2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
106 registered members (1978elcamino, 64bawagon, 69GTX, 97f150, 97prizm, 11 invisible), 1,710 guests, and 62 spiders.
Topics286,228
Posts4,904,684
Members67,582
Most Online2,967
Mar 10th, 2019
255/50r19 vs 255/45r19 #4445659
06/30/17 06:55 AM
06/30/17 06:55 AM
Ottawa, Ont CANADA
2K2AcuraTL Offline OP
Ottawa, Ont CANADA
Hi guys ( and gals ),
Presently doing some homework for replacing the OEM Michelins on my 13 DX.
My brand of preference is General Tires.. I am on my second set of Gen's on my TL [currently on RT43's] and have a set of 17" Gen Ultimax winter for the DX. This is my -go to- brand for tires.. however the OEM size RT43's is not offered... :-(.. but they do have a size that is close... the ratio is 45 instead of 50...
So my question is ..other than the speedo indicating a little faster than reality, is there anything else that would be adversely affected by this small difference in tire size? Is there a -show stopper- detail that I am not seeing?
Thanks for any shared info,
Cheers
J.
2002 Acura TL-P --- 2013 Acura MDX-Elite
Both on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445664
06/30/17 07:02 AM
06/30/17 07:02 AM
PENNSYLVANIA
JeepWJ19 Offline
JeepWJ19  Offline
PENNSYLVANIA
Cheers
J.
No
2002 Jeep WJ 4.0 | Mobil 1 HM 5w30 |
TG8A | 2.5" lift | 148k miles
Software Engineer :]
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445694
06/30/17 07:49 AM
06/30/17 07:49 AM
Ottawa, Ont CANADA
Ottawa, Ont CANADA
Also... If I may add to this little quandary, I can also see some tires that are 245 in the 45 ratio.. rather than the prescribed 255.
Suspecting a slightly narrower tire will still be acceptable??
Or am I pushing thing a little too far now..?
Thanks
J.
1984 Firebird SE
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445696
06/30/17 07:53 AM
06/30/17 07:53 AM
MA, USA
krzyss Offline
krzyss  Offline
MA, USA
What about load index?
Krzys
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445697
06/30/17 07:53 AM
06/30/17 07:53 AM
PA
d00df00d Online content
d00df00d  Online Content
PA
1. Wheels spinning faster = more wear-and-tear on everything from your engine to your wheel bearings
2. Anything that depends on wheel speed -- ABS, stability control, AWD torque split if applicable, etc. -- might not operate quite as it should
3. Smaller overall diameter = less rubber on the road, because the contact patch isn't as long front-to-back
Any show-stoppers here? Doubtful. Unless you have to do an emergency stop or swerve, most of the effects will be very slight. There probably won't be any single event, or anything you'd notice in the short term. But a lot of things are affected.
I certainly understand wanting to stick with your go-to brand. I have my own go-tos, and I usually don't want to stray from them. But I'd never buy the wrong size just to get the right brand.
2008 BMW M3 Sedan 6MT
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445700
06/30/17 07:56 AM
06/30/17 07:56 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
The load rating is lower on the 45 profile tire than what's on the door sticker, so perhaps a tire shop may give you grief about it. The MDX is surprisingly porky at 4700lbs and a 98V load/speed rated tire only gives you 3300lbs per axle, so with 5000lbs towing and a decent cargo load you might be running very close to the rated capacity of the tire, plus your camber and toe in the rear will be terrible with a good load on, which heats up the tire more...
If you had the 18" rims then those tires have almost a ton more in load capacity and you have more load room to run smaller tires on those rims.
If you never tow, and never carry a heavy load of people, and you are the only driver, then sure you could get away with it. But especially as the tires age, you could get into trouble with a big load and doing 80mph on tires just above TPMS warning pressure on a hot day...
