STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
109 registered members (ARCOgraphite, Ag76, Altima2, acme, 2012AccentSE, AandPDan, 11 invisible), 1,969 guests, and 63 spiders.
Topics286,230
Posts4,904,725
Members67,582
Most Online2,967
Mar 10th, 2019
Vanguard 15w50 #4306708
01/19/17 06:39 AM
01/19/17 06:39 AM
Pa, USA
NH73 Offline OP
NH73  Offline OP
Pa, USA
What do you think of this oil? https://www.briggsandstratton.com/na/en_us/innovations/parts-accessories/vanguard-oil.html Do you think its a good indication of that 15w50 oils is a great choice for small gas engines?
2017 Toyota RAV4 Hybrid
2004 Ford Explorer Sport Trac
2012 Gravely ZT XL 48 w/ Kawasaki FR730
Re: Vanguard 15w50 [Re: NH73] #4306721
01/19/17 07:15 AM
01/19/17 07:15 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I typically avoid "small engine oil" since it's the same exact stuff you can buy off the shelf in a different bottle for much, much less money.
Re: Vanguard 15w50 [Re: NH73] #4306737
01/19/17 07:44 AM
01/19/17 07:44 AM
Missouri
vronline Offline
vronline  Offline
Missouri
Obviously you'll get a lot of varying opinions on here and I know people use heavier oils, but they only spec that for Vanguard engines. B&S specs nothing higher than 30w, and I believe that's all you really need, even in hotter climates.
https://www.briggsandstratton.com/na/en_us/support/faqs/browse/mower-oil-type-and-capacity.html
http://blog.briggsandstratton.com/synthe...4-cycle-engine/
Re: Vanguard 15w50 [Re: NH73] #4307294
01/19/17 05:52 PM
01/19/17 05:52 PM
Delaware
2cool Offline
2cool  Offline
Delaware
If you look around in this subject, you will find MANY posting of the great results people (including me) have gotten with 15W-40. Not that I think anything bad would happen, but I doubt the extra 10 numbers of viscosity will give you any more protection. What is the price difference for a quart? If more than a dollar, why bother? 15W40 is widely available.
Re: Vanguard 15w50 [Re: NH73] #4307419
01/19/17 08:38 PM
01/19/17 08:38 PM
Pa, USA
NH73 Offline OP
NH73  Offline OP
Pa, USA
My experience is oils of the same line are priced the same, weather its 0w20 to 15w50. The reason I ask is because, you could get whatever 15w50 is on sale at the time.
Re: Vanguard 15w50 [Re: NH73] #4307539
01/19/17 10:44 PM
01/19/17 10:44 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I think they call for straight 30 in the residential mowers since the home owner will be done mowing by the time it gets hot enough anyways, vs a commercial guy will run all day basically.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Vanguard 15w50 [Re: NH73] #4307569
01/19/17 11:20 PM
01/19/17 11:20 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I use 15W-40 because that is what I have around for my lawn mowers. If i didn't have the 15W-40 around I would buy 15w-50 syn .
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Vanguard 15w50 [Re: motor_oil_madman] #4307570
01/19/17 11:21 PM
01/19/17 11:21 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
Excellent point !
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Vanguard 15w50 [Re: motor_oil_madman] #4307802
01/20/17 08:56 AM
01/20/17 08:56 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't think that's it.
First, don't underestimate the abilities of good quality straight 30 weight.
Second, mower oil gets pretty hot pretty fast - far less than 1/2 hour
Lastly, mower engines are built pretty stout, given their low HP per cubic inch.
The rod journal size (surface area) of a typical 3 HP Briggs is the equivalent of an engine making 20+ hp. That's a lot of surface area for such a small power output. That's why these engines run well even when lots of grit has been through the oil - - there's still LOTS of bearing left (in proportion to power output).
Re: Vanguard 15w50 [Re: 2cool] #4307805
01/20/17 08:58 AM
01/20/17 08:58 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have to agree with this.
I'd buy you a new engine if you could prove that RotellaT 15W-40, Delvac 15W-40, or Delo 15W-40 caused it to fail. (with normal OCI's of course)
Re: Vanguard 15w50 [Re: NH73] #4307919
01/20/17 10:51 AM
01/20/17 10:51 AM
MB - Manitoba
FastLane Offline
FastLane  Offline
MB - Manitoba
Why not use a synthetic 5W30 like Briggs recommends?
2010 Silverado 4.8 4x4 Mobil 1 5W30 ACDelco PF48E
2002 Mustang GT 4.6 Mobil 1 5W30 MC FL-820S
1966 Cessna 150 Phillips 20W50
2013 Mercury 30hp Mystic 25W40
Re: Vanguard 15w50 [Re: Linctex] #4312702
01/25/17 09:50 PM
01/25/17 09:50 PM
Houston, Texas
Houston, Texas
I suppose outside temperature and engine load has a lot to do with it. I know on my bigger mowers, things get warmed up pretty quick. 2-3 minutes and the oil filter is pretty hot to the touch.
Re: Vanguard 15w50 [Re: NH73] #4315351
01/28/17 10:41 PM
01/28/17 10:41 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Briggs has always recommended a 30 weight for as long as I can remember. The fact that they recommend a synthetic 50 weight for hard use engines is quite interesting. This is what we call a "clue".
For years, since the 2004 hurricane season, I have recommended synthetic 50 weight in all generator applications down here. All Kawasaki engines a 40 weight, all commercial Briggs engines at least 15W40, and SAE 30 or synthetic 10W30 for home owner Briggs equipment.
Briggs must be tired of warrantying engines and has finally figured out what a lot of us already knew.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Vanguard 15w50 [Re: bubbatime] #4316047
01/29/17 06:13 PM
01/29/17 06:13 PM
Pa, USA
NH73 Offline OP
NH73  Offline OP
Pa, USA
Why all Kawasaki engines get a 40 weight? Kawasaki recommends 30, 10w30, 10w40, 20w50 and 5w20(if used below 32 degrees). Basically you could use 30 to 50 weight on a Kawasaki. I have 5w30 full synthetic in my Kawasaki lawn mower that gets ran half hour at a time. Would you recommend to use something of a 40 weight?
Re: Vanguard 15w50 [Re: NH73] #4316484
01/30/17 09:53 AM
01/30/17 09:53 AM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Well most Kawasaki engines down here that I serviced are used in a commercial or similar environment. Plus its hot. 30 weight is marginal after hours of use and high heat, so my standard recommendation for anything Kawasaki down here is 40 weight.
Since your equipment is used for 30 minutes in a home owner use cycle, in PA, then synthetic 5W30 will be just fine for you. If it were mine, I would run 15W40 summer and 0W40/5W40 winter anywhere in the lower 48.
