Mobile 1 ESP @ Dowler Karn St. Thomas Ont
by RogerBacon. 09/24/18 05:40 AM
Mobile 1 ESP @ Dowler Karn St. Thomas Ont.
by RogerBacon. 09/24/18 05:37 AM
Direct Injection Valve Cleaning Maintenance
by RayCJ. 09/24/18 05:20 AM
Chattanooga tn ,cycling
by CourierDriver. 09/24/18 04:42 AM
Sunrise, Sunset
by csandste. 09/24/18 02:39 AM
Adding fuel filter- Generator built with no filter
by rubberchicken. 09/23/18 09:57 PM
Clutch Engaging too low
by Spetz. 09/23/18 09:41 PM
SMA - Krown previously, Fluid Film Application
by StevieC. 09/23/18 09:21 PM
First Paint Correction
by RayCJ. 09/23/18 08:33 PM
2011 Dodge Caliber
by dogememe. 09/23/18 07:48 PM
Mixing transmission fluids - partial change
by spk2000. 09/23/18 07:31 PM
Counterfeit MANN filter???
by IllinoisSparky. 09/23/18 06:54 PM
The smell of an oil: VME adds?
by fdcg27. 09/23/18 06:48 PM
Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Lilshady, SevenDu, sigpro, RayCJ, yellow97tt6spd
66055 Registered Users
46 registered members (asiancivicmaniac, Armkb, 10ecfarmer, alarmguy, 77GrandPrix, Astro_Guy, 3 invisible), 923 guests, and 44 spiders.
Topics290,926
Posts4,852,588
Members66,055
Most Online3,590
Jan 24th, 2017
2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles #4442313
06/26/17 08:42 PM
06/26/17 08:42 PM
USA
AITG Offline OP
AITG  Offline OP
USA
Code:
Mileage 19500 29230 38960 48835 58455 68060 77830 87655 97790 107275 116965
On oil   9110  9730  9730  9875  9620  9605  9770  9825 10145   9485   9690
Fe        17    13    19    17    15    10    31    14    17      17     29
Cr         0     0     0     0     0     0     0     0     0       0      0
Ni         1     0     0     0     0     0     0     0     0       0      0
Al         5     6     4     4     2     3     4     3     4       3      4
Cu         2     1     1     1     1     0     1     1     0       0      0
Pb         0     0     0     0     1     1     0     0     0       0      0
Sn         0     0     0     0     0     0     0     0     0       0      0
Cd         0     0     0     0     0     0     0     0     0       0      0
Ag         0     0     0     0     0     0     0     1     0       0      0
V          0     0     0     0     0     0     0     0     0       0      0
Si        17    16    15    11    10    11     9    13    11      11     10
Na         5     3     3     2     6     3     4     3     3       3      3
K          2     1     5     0     0     0     3     2     3       7      0
Ti       120   105   105    97   106    98    94   109   113     111    106
Mo        86    81    84    72    80    57    24    19    18      17     18
Sb         0     0     0     0     0     2     1     0     1       1      0
Mn         6     3     9     9     1     1     1     1     1       1      1
Li         0     0     0     0     0     0     0     0     0       0      0
B         59    43    53    39    58    31    33    36    39      38     41
Mg         7     9     9     9     9     9    10    10     9       9     11
Ca      2664  2428  2325  2196  2458  2174  2179  2468  2278    2436   2282
Ba         0     0     0     0     0     0     0     0     0       0      0
P        792   661   661   641   690   652   702   758   723     715    719
Zn       883   781   753   729   790   765   757   905   831     822    772
Fuel dilution<.1 <.1 <.1   <.1   <.1   <.1   <.1   <.1  <.1      <.1    <.1
Soot     <.1   <.1   <.1   <.1   <.1   <.1   <.1   <.1  <.1      <.1    <.1
Water    <.1   <.1   <.1   <.1   <.1   <.1   <.1   <.1  <.1      <.1    <.1
Vis 100C cSt8.1 8.1  8.0   8.3   8.4   8.0   8.0   8.2  8.2      8.0    7.9
TAN                  4.7  4.34   2.83
TBN            .10  1.56  1.45    2.6
IOLM <5%. Iron is slightly up, like it was last winter. Overall, pretty boring but we're well on the way to 200k.
The answer to 80% of BITOG questions: Read the book, follow directions.
Changing oil is not maintenance. Maintenance is the science of inspecting equipment to find and fix things before they break.
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: AITG] #4442335
06/26/17 08:56 PM
06/26/17 08:56 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
Very consistent numbers
thumbsup
The moly seems to trail off after the first five reports. Formulation change or different oil?
