European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
28 registered members (Bjornviken, craigq, 2015Corolla, Black_Thunder, Bailes1992, BlakeB, 5 invisible), 628 guests, and 38 spiders.
Topics290,966
Posts4,853,497
Members66,063
Most Online3,590
Jan 24th, 2017
2GRFE '16 Highlander 3.5L V6 Oil Filter #4446873
07/01/17 04:46 PM
07/01/17 04:46 PM
northern Alabama
benjamming Offline OP
northern Alabama
I'm looking for information on Motorcraft FL-2060 & ACDelco PF2259 oil filters that fit my '16 Highlander 3.5L V6 2GRFE engine. I've not been able to locate either in a store to visually inspect. For example, construction quality & COO.
Thank you.
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4446890
07/01/17 05:20 PM
07/01/17 05:20 PM
Cincinnati
Chris Meutsch Offline
Cincinnati
2005 Honda CR-V EX, 263k
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4446960
07/01/17 07:30 PM
07/01/17 07:30 PM
Idaho
CT8 Offline
CT8  Offline
Idaho
Toyota filters?
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4446993
07/01/17 08:14 PM
07/01/17 08:14 PM
Bend, Oregon
Oregoonian Offline
Oregoonian  Offline
Bend, Oregon
A better filter choice would be the Fram Ultra....easy to get at Walmart and priced close to the AC Delco.
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4446995
07/01/17 08:15 PM
07/01/17 08:15 PM
USA
slacktide_bitog Offline
USA
Get the Mahle OX414D1. It's made in Austria smile
Other good choices are the M1C-251 and the Fram Ultra XG9972. Both are US-made. The M1 cartridge has metal end caps.
The Wix XP 57047XP is made in Poland.
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4447016
07/01/17 08:53 PM
07/01/17 08:53 PM
northern Alabama
northern Alabama
I had not considered the Mahle but will try to find it. Thanks. Edit: Wow, their website is horrible. Never mind I won't consider them if they make it that difficult to find the right oil filter.
Yep, looked at the Mobil 1 & saw the metal end caps & US origin. I've not been able to find a Fram Ultra XG9972 yet, but supposedly it's a really good filter & certainly a good price if it's all that it's cracked up to be.
Yep, found both Wix offerings.
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4447017
07/01/17 08:57 PM
07/01/17 08:57 PM
MN
WillsYoda Offline
WillsYoda  Offline
MN
The Fram Ultra XG9972 can be found online at walmart or amazon...
goo.gl/Tn2kQN
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: WillsYoda] #4447020
07/01/17 09:02 PM
07/01/17 09:02 PM
northern Alabama
northern Alabama
goo.gl/Tn2kQN
Of course. However, I want to look at the oil filter before I buy.
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4447041
07/01/17 09:52 PM
07/01/17 09:52 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
the XG 9972 is in stock at several Walmarts around me. Just look online and see if their are any stores around with them.
Or just order online and return it if you don't like it, although I have no idea why you would not like the Ultra.
1994 Honda VT1100: Peak 15w-40/PSL/2500 mile OCI
2002 Ford F150: GTX HM 5w-20/EcoGard Syn/1yr OCI
2012 Scion xB: QSUD 0w-20/CQ Blue/5k OCI
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4447064
07/01/17 10:46 PM
07/01/17 10:46 PM
USA
USA
eBay, Amazon, and Rock Auto smile
But if you insist on actually buying your filter at a regular store, Walmart has Fram Ultra, and Napa has the Wix filters (Gold = regular Wix, Platinum = XP)
As for Mahle, their filters are very good quality, despite the bad website. There is really no need to actually visually inspect, as long as it doesn;t arrive damaged, and the COO can be found online smile
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4447243
07/02/17 09:02 AM
07/02/17 09:02 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Wally around me also have the Mobil1 on the shelf.
It is good filter although the price are high.
There is also Toyota TRD filter that looks like the Mobil1 or more like Mobil1 looks like TRD filter.
For TRD, may have to check the local Toyota near you.
  • 2017 Toyota Sienna
Re: 2GRFE '16 Highlander 3.5L V6 Oil Filter [Re: benjamming] #4447472
07/02/17 02:00 PM
07/02/17 02:00 PM
northern Alabama
northern Alabama
I had not thought about the TRD filter. I'll look it up - thanks!
