Originally Posted By: gofast182
Originally Posted By: dparm
I would not get wax on any sort of window. It won't hurt the glass, but it will smear and be messy.
In the case of D156, not in the least, quite the opposite. Remember these are detail sprays with many being synthetic "wax" and/or polymer-based. Several, including D156, recommend use as a drying aid (spray on a wet car and dry). With that said, I don't purposely spray it all over my windows.
I have found the same results. D156 can be used just about anywhere on the car - I have even sprayed it on my windows, and found that it acts a lot like Rain-X is SUPPOSED to work.. Rain just can't stick to the windshield with D156 on it. One caveat though, if you're going to do this: Make sure you go over it a few times with your microfiber to make sure you've removed ALL the high spots/residue.
