set for years
by 93cruiser
24 seconds ago
Looking to replace 2005 Sienna with SUV
by i6pwr
42 minutes 13 seconds ago
Trying to fix chainsaw
by turtlevette
Today at 06:48 PM
tire rotation
by marine65
Today at 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
Today at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
Today at 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
Today at 06:00 PM
New belt squeal cause damage to belt?
by pda1122
Today at 05:33 PM
Food Safety - If You Have Children
by Zee09
Today at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Today at 05:02 PM
Chain cleaning and lube
by dadinfo
Today at 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
Today at 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
Today at 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
Today at 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
Today at 04:30 PM
mobil 1 rebate check
by Fitter30
Today at 03:52 PM
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
Extend wifi range
by clarkflower
Today at 02:05 PM
Under valve cover pics 207,000 miles
by WobblyElvis
Today at 01:57 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
99 registered (93cruiser, 69Torino, 14Accent, 2015_PSD, 2004tdigls, 12 invisible), 1508 Guests and 62 Spiders online.
65303 Members
67 Forums
285875 Topics
#4454915 - 07/10/17 04:58 AM 2003 Marquis - Fan clutch?
tony1679 Offline
Loc: Central Oklahoma
Perhaps this is the stupid question of the day...
I was fumbling around part sites and discovered that there are aftermarket and even Motorcraft fan clutch replacements for my '03 MGM. However my car has an electric fan and NO clutch fan. So I have to ask, is it possible to add the clutch fan and use both?!? I've been looking at cheap ways to keep it cooler under the hood (mainly for the transmission's sake) and all the sites label these parts as an "exact fit" for my car (and list "severe duty" under the specs). Was it a one-or-the-other option? I'd be very interested if I can use both. But I'm also curious about benefits and disadvantages as well. I know it would drop mpgs/horsepower a little, but if it stays cooler it would be worth it in the summer, and I could remove it for the rest of the year. I know a trans cooler is the answer, but it's not my definition of cheap. I've just never heard of an 03 with a clutch fan. Also, if I can use both, where can I buy the fan blade for the clutch?
Am I missing something? shrug Thanks in advance!
2008 Chevrolet Impala SS (Tuned- DOD/AFM is EVIL!)
2003 Mercury Grand Marquis LS Ultimate Edition
Macro beer... puke
#4454957 - 07/10/17 06:43 AM Re: 2003 Marquis - Fan clutch? [Re: tony1679]
aquariuscsm Offline
Loc: Dallas,Tx USA
Is your Marquis like my 300ZX,which has an old school mechanical fan with a fan clutch for the main cooling and a secondary electric fan that comes on with the A/C?
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum 0W20
#4454976 - 07/10/17 07:05 AM Re: 2003 Marquis - Fan clutch? [Re: tony1679]
Trav Offline
Loc: MA, Mittelfranken.de
PM member bdcardinal with your VIN, he will be able to tell you.
#4454981 - 07/10/17 07:09 AM Re: 2003 Marquis - Fan clutch? [Re: tony1679]
Miller88 Offline
Loc: Onondaga County
I don't see why you couldn't put an actual fan clutch on that car unless they changed the radiator support in '03. As long as the water pump supports the hub and clutch, you should be good. You might end up having to get a new water pump and shroud for it.
They might set a check engine light if you are missing the electric fan. But if I were to add the mechanical fan, I'd ditch the electric completely.
I imagine it's the same for the 1/2 ton chevy trucks with electric fans. Even the 3.8L wranglers have a fan clutch kit for them!
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
#4454999 - 07/10/17 07:37 AM Re: 2003 Marquis - Fan clutch? [Re: Miller88]
Trav Offline
Ford parts catalog list electric and/or mechanical clutch so they apparently did use one on some vehicles like may be Police, I have no idea that's why I defer to a parts pro.
#4455144 - 07/10/17 10:26 AM Re: 2003 Marquis - Fan clutch? [Re: tony1679]
Rhymingmechanic Online   content
Loc: VA
I think the simplest and probably cheapest solution to cooling the trans IS a trans cooler. A good quality plate-type cooler kit should be under $100.
Adding a fan would require the clutch, fan blade, and possibly a new hub or pump with threads for the fan clutch. Rock Auto lists both short and long water pumps, which makes me wonder if that's related to the fan type. Removing the electric fan altogether will also require a new shroud.
There are a few Panther/police interceptor enthusiasts on here. Hopefully some of them will see your thread.
#4455152 - 07/10/17 10:31 AM Re: 2003 Marquis - Fan clutch? [Re: Rhymingmechanic]
Canadastang Offline
Loc: Ontario Canada
I have a 2003 Town Car, so I'll chime in.
To start, I don't think a mechanical fan would even fit without some rad hose modification or possibly some hood modification (yikes). With that said, you'd have to change your water pump to an older style pump with a threaded hub, and then you'd still have the issue of no plastic fan shroud protecting your pinkies when you open the hood (minor issue I suppose). You'd probably also have to remove the crash bracket on the pass side front of the engine (bad idea).
It'll cause a slight loss in HP and fuel economy due to the added drag on the engine, and it probably won't even move air as well as the electric fan on high.
So I have to ask, why?
My theory on the 03 having a listing for a mechanical fan is probably just an error or overlap. 2003+ panther cars had significant changes versus 92-02 models. All 03+ panthers had rack and pinion steering, but plenty of parts catalogs list steering gears, idler arms, pitman arms, etc., even though those parts simply do not exist on 03+ cars.
Edited by Canadastang (07/10/17 10:32 AM)
#4455790 - 07/10/17 11:01 PM Re: 2003 Marquis - Fan clutch? [Re: tony1679]
bdcardinal Online   content
Loc: Santa Barbara, CA
I have not seen a Panther chassis car with a fan clutch for that year range. Now maybe the ones that were meant to be modified into livery or limos might have had one. The limos have F150 rear drums.
The electric fans are fine. There was an issue with a few years and you had to replace the fan with the relay/module.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#4455837 - 07/11/17 01:31 AM Re: 2003 Marquis - Fan clutch? [Re: tony1679]
Falcon_LS Offline
Loc: Kuwait
Fan clutches went the way of the Dodo bird on this platform in 1998, with the introduction of Fail Safe Cooling and a two-speed electric fan using a Bosch controller. This uses a cylinder head temperature sensor mounted on the driver's side. 1995 - 1997 models had a clutched fan/electric fan combo controlled by the PCM based on engine temperature and whether or not the air conditioning was on. The electric fan does not pull enough air to cool the radiator, it is an auxilary unit.
For 2003 and newer vehicles, the fan is a variable speed unit that utilizes a PWM module on fan shroud, controlled by PCM. You cannot install a clutched fan on your vehicle without a number of modifications. For starters, the electric fan shroud, which the coolant overflow and power steering reservoir is mounted on, sits too close to the engine. You cannot physically fit a clutched fan in there.
In '06, electric fan was revised and had different blades - they were shallower and less curved with a smaller motor. This was much less efficent, and there were overheating issues that were addressed in a TSB - replace the fan with a newly revised version. The engine coolant temperature sensor was also eliminated, in favor of a single cylinder head temperature sensor to maintain coolant temperature.
GC 0W40 or Motul X-Cess 5W40:
99 Explorer EB: XG8A
00 Pajero: MD352626
01 Grand Marquis: XG2
03 Expedition SSV: XG2
05 Envoy: 51522XP
07 SRX: XG8765
