Originally Posted By: Shannow
Ahh, the old "advertorials are science" thing again...
Originally Posted By: Mobil Advertorial
3. The oil pump
In the oil pump, energy loss occurs due to rotational energy consumed by pumping heavier viscosity oils, particularly during warm-up. That’s why we’ve seen the trend of lower viscosity oils, such as 0W-30 and 0W-20.
Each time this advertorial is bought up, that's one bunk "fact" that stands out like dog's cods...
the difference between 60 and 80psi in an average oil system is in the 10s of watts...turn off your headlights, and you'll nett far more fuel economy than the oil pump impact that these articles hang their hat on.
The ACTUAL reason (sorry Mobil) is the viscous friction in bearing areas (bearings, pistons, rings, and to an extent cams etc.)...but these are "additional friction" areas according to Mobil's advertorial.
Camshaft wear...additives.
I'd be interested in actual claims of performance difference between
http://www.mobil.com/english-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-5W30
and
http://www.mobil.com/english-US/Passenger-Vehicle-Lube/pds/GLXXMobil-1-0W30
KV40 61.7 vs 62.9 (AFE 0W30 is the bigger of these two "startup" numbers).
KV100 11 vas 10.9
HTHS 3.1 versus 3.0
I don't think that either of these would even have a watt difference in "oil pump friction"
edit in microtype...
Originally Posted By: mobiladvertorial
Based on 0.2-2.3 percent potential fuel economy improvement obtained by switching from higher viscosity oils to a 0W-20 or 0W-30 grade. Actual savings are dependent upon vehicle/engine type, outside temperature, driving conditions and your current engine oil viscosity.
My actual MPG gain has been .5 to 1 compared to my Mpg when I first bought these vehicles using M1 5-30. The rest of your stuff is, well stuff to me. Sorry.