I actually run slightly undersize tires on my Focus, but it doesn't have the load capacity to get into too much trouble and I run them 4-5psi above the door sticker, but if I sell it, I'd slap a set of the right size tires on it, as the tires I have on it are no longer idiot proof.
07 Focus ZXW, 5spd manual, 230km M1 5W30
18 Outback 2.5 CVT 22km 0W20
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445709
06/30/17 08:01 AM
06/30/17 08:01 AM
socal
barkingspider Offline
socal
If my favorite brand of tire did not make the correct size, I would go to another brand that does carry it. And I prefer to stay at 50 series in your case vs 45. Perhaps 55 for a better ride if it fits
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 255/50r19 vs 255/45r19 [Re: barkingspider] #4445720
06/30/17 08:18 AM
06/30/17 08:18 AM
PA
PA
Reading this reminded me of something I had forgotten: a shorter sidewall means a less compliant ride, more noise, and greater risk of wheel or suspension damage when you hit a pothole.
Re: 255/50r19 vs 255/45r19 [Re: IndyIan] #4445734
06/30/17 08:29 AM
06/30/17 08:29 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
OP is also in Ontario, and our laws now state you must not go below the door sticker load rating. Vehicle will fail a safety inspection, and can actually get ticketed on the road.
I second the opinion that if your favourite tire does not come in the right size, find a different tire.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445735
06/30/17 08:29 AM
06/30/17 08:29 AM
Ottawa, Ont CANADA
Ottawa, Ont CANADA
Ah right . thanks for the reminder of the load index... door sticker states 103 and how heat may quickly come into factor.
Towing may be in the picture in the future [ reg utility trailer ] and we can fill this MDX at times with my 2 sons and the back filled with supllies for the week-end trip to the cottage.
here are two proponents I am looking at;
RT43 is - 45 255/45R19 104V SL BSW
and
GMAX 03 - 50 245/50ZR19 105W XL BSW
Pirelli, Conti, Yoko, offer correct sized tires..but the selection for 19" rims bite..!
1984 Firebird SE
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445736
06/30/17 08:32 AM
06/30/17 08:32 AM
Ontario, Canada
Ontario, Canada
and
I have driven many MDX where the owners have put XL tires on to replace the SL tires. The ride is horrible, it is like driving a dump truck. Although, I am surprised the 105 is considered XL.
Mighty Mouse Tech
Re: 255/50r19 vs 255/45r19 [Re: mightymousetech] #4445739
06/30/17 08:36 AM
06/30/17 08:36 AM
Ottawa, Ont CANADA
Ottawa, Ont CANADA
Ah I did not realized that..! luckly the tires I am looking are above the recommended load rating.
1984 Firebird SE
Re: 255/50r19 vs 255/45r19 [Re: 2K2AcuraTL] #4445760
06/30/17 08:56 AM
06/30/17 08:56 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
XL tires may need to be inflated higher to get the same load rating as SL tires. See page 11
Another one with tables
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: 255/50r19 vs 255/45r19 [Re: LotI] #4445776
06/30/17 09:15 AM
06/30/17 09:15 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Yeah, I was going to comment on the same thing.
And the tire shop is likely not to want to go there either!
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: 255/50r19 vs 255/45r19 [Re: mightymousetech] #4445811
06/30/17 09:44 AM
06/30/17 09:44 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
The law here states,
A tire fitted on a vehicle shall not,
(a) be of a smaller size than the vehicle manufacturer’s specified minimum size; or
(b) contact any vehicle component so as to affect the safe operation of the vehicle. R.R.O. 1990, Reg. 625, s. 5.
So if you are getting a wider lower profile tires on the same rims, I'm not sure what that means. I bet you are right though, in that the load rating is what inspectors worry about.
We discussed my undersized tires here and it was sort of agreed that a tires durability is a combination of its load rating and speed rating. So going slightly lower in load rating but way up in speed rating is probably getting you a more load resistant tire provided you keep it inflated.
