Originally Posted By: TheBus36
I haven't been on this site in a long time and I hate to ask a question that has been previously answered somewhere on here however a search does not yield any results. Is ti okay to mix different brands of full synthetic of the same viscosity. I've done it over the years many times with conventional and have had no problems. Thanks.
They are all compatible, it's an API requirement.
But what does "COMPATIBLE" mean ?
The ASTM test procedure is to take the finished oil product, and mix it with 7 API reference oils. Each mix is then taken down to it's new gell point (note new gell point, there's no requirement for it to remain the same), then heated to 150C, then frozen again, and thawed.
To be "compatible", the mix of oils can't split like a salad dressing, nor drop out precipitates.
That's it...that's all it promises.
So the strongest likelihood is that your mixes won't split like salad dressing, nor blow chunks.
As to the mix
* meeting 0W
* behaving predictably in any of the online calculators
* being guaranteed to meet the same performance standards (e.g. SN, DEXOS, etc.)
You are on your own, and nothing guarantees that, nor requires that to be the case.
But there's a new BITOG performance standard that I'm amazed the industry hasn't adopted en masse, and it's the "nothing blew up" test, that is quoted daily these days.
