Finally got the engine installed and fired it up today!! It runs quiet!
You can see the teardown pics here.
http://www.bobistheoilguy.com/forums/ubb...bui#Post3914624
My cost was about $900.
Rebuild pics..
Old scored cam.
Replacement used cam, new ones not available.
Crank and main bearings installed.
Checking ring gap.
I snapped a rod bolt off, so i replaced all of them
I used craftsman torque wrench for all the rods mains and head bolts.
I prefer to use a ring expander for installing rings. Its a simple one.
Lubed the cylinder with a mix of 5w30 oil and Schaeffer's 132
I used my old craftsman ring compressor.
Lubes i used for the main and rod bearings, and the moly paste for the cam. I've had the moly paste for a long time.
Cam install.
Some lifters had to be replaced. I filled them all with oil just before installing.
Installed the timing set, i forgot to take pics of the guides and tensioner,lubed with molypaste. sorry.
The oil pump was scored as well as the cover.
I sanded the cover down on a piece of glass until the scored gaps were gone, i finished it up with a 400 grit. I installed new pump gears.
I forget to stop and get pics of the rear main seal install and the front timing cover. And i neglected to take pics of installing the new luk clutch set. Sorry!
I filled the engine 1/2 quart over with oil, so it would fill the pickup tube a bit higher. The Oil pump was filled up and the oil filter was also prefilled. I usually use a 3600 filter on saturns, but i wanted to get oil pressure up a soon as possible so i used the shorter 3614.
After all the fluids were filled up and checked for leaks. I hooked my charge/starter to the battery and set it for 200 amp starting. I wanted the starter to spin as fast as possible with the spark plugs out of the head. About 5 seconds and the oil light went out. I installed the spark plugs and it stared right up.
No CEL's!!!
Rebuild pics..
Old scored cam.
Checking ring gap.
Cam install.
No CEL's!!!
