Originally Posted By: UltrafanUK
Originally Posted By: UG_Passat
Be careful if you use Motul oils as only their top of the range German standard (Group 4) full synthetics oils are good, the rest are just cheap junk oils only suitable for non turbo engines and short OCI's.
Can you elaborate a bit about that?
Not talking about the 300V range I assume, but what about the 8100 range? I have easy and relatively cheap access to 8100 0W40 and 5W40...and also their other offering, 6100/4100 etc.
He's over-reaching is his comment. I guess according to UltrafanUK, Group V blends are inferior to a pure Group IV basestock.
Motul has oils with Group V blends.
502.00 (and 505.00/505.01) are suitable for turbo engines but with fixed intervals (up to 10,000 miles or 16,000 km for the US/Canada, due to the higher sulfur gas)
503.00/503.01 can go up to 30,000 km OCI (with the flexible service interval).
Anyone doing 30K km OCI's is really pushing their luck if they don't get a UOA done!
I know many new cars sold in the EU do have that kind of max recommended OCI, but those cars also
have a warranty that says the oil consumption is still OK until it reaches 1 liter per 1000 miles.
Most owners with VW cars that are post warranty change their oil at 10 to 20K km max.
I thought Motul 300v which is supposed to be their best oil was a G4 synthoil, but I might have misread the TDS. Although A G5 based oil is as good (Some might say better) as a G4, they do not mix well with other oils, so if 300v is a G5, then I would not use it if you are prone to topping up with other oils.
There's many things you said that are blatantly false that you pass off as fact.
you must of missed the part about using the flexible service interval, it is up to 30,000 km and not understand how it works.
the key phrase is "up to", which does not mean "equal to". So, depending on the oil life monitor, which takes money factors into consideration, will tell you when to change the oil, within a safety margin for which the oil standard it is designed for (503.00, 503.01, 504.00 and equivalent diesel specs). It can very well tell to change your oil sooner, maybe 8000 km.
