2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
98 registered members (ABCarr, 2009Edge, 14Accent, 11 invisible), 1,492 guests, and 41 spiders.
Topics290,733
Posts4,849,336
Members66,033
Most Online3,590
Jan 24th, 2017
2006 Buick CX Lacrosse 3.8l - Preventive Maintenan #4453859
07/08/17 10:17 PM
07/08/17 10:17 PM
Texas
WyrTwister Offline OP
Texas
We bought this car a week or two ago . 37,000 + miles on the clock . in nice shape , as far as I can tell .
So , I am attempting some DIY PM .
Considering it is 11 years old , rubber and plastic tend to go bad with age & heat . I am replacing the 2 radiator hoses . The lower hose was a real bear . Ended up removing the battery & tray to gain better access to the 2 spring hose clamps . Has to cut the OEM hose in the middle so I could treat this hose as 2 separate pieces . This enabled me to twist / wiggle the hose ends to position the 2 " tabs " on the spring clamps to be more accessible to pliers .
I do not like spring hose clamps ! Replace the ones on the lower hose with screw / worm gear type clamps .
While the battery tray is out , I wire brushed it and painted it with Duplicolor black " Rust Remedy " spray paint . Hope this will forstall further corrosion ( it really was not in very bad shape ) .
Plan to replace the serpentine belt . Replaced the 2 plastic " heater elbows " with metal elbows .
Plan to replace the thermostat / gasket . When all the coolant related items are finished , will refill with fresh / new coolant .
Used 2 different Walmart $ 2 turkey basters . One to remove Power Steering fluid & the other to remove brake fluid . Then refill with clean / new fluid . ( By the way , the PS pump is located kind of under the alternator area of the firewall side of the passenger side of the engine compartment . Very big pain to get to . :-(
Replace the hood assist " struts " .
Purchased a transmission filter & gasket . Ordered full synthetic Dexron VI & hope to do a spill & fill before the weather turns cold , this winter . Thinking about adding a Dorman steel transmission pan with a drain plug .
Tires look to be 50% or better . Dealer said they changed oil before I took delivery . Bought 5 of the $ 10 - 5 quart dino oil on sale at Home Depot . One oil filter at Wally World . Plan to order sever ( stretch out the freight cost ) filters from RockAuto.com .
Does any one know if the suspension has grease zerts ? I have a grease gun .
Thanks for listening .
Need to order a dash mat .
Wyr
God bless
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453866
07/08/17 10:26 PM
07/08/17 10:26 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
Ive read that the turkey baster method does not work with brake fluid. I do use the same method for PS fluid though.
How about a inline transmission filter or cooler?
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453877
07/08/17 10:35 PM
07/08/17 10:35 PM
Dallas,Tx USA
aquariuscsm Online content
aquariuscsm  Online Content
Dallas,Tx USA
I change ALL fluids as soon as I get the car home,before ever driving it again. The weekend I brought my Accord home,I changed the oil,transmission fluid,coolant,brake fluid,and power steering fluid.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: TheKracken] #4453896
07/08/17 11:00 PM
07/08/17 11:00 PM
Texas
Texas
Turkey baster does not remove anywhere near all of the fluid . Need to drive it a while & repeat .
Do not know why it has a problem with brake fluid ? Seems to work for me ?
Thought about an external ATF cooler in front of the radiator .
Also thought of the in line filter . Less familiar with it than the external cooler . The question of pressure drop comes to my mind . How often is it recommended to be changed out ?
Thanks ,
Wyr
God bless
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453897
07/08/17 11:01 PM
07/08/17 11:01 PM
Idaho
CT8 Online content
CT8  Online Content
Idaho
Brake fluid doesn't circulate .The master cylinder pushes fluid to the wheel cylinders when the brake pedal is pushed . when the brake pedal is released the pressure drops and the brakes release. Like a syringe connected by a hose to another syringe. Noooooooooooo dash mat.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: aquariuscsm] #4453899
07/08/17 11:04 PM
07/08/17 11:04 PM
Texas
Texas
Not a bad idea .
Being an old fat man , I kind of have to pace myself . Have not driven it very much since taking delivery . I mostly drive a company pick up & wife drives our little red Chevy Sonic .
Will drive it more after I retire & loose the company truck .
Thanks , :-)
Wyr
God bless
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453901
07/08/17 11:05 PM
07/08/17 11:05 PM
Idaho
CT8 Online content
CT8  Online Content
Idaho
It is nice having a company vehicle . I cry for 2 hours before starting any project
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: CT8] #4453903
07/08/17 11:08 PM
07/08/17 11:08 PM
Texas
Texas
Yes , you are correct , yet it would seem there must be a little migration of fluid ?
The turkey baster should be better than nothing . However , I can see the best thing would be to jack each wheel up , one at a time & bleed the wheel cylinder / caliper via the bleed screw .
The old fat man does not move along like he once die .
Thanks , :-)
Wyr
God bless
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: CT8] #4453905
07/08/17 11:10 PM
07/08/17 11:10 PM
Texas
Texas
The company truck cost me zero & I drive it as I wish .
Can not get much better than that ! :-)
I too am subject to procrastination before I start a project . :-(
Wyr
God bless
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453932
07/09/17 12:02 AM
07/09/17 12:02 AM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
Thanks , :-)
The water is absorbed into the brake fluid and distributed throughout the fluid. So eventually you can get most of the water out, but that would take a long time and countless gallons of fluid.
Think of simple diffusion.
95 Cherokee 190K DELO 10W30,XG8
07 IS250 100K Napa 10w30,FULL
04 YZF-R1 19K DELO 15w40,XG7317
99 HD XL1200S 20K VR1 20w50,1515
14 RX450h 32k PP MIX,NAPAG
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453947
07/09/17 01:05 AM
07/09/17 01:05 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
They're actually very manageable with the right tool. They also keep a constant tension on the hose even if the hose shrinks.
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4453999
07/09/17 04:52 AM
07/09/17 04:52 AM
Texas
Texas
I am sure you are correct .
I never have the right tools . Bought 2 new long needle nose pliers for the task . One with " bent " nose & the other with straight nose .
Also used vice-grips and channel locks .
Please tell me , what should I use ? Hopefully , that is available locally ( not have to special order ? ) .
Of course , I hope I will not need them again for a whilr .
But our little red Sonic uses spring clamps , also . :-(
Thanks , :-)
Wyr
God bless
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4454004
07/09/17 05:36 AM
07/09/17 05:36 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
If you feel the brake fluid needs attention, why not do it right and bleed the system? The new fluid will just stay in the M/C and will not find its way down to where it's needed most, downstream.
The "thinking" man's friend.
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: WyrTwister] #4454013
07/09/17 06:04 AM
07/09/17 06:04 AM
Taiwan
Ducked Online content
Ducked  Online Content
Taiwan
Not a bad idea .
Yes it is/I don't.
New-to-me used car is an unknown quantity and a potential gotcha. I wait and see if I've made a terrible mistake before I spend any more money on it.
Of course if you never make terrible mistakes, then this tactic won't be relevant, but I have, and do.
Re: 2006 Buick CX Lacrosse 3.8l - Preventive Maintenan [Re: Lubener] #4454032
07/09/17 06:38 AM
07/09/17 06:38 AM
Texas
Texas
Lazy .
Wyr
God bless
