Originally Posted By: wrcsixeight
On another forum I frequent, A poster who posts and knowledge I have learned to respect, recently said it is better to use Dex VI in any application that calls for ATF+4 as it is superior in every way and backwards compatible.
Call me Dubious.
What say you?
All the old Chrysler AT's used something called ATF, pretty much like what was used in the GM's of the period. ATF morphed into Dextron, then Dextron II. I have a Dodge car in storage that has "use dextron II " imprinted on the dipstick. When they started putting lockup TC's in transmissions they had to come up with a different fluid. Originally ATF+, then ATF+2 , then +3, now +4.
Do not use Dextron VI in any trans that calls for ATF+4.
