09 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
OK, so does the thing have clutches? If not, just use hydraulic fluid ...
Re: Type A transmission fluid replacement [Re: jhellwig] #4455724
07/10/17 09:31 PM
07/10/17 09:31 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Tractor hydraulic fluids claim to meet type a
115 Simplex Torque Converter Fluid
For use in automatic and heavy-duty transmission where automatic transmission fluid type A is required ,this is a copy and paste for example.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Type A transmission fluid replacement [Re: jhellwig] #4455893
07/11/17 05:45 AM
07/11/17 05:45 AM
Guilford, CT
exranger06 Offline
exranger06  Offline
Guilford, CT
Napa sells "Type FA" fluid, which is supposedly for Type F and Type A applications.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Type A transmission fluid replacement [Re: BrocLuno] #4456607
07/11/17 07:34 PM
07/11/17 07:34 PM
Ottumwa, Iowa
jhellwig Offline OP
jhellwig  Offline OP
Ottumwa, Iowa
No clutches. Just pumps and amplifiers running a cylinder.
I do t know why Fisher speced transmission fluid but their products are built proof for the most part.
2014 Toyota Sienna
1983 Chevy K5 350