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: Seventh] #4442338
06/26/17 08:57 PM
06/26/17 08:57 PM
USA
AITG Offline OP
AITG  Offline OP
USA
thumbsup
Nope, same oil from the first change.
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: AITG] #4442354
06/26/17 09:08 PM
06/26/17 09:08 PM
NorCal
Seventh Offline
Seventh  Offline
NorCal
thumbsup
I figured so, since the titanium stays so consistent, and that's Kendall's signature thing.
It's working great for you
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: AITG] #4442382
06/26/17 09:37 PM
06/26/17 09:37 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Thanks for sharing.
Consistent readings.
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: AITG] #4442479
06/27/17 04:51 AM
06/27/17 04:51 AM
Down Under
SR5 Offline
SR5  Offline
Down Under
A good oil, working well for you.
Thanks for the post.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: AITG] #4442521
06/27/17 06:29 AM
06/27/17 06:29 AM
Indianapolis, IN
dnewton3 Online content
dnewton3  Online Content
Indianapolis, IN
My thoughts:
I must say that's a nice trend going there. Kudos and keep at it. While you're a far distance from being able to ascertain a micro study, you're numbers compare very favorably to macro data. The 5.0L Coy motor is a good engine for sure. You could certainly stretch out the OCIs further as a test if you wanted. I realize you may not be comfortable with that, but the data shows it's worth consideration. Wear rates are very low, contamination is essentially non-existent, and other parameters (vis, acid/base) are showing no ill effects to wear.
What others might say:
If you believed some other folks on this site, then your oil is "shagged" and worthless and you should have OCId far sooner on every cycle because the few samples that you did with TBN/TAN clearly show the oil flipping (inverting, cross-over, whatever one wishes to call it ...). So, despite the incredibly consistent wear performance and desirable outputs, regardless of the low contamination, your inputs show you're a fool. You'd better hurry up and change the oil more often or your engine will most certainly self-destruct, according to their mantra. Your oil acid/base are inverting probably around that exposure. If we were to believe them, you should OCI every 5k miles, just going on the inputs that are out of their defined specs.
What's the difference in the two viewpoints?
I focus on results. I look at a lube/engine combination and analyze the relationship in terms of the lube's purpose; that being the lube is there to serve the engine. If the engine is happy, then the lube it doing it's job; that of reducing wear. When an input changes but the output does not change, it's reasonable to logically deduce that the input is NOT a controlling factor in wear, at least at that stage. Although acid flipped base, nothing bad happened. I focus on outputs, and use inputs to initial more scrutiny if warranted. Inputs are important, but not as a cause to OCI; rather as a trigger to pay ever closer attention to what's going on. Something that goes out of spec may or may not create an immediate causation to OCI; one needs to look with open eyes and not blind obedience to some spec.
Other focus on inputs. They look at a lube and give highest consideration to the lube's properties; that being regardless of how the engine is reacting, it's only the lube properties that should trigger an OCI. So despite the fact that wear is under control and there is no contamination present, they would change oil due acid in your UOAs. If you were to UOA a few times at 5k miles, we'd be able to determine of that was often enough, or maybe even more often? If wear is low, but the vis is out of grade, then OCI. If wear is high, but vis is on-spec, then don't OCI. They focus on the inputs, and don't want to give credence to the outputs. They believe that wear metals do not tell a tale worthy of listening to, and therefore ignore wear data and focus only on the lube parameters (such as vis, FP, acid/base, etc).
So depending upon what paradigm you want to believe, the UOAs indicate that your engine is either doing great, or about to self-destruct.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: AITG] #4442612
06/27/17 08:55 AM
06/27/17 08:55 AM
Ontario, Canada
MobilinHyundia Offline
Ontario, Canada
All my oil changes get done at 20 000 km (12 000 miles) intervals minimum.
2009 Sonata GL 2.4L (226000km)-QS FS 5W20 ,OEM oil filter
2009 Sonata LTD 2.4L (170000km)Castrol Egde 5W20, RP filter
24000km/15000 mile oci so far
Re: 2011 F150-5.0V8 Kendall GT1 5W-20-9690 miles [Re: dnewton3] #4442701
06/27/17 11:08 AM
06/27/17 11:08 AM
USA
AITG Offline OP
AITG  Offline OP
USA
Originally Posted By: dnewton3
My thoughts:
I always value your input on the subject. I look at stretching drain intervals a little differently. Maintenance is not changing oil. Maintenance is about inspecting the vehicle thoroughly to find things that need attention and making repairs before they cause problems. From that standpoint, I don't want to go over 10k without taking a good, careful inspection of CV boots (4WD), wheel seals, fluid leaks, corrosion issues and anything else that indicates a coming repair. As long as I'm under there changing the oil is no big deal.
