Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
53 registered members (1foxracing, 53' Stude, BeerCan, 4WD, 4 invisible), 1,219 guests, and 35 spiders.
Topics295,095
Posts4,927,734
Members66,684
Most Online2,553
Oct 27th, 2018
Initial review: Wagner OEX pads & AC Delco rotors #4376557
04/10/17 10:18 PM
04/10/17 10:18 PM
USA
stephen9666 Offline OP
USA
I recently installed a new set of Wagner OEX brake pads and AC Delco coated rotors. Here are my initial impressions after a couple hundred miles. Iíll be updating this as I get more miles on the combo.
Why I bought these pads:
-GG rated. The factory pads were FF.
-Made in the USA. The company says all the OEX pads are made in the USA.
-They use a traditional brake pad shims. I have read about some issues with the integrated insulators on the Wagner Thermoquiets, so I decided to try these.
Some notes about the OEX pads:
-Theyíre mainly aimed at trucks and SUVs, for some reason, but they do have applications for some cars.
-They fit fine. I didnít need to file the pad ears or anything.
-The included hardware all fit well.
These pads are performing well, but the friction material shape is gimmicky and isnít as tall as the OE pads (see pics below). Iíve read the smaller swept surface could lead to larger rust ridges at the edges of the rotor. That may not happen in my case, as I bought fully coated rotors where the coating is only worn off on the swept surface. I would prefer a normal friction material shape.
The rotors:
I wanted fully coated rotors, so I went with these AC Delco Advantage coated rotors. These rotors are fully coated, including the inside of the hat and down in the vanes. Theyíre made in China.
The machine work looks good and the installation went fine. We will see how the coating holds up. The zinc-based coating on these (at least I believe itís zinc based) does not appear as tough as the paint used on some rotors, but these rotors are fully coated vs. the partial painting used on some other rotors.
Rotor installation:
I cleaned both hubs with a wire brush and a wire wheel on a grinder -one side more thoroughly than the other, as youíll see later- and installed the rotors. I used my clamp-on HF runout gauge to check the runout. The factory spec on this vehicle is .002Ē runout max.
The passenger side, which was more thoroughly cleaned, came out .001 runout right off the bat, so it was good to go. The driverís side came out .0025. I took off the rotor and cleaned some additional rust I had missed off the hub. I checked the hub runout and it was .001 or less. I reinstalled the rotor 180 degrees from the initial installation point and got .001 runout.
Then I did a mild break-in, about a half-dozen mid-pressure decelerations, and then drove on normally. Some of the oft-quoted bedding methods online can be too aggressive for street pads. A mild bedding and normal driving is what works for me.
Overall impressions:
The performance so far of this combo has been very good. This combo has a strong initial and overall bite. They stop better than the OE pads. As of right now thereís no increase in noise over the OE pads. I canít comment on the dust right now, as I only have a couple hundred miles on these.
The Pads:
This is the total difference in height between the friction material on the OEX and original pads. There is not this much gap on the top and bottom. This is the total gap at the top and bottom added together.
The rotors:
Checking the runout:
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4376602
04/11/17 03:09 AM
04/11/17 03:09 AM
ROCHESTER, NY
Char Baby Online content
Char Baby  Online Content
ROCHESTER, NY
Hi,
I don't see the coating on the rotors. I am used to the BLACK E-Coating on some painted rotors.
Are the rotor hats & vents painted?
Is it a clear coat paint?
Or a silver paint that isn't showing up in pics?
smile Just asking,
CB
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4376632
04/11/17 05:31 AM
04/11/17 05:31 AM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
Looking good to me. The Acdelco Advantage rotors aren't painted you have to get the durastop (I think that's right) level rotors to get painted centers. I've had good luck with both. Also those are nice looking pads. All the thermoquiet ceramics I've gotten have been GG rated and Made in USA as well so I'm not surprised the OEX is the same. Good choices all around.
1988 F-150. 4.9 I6 247k. 10w-40 Castrol Syn-blend ACDelco UPF2.
2005 Cadillac STS N* 108k. 5w-30 Castrol Magnatec ACDelco Classic PF61
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4376711
04/11/17 07:12 AM
04/11/17 07:12 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Good thing you checked the run out. Too many people just slap the rotors on then complain they got garbage warped rotors. The coating last quite a while but be careful with wheel cleaners and never use something like purple power, it will damage the coating quickly.
