Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
127 registered members (benjy, Altima2, Benzadmiral, Bailes1992, aquariuscsm, Alfred_B, 8 invisible), 2,239 guests, and 62 spiders.
Topics286,397
Posts4,907,578
Members67,614
Most Online2,967
Mar 10th, 2019
Which Tire Repair Kit? #4442747
06/27/17 12:23 PM
06/27/17 12:23 PM
WV
BlindBaby Offline OP
WV
In addition to a properly inflated spare, Viair compressor, etc., I'm looking for a tire repair kit to put in all of my vehicles.
I've seen plugs, mushrooms, you name it. What type of tire repair kit would you recommend for plugging holes in the tread area? Any other tools such as needle-nose pliers that would make the job easier?
Thanks.
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442771
06/27/17 12:42 PM
06/27/17 12:42 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Any basic kit should do. You'll need to provide pliers.
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442780
06/27/17 12:53 PM
06/27/17 12:53 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
You'll need:
1. The T-handle rasp to bore out the steel plies so they don't catch on the plug.
2. The T-handle plug inserter.
3. The plugs.
4. Pliers to remove the foreign object.
5. Optionally they sell a vulcanizing agent which is like rubber cement in a little can with an applicator. I like to put this all over the hole, on the plug and insert it in. Once it's all done and I cut the tail ends of the plug off, I put the vulcanizing agent all over the plug too. The VA also acts like a lubricant to make it easier to push and pull on the plug.
You probably won't find any other style of tire kit. The plug ones are most common and very cheap and always got the job done for me.
2015 Civic LX Coupe
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442792
06/27/17 01:03 PM
06/27/17 01:03 PM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
I'm not a fan of plugs, they can get you to a repair shop but I've never had a plug that did not fully leak over night.
They make these 2 part patches for tires. It's a little more work and probably can't be done on the side of the road but basically it's used on the inside of the tire. You clean the hole area then you place the first patch on it and role over it with the needle tool. It releases the adhesive on the inside of the first path. You then put the second patch on and use the tool again and it fuses the patches into the tire.
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442793
06/27/17 01:08 PM
06/27/17 01:08 PM
WV
WV
Any thoughts on the Dynaplug ?
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442804
06/27/17 01:14 PM
06/27/17 01:14 PM
Lemont IL
Fattylocks Offline
Fattylocks  Offline
Lemont IL
The kits that Walmart sells work out fine. Get the better one with the T-handle tools. If you need anything extra a pliers might be good to have to pull out the offending object and straight edge razor blade comes in handy to trim the plug flush with the tire.
94 Caprice Wagon Daily driver
05 Focus Wagon 2.0 Duratech Thrifty city car
05 P71 ex Homeland Security emergency Beagle cruiser
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442859
06/27/17 02:08 PM
06/27/17 02:08 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Get a quality kit with the red plugs. Mine cost about $30. I have put many thousands of miles on my plugs and never had one leak yet.
http://m.ebay.com/itm/281907908784
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442877
06/27/17 02:36 PM
06/27/17 02:36 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
+1 Fattylocks. I used to live in Lamont IL when I worked at Argonne Labs. Ed
CX5 Touring 2.5L :-)
Re: Which Tire Repair Kit? [Re: BlindBaby] #4442963
06/27/17 04:15 PM
06/27/17 04:15 PM
Philadelphia PA
SKVenture Offline
SKVenture  Offline
Philadelphia PA
Thanks.
No better substitute.
https://www.amazon.com/ARB-10000010-Orange-Speedy-Repair/dp/B004P91FCO
Re: Which Tire Repair Kit? [Re: Fattylocks] #4442967
06/27/17 04:19 PM
06/27/17 04:19 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Walmart does a good job with flat repairs. They put a plug in that melds right into the tread. This happened shortly after I bought the tires and that was 60k miles ago with no issues.
Re: Which Tire Repair Kit? [Re: BlindBaby] #4443037
06/27/17 06:08 PM
06/27/17 06:08 PM
Reno, Nevada
Langanobob Offline
Langanobob  Offline
Reno, Nevada
I use this Safety Seal kit. Dozens of repairs on mine and friend's tires without a problem. Looks similar to the ARB kit suggested by SKVenture which is probably also a good kit.
Safety Seal
Re: Which Tire Repair Kit? [Re: BlindBaby] #4443051
06/27/17 06:21 PM
06/27/17 06:21 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I am looking at one myself, I like the idea of not rasping the hole out much bigger than a small nail, basically it doesn't seem to do any more damage than already done. Even if a temp fix it wont make more of a mess so the proper patch plug patch can be used. This one is SS is on my list.
http://www.dynaplug.com/pro_xtreme.html
Re: Which Tire Repair Kit? [Re: Fattylocks] #4443057
06/27/17 06:29 PM
06/27/17 06:29 PM
new jersey
jrvn Offline
jrvn  Offline
new jersey
this
Re: Which Tire Repair Kit? [Re: BlindBaby] #4443109
06/27/17 07:29 PM
06/27/17 07:29 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
The ones that Walmart will normally work but I have broken the T-Handle then it becomes a real pain to work with. Fortunately I was at work and able to use a drill to ream out the hole. I do like the looks of the Dynaplug which require no reaming to create more damage. nice design but I have not used them. Never had any issues with the standard plugs but definitely prefer the long stringy type over the round rubber ones that resemble a valve stem.
96 Grand Marquis
01 Sable LS
02 Montero
Re: Which Tire Repair Kit? [Re: 3800Series] #4443280
06/27/17 10:47 PM
06/27/17 10:47 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You're doing something wrong.
I have one had plugged tire leak for every 80-90 that don't leak, not even the tiniest bit.
Maybe don't ream the hole so much?
