Type A transmission fluid replacement
Ottumwa, Iowa
I have a non transmission application that specs type A. I have never seen or heard of type a. Does anyone know what it has been replaced by?
This is for a hydraulic control valve from the late 80s early 90s.
It can also take MIL-H-5606A spec fluid.
Originally Posted By: Chris142
I always see it at liquer stores next to the nd oil and 8oz bottles of brake fluid.
I need something that is an actual fluid.
In GM applications (early Powerglides for example), Dexron spec fluid is the replacement and works fine.
I would find a Dexron III fluid, even though that isn't the current Dexron spec.
Type-A is what they used before the original Dexron, very very obsolete.
You can probably get Type-A at one of those discount stores in the hood (PQIA has profiled some of them). Amazon also has Accel Type-A
But you're much better off with any Dexron III type ATF. Even Walmart brand ST will work fine in your application
Tractor hydraulic fluids claim to meet type a
115 Simplex Torque Converter Fluid
For use in automatic and heavy-duty transmission where automatic transmission fluid type A is required ,this is a copy and paste for example.
Originally Posted By: BrocLuno
OK, so does the thing have clutches? If not, just use hydraulic fluid ...
No clutches. Just pumps and amplifiers running a cylinder.
I do t know why Fisher speced transmission fluid but their products are built proof for the most part.
