Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
New plants around the yard
by gregk24. 03/19/19 03:24 PM
New Nissan Titan XD w/5.6l oil choices
by josephp732. 03/19/19 03:20 PM
Gran Prix Tour RS tires
by HangFire. 03/19/19 01:50 PM
Look How Good Our Cars Are Getting!
by ekpolk. 03/19/19 11:49 AM
Good or bad? Special ordering a brand new car?
by Ed_Flecko. 03/19/19 11:49 AM
Good Purchase?
by FordBroncoVWJeta. 03/19/19 11:33 AM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
138 registered members (4WD, 92saturnsl2, 77GrandPrix, 01rangerxl, 1foxracing, 2015_PSD, 11 invisible), 2,023 guests, and 51 spiders.
Topics286,086
Posts4,902,285
Members67,560
Most Online2,967
Mar 10th, 2019
Need help with rear wheel hub; bolt snapped #4441957
06/26/17 01:04 PM
06/26/17 01:04 PM
illinois
nolan7120 Offline OP
illinois
I was in the process of trying to change my parking brake shoes on my 2009 Hyundai Elantra when I accidentally snapped off a bolt head of one of the 4 bolts required to remove the hub (rear passenger side, bottom left bolt if you are looking at the hub). The other three came out just fine. This style of parking brake is one of those mini drum types on the inside of the rear rotor.
If the axle flange doesn't have threads (and only the hub flange does), I think I may be able to still remove the wheel hub. I tried yesterday by banging the [censored] out of it but had no luck. I'd rather not beat it into a pulp because I want to reuse the hub after working on the parking brake.
My next course of action is to go rent a slide hammer and to just try the other side. That way I can know for sure if there are no threads on the axle flange (and therefore wasting my time on the other side by trying to beat it out with a stuck bolt body still present). I'm also going to get some PB Blaster and see if that helps because I was using WD-40. I think I may have some Kroil around but that will be more of a pain in the butt to apply.
Has anyone snapped off one of the bolt heads while trying to remove a wheel hub? If I try to drill it out from behind the axle flange, there are various suspension components in the way that I'd have to remove even to get a decent angle on the broken bolt. I've never tried that before and wouldn't want a broken bolt on a funky angle to be my first attempt. Any suggestions on what to do next?
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4441968
06/26/17 01:27 PM
06/26/17 01:27 PM
Ontario Canada
cjcride Offline
cjcride  Offline
Ontario Canada
Try Hyundai-Forums.com
Welcome
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4441986
06/26/17 01:56 PM
06/26/17 01:56 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
You weld on a nut or bolt to what is there.
Impact wrenches often get off bolts/nuts where a breaker bar snaps it.
2015 Ford F250 w/Powerstroke
Re: Need help with rear wheel hub; bolt snapped [Re: Donald] #4442070
06/26/17 03:32 PM
06/26/17 03:32 PM
Gulf Coast, MS
3800Series Offline
3800Series  Offline
Gulf Coast, MS
This been there a few times.
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4442078
06/26/17 03:44 PM
06/26/17 03:44 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Both parts cant be threaded. If the bolts go in from behind only the hub is threaded, if the bolts go in from the front through the hub then the stub axle flange is threaded.
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4442198
06/26/17 06:29 PM
06/26/17 06:29 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Your description is astute, but we would still be well-served by a picture.
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4442210
06/26/17 06:41 PM
06/26/17 06:41 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Why the hub removal just for P-brake service?
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4442290
06/26/17 08:26 PM
06/26/17 08:26 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Heat and wax in combination are supposed to be effective looseners.
Re: Need help with rear wheel hub; bolt snapped [Re: cjcride] #4442396
06/26/17 10:09 PM
06/26/17 10:09 PM
illinois
illinois
Welcome
Tried Hyundai Forums but no response. I didn't start a new thread though; only updated an old one so maybe that's why.
Re: Need help with rear wheel hub; bolt snapped [Re: Trav] #4442397
06/26/17 10:11 PM
06/26/17 10:11 PM
illinois
illinois
You're right, only the wheel hub is threaded. After getting the thing off today, I was able to peer in the hole and it looked like there were threads in there due to all the rust buildup but low and behold there wasn't.
Re: Need help with rear wheel hub; bolt snapped [Re: JTK] #4442398
06/26/17 10:13 PM
06/26/17 10:13 PM
illinois
illinois
Because it's an absolute pain in the [censored] to do with the hub in the way. I was able to disassemble all the hardware today, but reassembly if I hadn't gotten the hub off would take me a really long time. Figured it's just easier to pop off the hub, service the parking brake, and pop it back on. The broken bolt decided otherwise!
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4442400
06/26/17 10:13 PM
06/26/17 10:13 PM
illinois
illinois
Success! To an extent at least. I ended up disassembling the parking brake hardware despite the wheel hub in the way.
I knew I wouldn't be able to reassemble it unless I was able to remove the hub. I borrowed a bolt extractor socket set from my ex's dad, and through one of the holes on the wheel hub, I was able to get it banged down nice and tight on the end of the bolt.
After heating the surrounding area, I was able to move the bolt forward like a 1/2", and suddenly it came to a dead stop. I removed the extractor socket, popped on the slide hammer I rented from Autozone, and was able to pull the hub off on the 2nd try. At this point, the bolt was still stuck in the hub.
I took the hub over to my ex's dad's house because he has more tools and a better work space. After a solid 30-40 minutes of heating up the hub while in a vise and cranking the [censored] out of the bolt with various tools (vise grips, pipe wrench, channel locks, and finally an extractor socket coupled with a huge ratchet), the [censored] thing came out.
My only issue now is 2 of the 4 holes on the wheel hub feel like they have buggered up threads. I tested all 3 remaining bolts in both holes and they won't go in more than one turn before I encountered resistance. So tomorrow to start the day off I get to fix the threads on the hub, which I've never done before. My ex's dad can't help me there as he only has a SAE tap and die set. I either need to 1) Find and pay someone to do it, 2) try it myself, or 3) buy a new hub.
Re: Need help with rear wheel hub; bolt snapped [Re: nolan7120] #4442438
06/27/17 12:29 AM
06/27/17 12:29 AM
Trav Offline
Trav  Offline
IF I were doing this job I would replace the hub, all that heating with a torch may have buggered the bearing grease and a new hub may be in the cards sooner than later anyway.
Well done getting it apart. nice save. thumbsup
Re: Need help with rear wheel hub; bolt snapped [Re: Trav] #4442491
06/27/17 05:21 AM
06/27/17 05:21 AM
Pennsylvania
bugeye Offline
bugeye  Offline
Pennsylvania
Suggest following Trav's advice. New hub. Use never seize on the bolts. Hubs are cheap relative to the hassle of changing as you found. Don't want a future bearing failure.
Re: Need help with rear wheel hub; bolt snapped [Re: Trav] #4442553
06/27/17 07:28 AM
06/27/17 07:28 AM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
Agreed. Either the grease got messed up, or the seal was damaged, which will let water and foreign debris in which will ruin the bearing too.
Don't buy the $49.99 bearing from Autozone or Advance Auto either. Buy OE, SKF, BCA, Timken or other premium grade part.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
