2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
80 registered members (A310, advocate, 2009Edge, ABomb369, 2013ecof150, 1JCB, 6 invisible), 1,271 guests, and 37 spiders.
Topics290,627
Posts4,847,676
Members66,011
Most Online3,590
Jan 24th, 2017
Non-ethanol 87 mixed with 100LL to raise octane #4433659
06/16/17 07:41 PM
06/16/17 07:41 PM
Va
i6pwr Offline OP
i6pwr  Offline OP
Va
Brief history....I have a restored JD 212 with the K301 Kohler that I also rebuilt about 1 1/2 years ago. I have been using non-ethanol 87 from a frequently used pump and have had the timing set at 14 deg BTDC.
I wanted to use a more retarded timing than the spec'd 20 deg adv for a good while until I had about 100 hours on the motor. Not that this is normal practice, but since it had adequate power I just left it alone. So I have it set now at 18-19 deg adv and I would like opinions on using higher octane fuel to reduce the chance of possible detonation when it's working hard. Another factor would be the added lead content for the valves. I had them ground, but still retain the original seats.
Perhaps the higher octane is not needed, but if so, would mixing some 100LL with the non-ethanol 87 be a good idea? I would also use the mixed fuel for other equipment like my KM-110 trimmer and a couple Husky saws.
I really don't want any of the 89 or 93 from the gas stations....no telling how long that 93 sits in the tanks, and to make 89, 93 is generally mixed with the 87 at the pump....and it's an ethanol blend.
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433681
06/16/17 08:01 PM
06/16/17 08:01 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The K301 is going to be a terribly durable engine. Running E-free in it is a good idea, but it does not need particularly high octane. The E-free regular should be more than adequate with factory timing.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433732
06/16/17 08:58 PM
06/16/17 08:58 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
100LL is not really low lead, very bad idea compared to just using 87 octane e0
You would risk lead buildup and lead fouling of the spark plugs etc.
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433744
06/16/17 09:07 PM
06/16/17 09:07 PM
San Antonio, TX
Nyogtha Offline
Nyogtha  Offline
San Antonio, TX
IIRC from my Blendineer days 100LL has 2 or slightly above 2 g/gal max lead content, vs. old school leaded pump gasoline and NASCAR /TORCO furls having 4 g/gal max lead content. That was a number of years ago but doubtful it's changed much if at all.
Seasonal volatility requrements for pump gas makes for decent turnover in my experience. However pump sales volumes, and thus terminal order volumes for station delivery, tend to be lower in less affluent areas for higher octane products.
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433835
06/16/17 11:18 PM
06/16/17 11:18 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
If you replaced all fuel lines during the re-build, just use mid-grade.
E-10 won't harm the valve seats, that generally shows up at higher RPMs, and
this is likely governed to 3300-3600 RPM.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433871
06/17/17 12:15 AM
06/17/17 12:15 AM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Race-Gas can bump the octane
http://race-gas.com/
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433900
06/17/17 01:47 AM
06/17/17 01:47 AM
Kansan,1911 45ACP fan
Marco620 Offline
Marco620  Offline
0 ethanol has 3rd more energy per BTU. Great choice.
15' Civic 179k.0w20 Redline/Archoil9100,Eibach,Yokohama/Borla Exhaust/Tein Suspension/Fu7317/Redline Si-1
Right to work state proud. Non union household
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4433950
06/17/17 05:55 AM
06/17/17 05:55 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
A little lead goes a VERY long way.(for valve recession)
100LL mixed 1:20 (or even 1:30) with unleaded will give you what the pumps were selling in the very early 90's.
The Kohler engine is relatively low compression - you should be able to bump the timing up to 24 on 87-E0 and not get any detonation.
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: dwendt44] #4434038
06/17/17 08:37 AM
06/17/17 08:37 AM
Va
i6pwr Offline OP
i6pwr  Offline OP
Va
Yes, all lines were replaced and it's governed @ 3600. But I will try at all costs to avoid "E"vil 10 pump gas in my small engines unless I know I'm going to consume it within a week....or that weekend... wink
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4434052
06/17/17 08:50 AM
06/17/17 08:50 AM
Iowa
The_Eric Offline
The_Eric  Offline
Iowa
Evil E10? Whatever. That's all I have ran for years. No stabilizers, no magic potions, no yearly or weekly carb repairs, no replacing fuel lines every other year or any of the other bologna I read about here. I just add it to the tank and mow. I even let it set in the tank over the winter and it still, by some miracle, starts in the spring.
You have a robust old piece of equipment with low compression- you could get the town drunk to take a leak in the tank after a good bender and it'd probably still run fine. Set the timing to spec and enjoy life.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: The_Eric] #4434065
06/17/17 09:03 AM
06/17/17 09:03 AM
Va
i6pwr Offline OP
i6pwr  Offline OP
Va
Ha...you're prob right...lol.
I agree E 10 isn't always bad, my FH430V starts all the time on it, the trimmers tend to stumble if it sits for a month or so. The JD JX-75 push mower hates it and I need to drain the float often. The Kohler will pop at idle sometimes if the E 10 sits for awhile, but E0 runs perfect in everything even siting over the winter, the Kohler pops to life immediately if the E0 has been in the tank for 3 months.
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4434105
06/17/17 09:53 AM
06/17/17 09:53 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
My '74 Economy Jim Dandy with a K321 ran fine on any of the fuels I put in it, but my '61 Power King with a Briggs 23 despises ethanol. I've never been through the carb. on it so maybe a kit with improved materials would help its tolerance for ethanol, but I've had E-free available every place I've lived since owning it so it gets it whenever possible. But during the times your machine is frequently used I'd go for higher octane with ethanol over E-free regular.
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4434239
06/17/17 12:43 PM
06/17/17 12:43 PM
Ottumwa, Iowa
jhellwig Offline
jhellwig  Offline
Ottumwa, Iowa
There is no need to modify the timing if you haven't changed anything else with the motor. Regular gas is fine.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: Marco620] #4434382
06/17/17 03:04 PM
06/17/17 03:04 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
No it doesnt. That makes no sense.. more energy per btu?
now if you meant more btu per gallon.. you would still be wrong..
because with 10% ethanol mix its more like 3-5%
Straight gas "e0" is about 114k-115k btu/gal
10% ethanol gas is around 110k-111k btu/gal
Re: Non-ethanol 87 mixed with 100LL to raise octane [Re: i6pwr] #4448390
07/03/17 02:16 PM
07/03/17 02:16 PM
Indiana
Indy2door Offline
Indy2door  Offline
Indiana
If there ever was a post about being anal this one has to be it.