Checking the run out and caliper and bracket alignment are the most important part of the brake job as far as keeping vibration due to uneven piston knock back, pulsation and noise to a minimum.
Many times on reman calipers with brackets included are reground on the mating surface and sometimes not vary accurately so the bracket does not sit square and needs to be corrected, if its not too bad a quick dressing with a file or thin shim will usually correct it other times the bracket needs replacement.
Interesting pads, post again as they get some miles on them.
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: Char Baby] #4376713
04/11/17 07:15 AM
04/11/17 07:15 AM
MN
Tman220 Offline
Tman220  Offline
MN
Originally Posted By: Char Baby
Hi,
smile Just asking,
CB
The zinc coating ACdelco uses for some rotors does have a silver look to it, it's much more durable and longer lasting than the gimmicky black paint other rotors have that doesn't last very long.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: nwjones18] #4376780
04/11/17 08:45 AM
04/11/17 08:45 AM
USA
USA
ACDelco now offers both plain and coated rotors in the Advantage line.
They still offer the painted rotors in the Professional line.
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4376893
04/11/17 11:13 AM
04/11/17 11:13 AM
Warner Robins, GA
nwjones18 Offline
nwjones18  Offline
Warner Robins, GA
Ahh interesting. I didn't know that.
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4378133
04/12/17 08:42 PM
04/12/17 08:42 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
Can you describe the tools that were used and the process of cleaning the rust off of the hubs?
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4378193
04/12/17 11:28 PM
04/12/17 11:28 PM
Specific Ocean
Kibitoshin Offline
Kibitoshin  Offline
Specific Ocean
I've been wanting to get a runout gauge to step up my brake service game. I maintain several vehicles and so far neither a complaint after doing a brake job.
Shin Gekiretsu Shin'ou'hou
01 Toyota Tundra 2WD V8 4.7L
02 Chevy Silverado C1500 V8 5.3L
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: Kibitoshin] #4378418
04/13/17 08:38 AM
04/13/17 08:38 AM
USA
USA
This one from HF works, but isn't great. It took some finagling to get it secured well enough to get an accurate reading. I still got a little needle shake, but it worked. I only paid $28 after a coupon for it, so not a bad deal.
http://www.harborfreight.com/clamping-dial-indicator-93051.html
If I had to do it over again I might try the kind with a magnetic articulated base, instead of this segmented kind.
http://www.harborfreight.com/multipositional-magnetic-base-with-fine-adjustment-5645.html
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: JamesBond] #4378434
04/13/17 08:56 AM
04/13/17 08:56 AM
USA
USA
I used a hand-held wire brush and an adjustable speed angle grinder with a cup brush. That's not the ideal tool for the job, but it's what I had and it worked.
There are specific kits you can buy for this job with abrasive disks that are donut shaped and fit over the stud. A lot of people also use a pneumatic angle grinder with an abrasive disk.
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4378962
04/13/17 08:03 PM
04/13/17 08:03 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
I use the magnetic base articulated arm, besides the magnet sometimes I C-clamp the base to something to get it to hold still. Mine isn't HF but might have come out of the same factory. I actually have my Grandad's Starrett indicator and a bunch of holders for it, but don't get it out for dirty stuff like brakes. Cheap stuff is good enough.
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4405746
05/15/17 07:59 PM
05/15/17 07:59 PM
USA
USA
I have a few thousand miles on these and they're working great. Smooth, quiet stops and plenty of braking power.
For people who were confused by the rotors, here's what they look like now. The pads scrub the zinc coating off the rotor on the braking surface.
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: stephen9666] #4450642
07/05/17 05:00 PM
07/05/17 05:00 PM
West Michigan
buck91 Offline
buck91  Offline
West Michigan
Still happy with these? Currently running Wagner TQ's on the truck with good results for many thousands of miles. Looking at options for my Wife's Explorer Sport and these have peaked my interest.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Initial review: Wagner OEX pads & AC Delco rotors [Re: buck91] #4496537
08/23/17 09:39 PM
08/23/17 09:39 PM
USA
USA
Yes, I'm really impressed with these. I have 6,000 miles on them so far. Very good and consistent braking with good initial bite. No noise that I can detect.
So far, so good. I'll update this more as I continue to add-on miles.
