Re-using building materials esp nails
by andyd
06/18/18 08:57 AM
Central A/C [censored] out
by TOMJ
06/18/18 08:43 AM
08 Scion tC under valve cover pics
by Highboy
06/18/18 08:39 AM
Storing extension ladded in garage?
by maverickfhs
06/18/18 08:27 AM
Do you let your tool batteries go dead in storage
by Snagglefoot
06/18/18 07:20 AM
Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
WtsTacoma01, Orion62, Revd, blinky1041, mostdecent
65262 Registered Users
94 registered (Artem, Backwoods41695, billt460, badtlc, AndyB, 4WD, 8 invisible), 1535 Guests and 36 Spiders online.
65262 Members
67 Forums
285515 Topics
#4406135 - 05/16/17 11:50 AM Wiring driving lights
Drew99GT Offline
Loc: Colorado Springs
I'm looking at putting a driving light kit on my Corolla; how hard is the wiring installation? Here is the kit I'm considering:
https://www.amazon.com/Genuine-BlingLigh...iving+light+kit
Can something like that be easily wired into a key on circuit instead of directly to the battery???
Thanks
#4406139 - 05/16/17 11:57 AM Re: Wiring driving lights [Re: Drew99GT]
eljefino Offline
Loc: ME
I wired mine to the fuse for the electric seat heater in my camry. I have no such heater but it's keyed to ignition only. I just tapped the fuse on the "downstream" side so it's fused by the fuse.
Why are you going incandescent instead of LED?
#4406164 - 05/16/17 12:21 PM Re: Wiring driving lights [Re: Drew99GT]
UG_Passat Offline
Loc: NJ
driving lights due to their beam pattern should be only used with the high beams.
So, high beam power should be connected to the +12V of the included switch, then wired as normal.
Since the description of the item says: Genuine BlingLights 3 Inch Round Xtra 35w = 70w Fog Light Driving Lamp Kit (Non-Halo Version)
find out which one is it. If it's fog lights, then you can connect the parking light 12V to the switch 12V. If you want it off with the high beams, then you ground the relay to the high beam 12V. Otherwise, a chassis ground means it won't shut off with the high beams (check local laws)
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
#4406168 - 05/16/17 12:28 PM Re: Wiring driving lights [Re: Drew99GT]
AlaskaMike Offline
Loc: Alaska
Usually it's best to tap into the headlight circuits to trigger the relay, and as UG_Passat mentions, driving lights should come on with the high beams, and fogs with the low beams. When I've done this, I've always included a separate switch for the driving lights, but never felt that was needed with fog lights.
I realize that the kit you show includes a relay, but it's worth mentioning to never install supplemental lighting when tapping into an existing circuit without using a relay. You're virtually guaranteed to overload it.
#4406172 - 05/16/17 12:37 PM Re: Wiring driving lights [Re: Drew99GT]
Drew99GT Offline
So how do I tap into the factory headlight circuit? Do I need to splice wires? Sorry, I'm a total newb when it comes to anything electrical.
#4406275 - 05/16/17 02:51 PM Re: Wiring driving lights [Re: Drew99GT]
HerrStig Offline
Loc: Boston, MA
You get the current to run the relay from the headlight circuit and the power to run the lights themselves directly from the battery through a fuse. When the high beam (or low if fogs) circuit gets energized current goes to the relay which switches on power to your extra lights.
#4406480 - 05/16/17 06:38 PM Re: Wiring driving lights [Re: Drew99GT]
Mr Nice Offline
Loc: Orlando, FL
YouTube has lots of videos on what you want to do.
#4406896 - 05/17/17 09:16 AM Re: Wiring driving lights [Re: Drew99GT]
UG_Passat Offline
Loc: NJ
Yes & no.
If there is a fuse in the fuse box for the appropriate light, you can use those "add-a-fuse" kits to tap into it.
If you can't find a fuse, then you need to splice into wiring, Scotchloks are an easy way to do it.
#4407076 - 05/17/17 12:27 PM Re: Wiring driving lights [Re: Drew99GT]
SHOZ Offline
Loc: Illinois
I would not use the OE 12v as supply for the power. Most newer cars use a ground to control the relay coil. Relay is hooked directly to the battery through a fuse.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4407517 - 05/17/17 10:13 PM Re: Wiring driving lights [Re: Drew99GT]
901Memphis Offline
Loc: Northern Kentucky
I would shoot an email to Daniel stern he can give you very specific information for your model I bet.
He sells nice relay kits that are for this.
https://www.danielsternlighting.com/products/products.html
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
#4408166 - 05/18/17 06:56 PM Re: Wiring driving lights [Re: SHOZ]
HerrStig Offline
Loc: Boston, MA
So you put the coil for the aux lights in PARALLEL with the headlight relay coil.
#4408435 - 05/19/17 07:22 AM Re: Wiring driving lights [Re: Drew99GT]
SHOZ Offline
Loc: Illinois
My Hyundais use a ground from the OE switch to operate the lights. From the factory the fog light ground (I use them for driving lights) will only work with the low beams on. I rigged it so they can be switched on anytime the key is on.
The new relay I used for my HID fog lights has 12v+ fused power coming off always hot 12v+ for the #30 lug. I loop this to the coil 12v+ too so the coil is always hot. Then use the factory switch to apply ground to the coil.
#4492476 - 08/19/17 01:04 AM Re: Wiring driving lights [Re: Drew99GT]
purelux Offline
Loc: pennsylvania
I have my driving lights (harness, relay and extra inline fuse) wired directly to the battery and a ground. This way I can use them as needed alone, with low or high beam. Occasionally they work better and don't blind in heavy snow fall or fog. But mainly they are used with no oncoming traffic on unlit secondary roads.
