Originally Posted By: compratio10_5
My observations are that addiction to high mileage oil is correct. The puff of blue smoke, only on start-up, is a sign of leaking valve stem seals. High mileage oil swells and softens these elastomer seals and reduces leakage. If you switch back to normal oil, the seals shrink and harden back to their original condition. Compounding this is low temperatures which also tend to shrink and harden the seals allowing oil to leak down the valve stem into the cylinder (remember the Challenger O-ring disaster caused by low temperature hardening). This is one reason that I do not use high mileage oil until there is some evidence of oil burning or leakage.
+1. I noticed Maxlife took the 75,000 mile odometer off its label.. It always bothered me for the reasons you state. Misleads people and gets them hooked on HM oil.
