MolaKule
Staff member
Originally Posted By: ecotourist
Your message was very timely. We just finished renovating a bathroom and within a few days the fan started making a lot of noise. I wondered about putting a drop of oil on the only accessible bearing and your message prompted me to do it.
The result - the noise is gone and the fan seems to be turning faster as well.
I used "Masters Lubricating Oiler" recommended for bearings and moving parts of pumps, motors, fans, compressors, etc. It's quite old; I've used it in the past on furnace fan motor bearings. Seems like about a 20 or 30 weight oil. We'll see how long this lasts.
Same here. I just oiled both bathroom fans about a month ago. The fans were 10 years old.
I used a 6 cSt PAO with a 32 cSt ester for about a 20 grade oil, no additives.
I don't like to use motor oils or oils with additives because if the oil does sling off, the sulfur-phosphorus AW components corrode the copper windings.
I used a 10 mL syringe with a small 0.5 mm medical tube to apply the oil, like two drops per bearing.
