Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
Valvoline Daily Protection 5w30 - $13.52 at Walmart
by RonRonnster - 01/17/20 06:39 PM
Gotta love Friday
by 53' Stude - 01/17/20 06:11 PM
It was 1911
by CourierDriver - 01/17/20 06:10 PM
Desulfating a Battery
by 5AcresAndAFool - 01/17/20 05:41 PM
weird deal alert: potassium permanganate
by GON - 01/17/20 04:42 PM
Kirkland Signature 0W-20 any good?
by CB22 - 01/17/20 04:31 PM
CPA1989, myisland, BuellRacer, devharryc, UncleNorby
70460 Registered Users
61 registered members (aquariuscsm, A_User55555, 928, AZjeff, adams355, 3 invisible), 1,470 guests, and 25 spiders.
Topics300,265
Posts5,171,962
Members70,460
Most Online3,728
Jan 11th, 2020
Page 1 of 3 1 2 3
Interesting pics I took of Pilot with VCM internal #4195659 09/05/16 11:51 AM
B
BigBuck Offline OP
B
2013 Kia Optima
46,470 miles
Chevron Supreme 5w20
1997 Ford F250 H.D. 5.8
26,500 miles
Formula Shell 5w30
Re: Interesting pics I took of Pilot with VCM internal [Re: BigBuck] #4195665 09/05/16 11:58 AM
slacktide_bitog Offline
How many miles on the car? The front is dirty, thew back is clean. Looks like the back row is the bank that gets turned off in VCM. Is this correct?
In any other transverse V6, the back is usually dirtier than the front.
I hope you gave it new valve cover gaskets and iridium spark plugs smile
Re: Interesting pics I took of Pilot with VCM internal [Re: BigBuck] #4195688 09/05/16 12:46 PM
T
Trav Offline
T
Looks like many I have done, I would change the PCV and the spool valve. The part with the 2 solenoids and blue plug on the rear cyl head, this one may have one on the front also (VCM 2).
These get clogged and fail without warning on engines like this, I have a half a dozen old ones hanging around that failed, when they go the engine will only run on 3 cylinders and it wipes the expensive active engine mounts out and hammers the transmission.
On these I remove the oil pan and clean it out along with the pickup tube and filter mounting pad so I can flush the spool valve passages out then manually clean the heads.
Some before and after of one of these (VCM 1 engine)
Re: Interesting pics I took of Pilot with VCM internal [Re: BigBuck] #4195781 09/05/16 02:50 PM
M
mclasser Offline
M
Cool pics. Year & mileage?
I have the VCMuzzler on my Pilot and couldn't be happier. Power from the 6 cylinders is available at all times without the shudder and lag B.S. from VCM.
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: Interesting pics I took of Pilot with VCM internal [Re: mclasser] #4195824 09/05/16 03:48 PM
T
Trav Offline
T
Yes I did the same thing on some of them, its a resistor in the oil pressure circuit. I works fine and the engine runs like its supposed to but I haven't tried it yet on VCM 2.
Re: Interesting pics I took of Pilot with VCM internal [Re: Trav] #4196132 09/05/16 09:02 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I just installed VCMuzzler a week or two ago, but it's a resistor inline with a temp sensor on the one head, right under the plastic cover. Very simple to do. Makes OBD-II think the engine is around 159-164F.
Re: Interesting pics I took of Pilot with VCM internal [Re: JHZR2] #4196252 09/06/16 05:17 AM
T
Trav Offline
T
Nice! What difference are you seeing in fuel consumption? Does it run better in general? It sucks Honda keeps doubling down on this miserable failure of technology.
Re: Interesting pics I took of Pilot with VCM internal [Re: JHZR2] #4196259 09/06/16 05:36 AM
demarpaint Offline
When the OBD-II thinks the engine is running around 159-164F is it increasing the fuel mix a bit, making the engine run a little richer? Or is it running the same fuel mix as it would be when the engine is running at its normal operating temps? Thanks!
God Bless Our Troops
Re: Interesting pics I took of Pilot with VCM internal [Re: demarpaint] #4196263 09/06/16 05:51 AM
T
Trav Offline
T
Its still hot enough to go into closed loop so the air/fuel monitors (AKA wide band O2) are taking car of the mixture.
Re: Interesting pics I took of Pilot with VCM internal [Re: Trav] #4196269 09/06/16 06:21 AM
Smoky14 Offline
Didn't GM have a great failure in the 1970's with a 4cyl V8? I recall them being a headache beyond fixing.
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: Interesting pics I took of Pilot with VCM internal [Re: Smoky14] #4196306 09/06/16 07:51 AM
T
Trav Offline
T
Yep Cadillac 4-6-8 but i think it was in the early 80's not sure, that was some serious garbage.
Re: Interesting pics I took of Pilot with VCM internal [Re: BigBuck] #4196424 09/06/16 10:52 AM
Smoky14 Offline
That was the one Trav, thanks for the memory boost. That idea was right up there with their diesel efforts of the same era.
Smoky
Re: Interesting pics I took of Pilot with VCM internal [Re: BigBuck] #4196640 09/06/16 03:59 PM
H
HTSS_TR Offline
H
Honda VCM is shutting down 1 bank all the time(when appropriate) ? How about alternate shutting down 1 bank for few minutes then other bank ... Will this would reduce the problem ?
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
Re: Interesting pics I took of Pilot with VCM internal [Re: HTSS_TR] #4196778 09/06/16 06:22 PM
T
Trav Offline
T
The original VCM 1 did that the VCM 2 uses a little different system to try and both banks into the act to some extant, they failed miserably.
Re: Interesting pics I took of Pilot with VCM internal [Re: BigBuck] #4198217 09/08/16 01:35 PM
K
K20FA5 Offline
K
I'm so glad that I got rid of our ticking timebomb! We had just under 95,000 miles on our 09 (VCM2). It had been burning oil for the last 20,000 or so miles. No more Honda V6's for me until they get rid of the VCM and the timing belt! I'll buy their 4 bangers all day!!!
Mine-2018 Chevy Silverado LT Z71 5.3L-M1 AFE 0W-20 / Wix WL10255
Wife-2017 Volvo XC90 T6 Inscription Polestar Tuned 2.0L- Dealer 5W-30
Page 1 of 3 1 2 3
